View Full Version : Ford Escort RS Turbo
- zvh or full zetec
- Horn problem???
- Trying to locate a s1 rs.
- Inspecting pistons
- rs turbo efi overfueling
- Wiring loom
- which oil grade do you use, theres now fully synthetic anywhere
- breaded cosworth loom??
- Coolant Temperature
- Sensors needed
- Black fuse for fuel ecu
- Indicator stalks mk3 & 4 info needed
- Vibra-Technics witch ones??
- im stuck
- mk5 rs2000 box mated to my rs turbo engine
- steering racks the same?
- rs combi van help!!
- gearbox problem??? or......
- Wheel bearing issue, help!!
- Air lock problem
- Boost stutter Advice
- rs does not idle anymore now
- proper bargain
- spot light c-peice
- efi head on mfi set up?
- rear drum swap??
- 175hp @ 16psi atw
- Throttle cable problem?
- oil dipstick....! series1
- on facebook????
- 2.1 zvh
- boost stalling, losing power, have i bought a shed
- alloy wheel suggestions and pics
- What temp ???
- show me your splitter
- zvh ignition timing
- Ford escort mk3 front track control arms
- No Spark? Help! Everything Checked But Still Nothing!!
- Door won't go back on properly...
- 5th gear making a very strange noise
- turbo
- anyone know this mk3 van?
- Washer bottle
- MS2 with Newmans cam
- Focus rs gearbox in a s2
- zvh head gaskets
- Anti roll bar shackles
- MFI Management Loom Separation
- Metal clutch quadrants
- parts
- 1.8zvh bhp?
- what to do about small rust, or preserving metal
- wheres good for a set up?
- What colour.
- Fuel Line Diameter
- Problems
- anyone tried Corten miller for tuning?
- Rs turbo heat shield onto zvh??
- What to do about this:
- Konis or spax?
- Smoking CVH Turbo
- Which tyres on escort cossie wheels for a Series 1
- do i carry on
- Mk2 RST questions...
- helppppppp please
- mk4 fuel relay?
- do you know this car: H770 WCP
- brake bar picture
- how much you think
- turbo upgrade
- Act sensor question
- Bottom ends
- best gaskets for s2 rs turbo head
- Newman cam
- s1 with no spark
- best place to buy genuine ford parts?
- Rs turbo oil temp?
- Need to ask a favour (N/West people).
- For anyone interested in a Zetec turbo conversion.
- Weird Dash Lights Problem Sorted, Now Weird Horn Problem? Clicking Noise From Relay?
- want to earn some ££ need a handy rs guy, just bought one
- New sticky on fueling related or hot start issues
- Fueling issues
- Which oil
- Starter not turning
- S2 cutting out irregularly? And odd back fire?
- dry sump
- Dump or no dump
- PLEASE HELP no fuel to inj 3 and 4
- anyone on here with 301+ bhp, which gearbox/clutch
- which management system?
- apexi avc
- Fuse box removal
- Adjustable lower arms
- wheres the idle valve?
- 285mm discs
- mtx quick one
- Fan & Heater Matrix Not Switching On?
- exhaust joint ring gasket and spring bolts
- Worn Camshaft Followers
- mtx75 rs2000 or focus rs gearbox
- Misfire on no2 cylinder
- vernier pulley on std cam
- Rs turbo hunting
- Newmans cam Timing.. HELP!!
- whats it worth
- Few rs turbo questions for buftys re original parts
- need some help please (ignition timing)
- 2.1 zvh turbo
- gearbox cradle
- rst vs poverty spec wrx
- Driveshaft problems!
- need urgent help plz
- Help , 1 week too ford fair rst front suspension botteming out :-/
- Oil return pipe
- anybody going ford fair next sunday??
- where can i get some mk3 escort spots from?
- map Sensor Supressor
- as promised couple of pics of my s2 more to follow just weather is on and off
- Hot starter motor?
- Series 1 tickover at 3000 revs!
- anyone breaking their car?
- Mobile turner
- Rs turbo CTS gearbox
- Escort MK1 Hayabusa Conversion?
- 2.1 zvh with no Cambelt :-(
- s2 rs rev counter problem please help
- Strut Brace
- whats up with my gearbox
- g600 unm
- s2 Wanted!!
- Replacement panels
- cold start?
- mondeo mk3 calipers?
- only running on 2 cylinders
- Please help I.D a camshaft
- Information on Rolling Road?
- coilovers catching rear wheels?
- P8 pin for lambda sensor
- is there any out there with out rust or serious running problems
- top speed with std rst gearbox
- 1.8 zetec into s2 rst
- Rst alternator fan...
- Dump valve
- Escort dials mk4
- Crownwheel & LSD
- newbie and his car rst cab
- Master Cylinders Size - Help Please!
- Manifold help......
- Starter motor & alternator wireing
- Pedal box's
- turbo oil seals
- Fuel Pressure test
- Ecu & fuel ecu
- Pillar pod?
- efi pic request
- fitting afr and egt gauge
- 17 inch wheels
- new turbo
- Sump Gasket...
- fuel regulator
- green 803's (MOT)
- power run today/graphs
- S1 still hunting
- Rs turbo no spark
- rs turbo b and m quickshift, where from ?
- PLEASE HELP ME! CO keeps rising and won't adjust!
- MS ECU Voltage
- mega squirt??
- actuator
- Wiring loom question
- engine adjustement after rebuild
- Gpa coil question
- Firing order
- Non starter
- Best s2 tyres
- what to do?
- Innovate MTX-L "narrowband" output to replace CO Pot?
- Radiator and intercooler set up
- Escort RS Turbo S2 not starting after changing fuel filter
- Mk5 escort zvh t l6 management
- 2 stage boost stopped working - Amal valve?
- exhaust paint
- Im back!!!
- Hid kit
- Anyone own H GWC
- efi conversion will only fire up off a permanant feed to relays?????
- cossie managment help plzzz ....
- which side of fuel rail does fuel feed go???
- No fuel to injectors
- Central locking help
- s2
- alternator wont fit??
- what gearbox?
- Central locking problem ...now fixed!
- Mtx driveshafts
- Focus rs brake setup
- Pricing help on nos stock
- Carbon Roof Advice
- Mk4 door skins
- RS1600i Inlet
- stuttering on boost
- Twin fan loom.
- sunroof tray ???
- rs turbo as every day car?
- people who have spent big money on a clutch
- engine noise! almost given up
- rs mud flaps
- Hub upgrades
- main cap bolts
- omex, emerald, cosworth l6/l8 for zetec turbo
- mk4 escort rst into mk3 1.1 bonus shell project!!
- Frst oil pump say as erst
- Bodyshop Help
- mk3 mk4 escort engine mounts????
- help with pricing on these parts please?
- anyone know any history of my s2? F587GDV
- Cant decide!!
- running rough on cold start up
- Removed Fiesta abs what next?....
- setting up ofab
- Colour Change on S2
- Knocking rst engine.
- Oil cooler
- Fueling issue
- Ignition problem
- mk6 rs2000 for a mondeo st 24
- Escort S2 Engine Problems !!
- S2 strut brace
- stage 2 or stage 3
- Drove The RS
- any other options
- zvh or zt??
- Rs turbo servo
- Took the carpet out.....
- rs turbo rear armrest
- Clutch
- zvh turbo cossie management help needed
- Bleeding the Metering head!!
- How do people rate the bosch ev14's?
- Replacement servo
- Anyone know this car??
- What injectors ?
- Windscreen fitting diy
- Escort rst running hot
- Escort S1 RST Gartrac wide body
- Essential upgrades
- Over heating/ bubbling
- Saggy rs turbo door cards
- Seat belt spacers
