PDA
View Full Version : Ford Escort RS Turbo
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 [77] 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107
  1. bonnet
  2. bonnet won't close
  3. my cars finally been setup
  4. zorst problem??
  5. brake advice? please
  6. Tuners up in Scotland?
  7. holding back on boast any ideas
  8. hmmm some advice would be good...
  9. Map Sensor Supressor for OFAB EFi
  10. Best alloy rad
  11. dials
  12. start up
  13. any ideas on the spec of this?
  14. mk3 vs mk4
  15. S1 won't start. Help please !
  16. boost
  17. revv limit 2.0 ZVH
  18. Radio Loom
  19. Looking for KE-Jet experts
  20. big flat spot!
  21. Is this a swirl pot?
  22. window problems
  23. lsd box
  24. full respray?
  25. Just Ordered Cobra Springs
  26. cant boost above 2-3psi!! help!! Options
  27. RS Turbo Weird!
  28. how do i know if my 5th injector is working?
  29. i/c
  30. wheel bolt thread
  31. help needed - actuator
  32. Series 1 Rear Speakers Wanted Cash Waiting!
  33. Other engines in mk4 escorts
  34. steering wheel boss
  35. whic ap clutch
  36. Headlining news...
  37. ITV1 looking to hire and film a 1980s Ford Escort
  38. How much boost are you running?
  39. Turbo suppliers/reconditioners
  40. half pace intercooler
  41. front mount i/c......pace or pro alloy????????????
  42. Pace intercooler
  43. Brakes...310mm to big??
  44. boost problem
  45. buying a three door
  46. electronic boost controller on MFI?
  47. S2 REAR SUSPENSION
  48. Clutch fixed, but now over boosting!
  49. standard gearbox
  50. No go with 1 psi of boost
  51. Gearbox for 2.0 zvh turbo
  52. ecu pipe ?
  53. 1.9 cvh engine
  54. zetec turbo water pump
  55. wanted. s2 chip
  56. different boost
  57. bigmatt's ofab question thread!!!
  58. frst/ 2i
  59. safe & reliable bhp
  60. wot front splitter do peple have on there ERST then?
  61. brakes
  62. drivers seat s2
  63. alarm prob (may be)
  64. live mapping
  65. BOOST!!!! WONT GO UP!!
  66. Advice on S2's
  67. Turbo and ECU compatability
  68. Engine rebuild and initial timing check assistance
  69. Front Lower Arm bushes
  70. Mk3 bumper end caps
  71. S2 roof cloth..
  72. standard clutch
  73. master cylinder
  74. When replacing valve stem oil seals
  75. S2 Suspension??
  76. Gear Linkages
  77. XR3i Inlet Manifold onto MFI
  78. oil
  79. RST starting problem
  80. -31 actuator
  81. Clutch and gear box
  82. Clutch
  83. bhp
  84. Anyone got the part number for the t3 drain pipe
  85. cvh or zvh
  86. chrome or alloy cages
  87. rear windows
  88. no boost
  89. brakes continued from yesterday.
  90. RST Fuel hose queery
  91. boost problem
  92. Teeny weeny part required
  93. chargecooler/intercooler??
  94. just back from rolling road...NEED ADVICE please
  95. efi conversion sierra pulley
  96. stearing wheel??
  97. bhp gain on gas flowed head
  98. Thread size of RST gear nob/lever
  99. S2 weight
  100. smell burned oil, but no smoke, no play shaft in turbo
  101. Help Wanted
  102. cossie or EFI management conversion?
  103. which ecu 2 which model
  104. mechanical or electric gauges
  105. think my engine just went bang!!
  106. modded front bumpers lets see them!
  107. Exhaust Heat Wrap
  108. Fuel Pump
  109. T3 rebuild kits on ebay
  110. Granada cosworth
  111. Zetec Turbo in S1
  112. Super power gaining throttle body!!!????
  113. S2 Won't start Please Help
  114. Series 2 Steering
  115. INTERIOR/DASH PICS REQUEST
  116. i think its the plugs
  117. is my new auto gauge(boost gauge) reading correctly????
  118. sun roof seal
  119. what will i need to do to my engine.....
  120. cvh head
  121. speakers
  122. exhaust gaskets
  123. 1198 'S' plate s2
  124. NGK BCR8ES
  125. radiator
  126. starting problems
  127. spark plugs
  128. Speakers on S1's
  129. My car is sick.
  130. Thinking about dipping my toe into RST ownership?
  131. Removing ABS
  132. Same old
  133. boost gauge wires,wheres best to connect em?red black,orange
  134. New Style MOT
  135. rs1600i rocker cover with turbo crossover pipe
  136. That I connect to him to this block
  137. boost
  138. where to get gearbox rebuild
  139. whinning gearbox
  140. see how she sits nice now!
  141. help rubbing,knocking noise coming from front of my rs?
  142. does anybody know?
  143. oil cooler
  144. rocker cover breather
  145. efi conversion
  146. s2 turbocharger advice
  147. interval
  148. brake lines
  149. Few questions…
  150. cossie managment help
  151. RS Off the road again
  152. not startin again
  153. Price of GRS cooler?
  154. s1 chipped ecu ?
  155. Focus rs engine in ERST
  156. what make of guages do people use?
  157. oily exhaust chamber
  158. Spark plugs - do they look OK?
  159. My car wont start!
  160. series 2 wont start
  161. unlimited boost chip
  162. what wheels?
  163. Zetec turbo manifold
  164. another week another problem!(Dizzy)Still unsolved, HELP!!!
  165. oil cap blown off
  166. ISCV
  167. FAO people with Koni's
  168. Producer nightmare?
  169. spark plug gaps?? motorcraft 901C1....
  170. cracked dash solution on S1
  171. Strut refitment
  172. car wont idle, help needed
  173. Bottom balljoints
  174. crunchey gears
  175. Supressor
  176. metering unit
  177. 2.1zvh conversion
  178. E.F.I CONVERSION?
  179. is the exhaust on my car any good?
  180. gearbox/clutch problem ?????
  181. cheap insurance
  182. need a bit for my sandwich plate, anyone got it??
  183. Radtec frontmount intercooler
  184. IS THERE A GASKET BETWEEN THE MANIFOLD AND THE TURBO
  185. Cosworth Brakes
  186. bit of help needed
  187. Temp gauge on dials
  188. -31 ACTUATOR?
  189. rst into mk5 help
  190. replacment dials
  191. erst radiator swap
  192. bushes
  193. who do i see about loom plugs??
  194. Power Steering Conversion?
  195. whos put st24 breakes on there RS?
  196. ANy1 using saff cossie intercooler
  197. whats it worth?
  198. how to tell boost pressure
  199. replacing heater matrix
  200. H725 WCP - " Who's Car ? "
  201. unlimited boost chip
  202. porbley been asked 1,000,000,000 times
  203. LSD BOX clonk clonk!
  204. does anyone know anything about my car? E444TNY
  205. smokey s1
  206. Escort TAXI
  207. revs drop
  208. cossie brakes under s2 alloys
  209. misfire on boost
  210. s1 anti roll bar on s2???
  211. difference between s1 and s2 ecu
  212. S2 with S1 kits......
  213. Converting XR3i EFI to Turbo
  214. s1 pinking like mad.....
  215. rs 7 spokes on rs turbo?
  216. smoking rst
  217. power/performance
  218. best spark plugs
  219. Had Our Escort Rs Set Up On Friday
  220. Tappets...
  221. bleeding s2 brakes
  222. FTAO Oranoco & Peeps running Paradas
  223. Are S1 and S2 Windscreens and scuttle panels the same?
  224. S1 turbo
  225. Has anyone fitted a Diesel turbo unti to their car?
  226. newbie help, just bought an RST
  227. Few probs with my s2,can anyone help please?
  228. set up after gearbox replacement?
  229. what is the et for wheels and pcd as well, anyone know???
  230. Best place to get new lifters--and how much?
  231. Help with bushes needed
  232. cts gearbox
  233. rs turbo gearboxes
  234. s2 Engine into mk5 xr3i 1800DOHC
  235. bloody cars...
  236. low comp and ignition timing ?
  237. efi head.
  238. noisy tappet sound
  239. Rear Discs
  240. hmmmmm is this a con?
  241. are XR3i and RS rear break shoes the same?
  242. S2 Black bodykit rivets still available?
  243. Highest boost on standard turbo?
  244. cossie managment phase sensor
  245. Fiesta turbo lump into mk3
  246. ECU CHIP
  247. Rattle wont go away !!!!!!!
  248. Removing the black underseal in the wheelarch--SERIES 1
  249. Noisey Tappets---How hard to change
  250. MK3 Onion Ford Workshop Manual
