PDA
View Full Version : Ford Escort RS Turbo
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 [45] 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107
  1. woodruff key
  2. Ford Escort MK4 1989 Project
  3. people that have rear headrests
  4. pi or jamex springs
  5. minimum head thickness for CVH
  6. can uput the engine and gbox in together?
  7. serria cossie turbo will in fit erst ?
  8. Question about clutch and gearbox...
  9. frst air temp sensor fitting
  10. Wat oil?
  11. Pro alloy turbo cooler?
  12. Cossie compressor wheel
  13. escort cos wheels on series1
  14. brake pipe length
  15. Sump removal
  16. brake pipes
  17. Brake Master Cylinder
  18. powerflex top mount.sorted now thanks folks.
  19. newbie
  20. driveshaft wont come out.
  21. head puzzler
  22. all you efi guys.
  23. Best intercooler/rad/fan set-up + spotlights
  24. hi all brake problem
  25. Cam shaft recomendations
  26. S2 electric window switch location
  27. electric windows mechanism
  28. stripped....
  29. F114 BKY
  30. Stage 2 turbo
  31. turbo problem
  32. Turbo spares?
  33. FIXED!! Intermittent Boost leak?! Tried everything!!
  34. Gearboxes?
  35. erst lowering
  36. Clutch Problem
  37. Spark plugs
  38. boot decals
  39. Anybody Interested....
  40. Offset on mk4 rs turbo rims
  41. AP Clutch?
  42. Help please!!
  43. Struts
  44. Vacuum hose
  45. Mk3 Escort
  46. More clutch problems!
  47. window thickness
  48. Oh dear lord
  49. buyers guide/advice
  50. What to do???
  51. Sump plug problem, new gasket and still leaking..
  52. ERST Cossie Management issue
  53. Headgasket replacement
  54. Oil pumps
  55. MFi engine build questions
  56. series 1 rs turbo
  57. brake fitting sizes.info needed.
  58. no number plate / fine/ points ??
  59. twats and total twats
  60. gutted !!!
  61. Will a Piper cam pulley fit a kent cam
  62. bonnet spacers
  63. Adjusting MFI?
  64. minimize torquesteer
  65. Cone filter or panel filter?
  66. finally had enough
  67. Clutch's
  68. Lost my keys
  69. Check my new blower out! :-)
  70. Mickey, ref GRS...
  71. help needed plz!
  72. how bout this for a 1.6cvh????
  73. gearbox oil
  74. Fuel return to tank...
  75. coilovers
  76. Fitting front suspension.
  77. Battery model
  78. mot failed
  79. why use wheel spacers?
  80. CVH Tuning....
  81. Series 1 Rs wont start..ideas?
  82. 17"s
  83. Boot floor repair panels
  84. Front panel
  85. For anyone interested in seeing headwork!
  86. metering unit order
  87. head
  88. Does anyone know the ohms
  89. Single wiper opinions
  90. Opinions Please!
  91. im looking for D345 LCE
  92. top speed
  93. Just had "the call" from NMS
  94. Help Please
  95. Gotech mini x
  96. removing doors
  97. Question about silent blocks kits....
  98. Air filter size?
  99. Rs number plates
  100. My escort turbo pickup thread!!
  101. Help with wilwood pads
  102. Suspension like hell, what went wrong...:((
  103. Quick question: How much tyre pressure STD 195/50/15 & T1R toyos.
  104. Changing my Clutch need a lil help
  105. Scrap it?
  106. S1 Actuator Adjustment
  107. wheel bolts to studs and nut?
  108. RS turbo LSD in other car?
  109. advise/help
  110. What silver for wheels?
  111. rs turbo fuel metering unit
  112. alloy radiator
  113. Zvh
  114. people with 90-spec fronts and BIG intercoolers/rad/fans
  115. New member from Basque Country
  116. Losing water and other things
  117. Escort cleanup
  118. What tyres?
  119. s2 rst wont boost actuator?
  120. Mk 4 escort windscreen
  121. rear brakes
  122. Running lumpy
  123. warning light on dash
  124. 3" bore exhaust off a cossie
  125. help?!?!?! erst s2 fuel metering unit
  126. Turbo'ing an EFI XR3i
  127. Washer bottle (front screen) S1
  128. spacers to fit cossie discs with RST callipers?
  129. Triple gauge holder in heater vents
  130. Indicators only work when i put foot on accelartor
  131. S2 ERST running / starting problems
  132. are series 1 and series 2 brake servo the same?
  133. series 1 wont start
  134. any one used these
  135. how to make std rs brakes sharper?
  136. smoked rear lights
  137. smoked rear lights
  138. 2.1 16v turbo conversion
  139. Show us your wheels on your S2
  140. Recaro seats
  141. im lookin for a good garage in torquay to set up my s2 rs turbo
  142. zvh alternator bracket help
  143. Fao track peeps....
  144. Blocks
  145. series 1 rst water pump
  146. rear speaker brackets
  147. Fiesta turbo engines
  148. Fuel pump wiring relays
  149. fuelling
  150. gearbox oil filler
  151. SCS Live Mapping
  152. How to fit S1 arches on a S2
  153. Escort Rs Turbo Setup
  154. Spotlights
  155. how do you take an engine out??
  156. Help car shakes when i brake hard
  157. Front Splitter fixing?
  158. Engine
  159. my car wont start trying but wont
  160. Few gearbox related questions if i may
  161. poly bushes for a series 2
  162. S2 wont start!
  163. Series One HELP!!
  164. Hhhhheeeellllllllllpppp !!!!!!
  165. CPS for efi? use sierra cps ?
  166. Blue smoke
  167. TURBO
  168. b and m quickshift
  169. help plz, s2 cradle mount and gearbox problem
  170. Escort RST Mixture screw block off
  171. Seam welding
  172. Front Towing Eye....
  173. paddle clutches
  174. Area Six manifold
  175. Can't get it up
  176. Flocked Dashboard and Interior.
  177. Xxxxx gaz coilovers xxxxx
  178. can any 1 help
  179. how mutch power and which chip?
  180. Problem changing gears
  181. clutch
  182. RST Problem
  183. is this normal???
  184. Tiger stripes on black s2
  185. Rebuilt engine wanted
  186. T3 Rebuild parts
  187. mk4 Amber spot lights??
  188. Got me new shell and rims
  189. Ride Height
  190. rs bumper skirt
  191. pic of the wiring behind the dash on a S2?
  192. radiator clearance when fitting FMIC, S2
  193. Morning
  194. My First EscRsturbo
  195. FAO people who's battery light is on dim all the time!
  196. Pistons
  197. S2 starting probs
  198. Need loom 1.1 or 1.3 escort..
  199. inlet manifold removal
  200. cosworth leather ?
  201. S2 Classic insurance?
  202. Rollcage for my escort rst pickup
  203. recaro seats undwind themselves
  204. Rs turbo ecu question
  205. Roof skin?
  206. rust bubles round sunroof ? easy way to repaire needed
  207. Which Sunroof?
  208. Metering unit, full of fuel and then just exploded fuel everywhere
  209. battery again
  210. Metering Head
  211. my rst cab
  212. Gearboxes
  213. Clutch cable
  214. anyone know how much for windscreen and fitting for escort cabrio
  215. What a knob!
  216. What colour for series 1?
  217. Autospecialists
  218. Amal Valve Lettering?
  219. Trouble with my RS1600i Turbo, wont start
  220. Look what I found yesterday!
  221. A little help with boost please
  222. chassis stamp
  223. New discs and turbo cooler
  224. low comp/steel rods
  225. shock absorber top mount
  226. efi ofac to ofab
  227. cosworth rear disc's
  228. What HT Leads
  229. spark plugs
  230. HT Leads
  231. What do I need to convert my MFi RS Turbo to run EFi? Updated 05/04/14
  232. stalling
  233. mfi tps setting
  234. tuners
  235. found this
  236. Quick question for peeps running zvh
  237. Boot floor
  238. bleeding brakes?
  239. Forged pistons
  240. Fuel pump mishap
  241. Chip question
  242. Stainless Steel Inner Sill Covers Mk4 RS
  243. new rs turbo
  244. rs turbo MFI to EFI help needed
  245. Big boost peaks
  246. 87 rst spotlight specs
  247. water pump
  248. 200bhp
  249. Driveshaft Nut
  250. zetec bottom end
