PDA
View Full Version : Ford Escort RS Turbo
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 [103] 104 105 106 107
  1. S2 Engine setup in the north west area
  2. Not starting...?
  3. S1 flywheel
  4. cheap bottom end
  5. S2 RS turbo escort
  6. Sum1 told me...........
  7. why 2wd discs and not 4x4 on a s2 erst
  8. max boost rst????
  9. **TWIN PODS now available**
  10. Fuel relay on efi (zvh)
  11. What think?
  12. exhausts
  13. engine tuning
  14. Am i at the limit?
  15. efi cossi management
  16. Overboosting
  17. 48mm housing?
  18. help needed pls
  19. Quick head question
  20. Clock Reset
  21. XR3i starter in RS?
  22. insureance for modded rs
  23. newbie help.. (performance)
  24. think my crank will be ok?
  25. Radiator!!
  26. how do I??
  27. black thing under the bonnet
  28. black thing under the bonnet
  29. black thing under the bonnet
  30. Do Esc Cos rear discs + calipers fit mk4 escorts?
  31. Serious overheating going on...
  32. s2 gearboxes
  33. Steel/Metal/Chrome Boost pipe
  34. Difference between a S1 and a S1 custom?
  35. mk4 16vZetec with power steering
  36. rs turbo bonnet question
  37. Cossie discs and S2 calipers up front?
  38. RS7 17" on a series 1
  39. exhaust housing swap ???
  40. Carbon fibre rocker cover??
  41. boot sticker??
  42. Brand new header tank ??
  43. F.A.O peeps with frontmount GRS i/coolers
  44. A question for the ZVH people out there
  45. oil pressure
  46. stickers
  47. WANTED RS 7 spoke alloys 17" cash waiting pl help !
  48. Setting the timing on an Rs Turbo
  49. DOUBLING UP ON HEAD GASKETS
  50. running in new motor?
  51. Has my head been skimmed too much
  52. I'm selling the 288 BHP monster!
  53. wots the best engine mounts
  54. Most BHP Using T3 Turbo
  55. Cracked Pistons
  56. fitting instructions for Spec-R oil breather
  57. ray masons number?
  58. Whats a Electonic Dump Valve
  59. Anyone know of any cheap insurance companies
  60. tubular manifold for S2
  61. Removing the ABS from a S2
  62. series1-oil breather tank?
  63. engine diagnostics
  64. Alloy intercoolers
  65. Poorly car again
  66. fuel computer
  67. BOLLOX!!!!!!!
  68. cast or forged pistons??
  69. Gearbox!!!
  70. [u][b]Anyone know about 2.1 ZVH[/b][/u]
  71. Wanted!!!
  72. What next???
  73. stinks
  74. series1 pace intercooler?
  75. help series1 wiring loom
  76. Painting my headlining?
  77. fooked engine mounts
  78. s2 monsta-van ,/its for sale now,,van,
  79. Breaking my RS (Sadly)
  80. CAM KIT & FOLLOWERS
  81. best spark plugs
  82. Alloy rads
  83. S2 Problems... please help
  84. 90 spec intermitant (variable speed) wiper
  85. Can everyone vote plz
  86. Bmw
  87. rs seven spokes
  88. Gear box noise on a s2 rs
  89. clear lights for a S2
  90. Rough output on my s2 ( another post sorry )
  91. B453 JWP, where are you now!
  92. RELAYS
  93. rough power output on my s1
  94. Smokey RS Turbo help!
  95. ADVICE ON MY S2
  96. size on engine
  97. S1 RSt QUICKSHIFT
  98. WILWOOD 4 POTS
  99. PETROL SMELL!!! S1 RSt
  100. recommendations for a check up...
  101. My Cabbie RS so far
  102. S1 BHP Upgrade Advice
  103. what would these be worth...?
  104. Tyre pressures
  105. S1 Massive Missfire
  106. s2 buying guide??
  107. Gearbox/clutch Noise
  108. Top end knock
  109. Spec-R strutbrace where from?
  110. turbo repair kits
  111. S2 body kit
  112. Fuel computer accuracy
  113. Thinking of selling my S2
  114. CVH problems
  115. S1 owners......I need your help on.....
  116. Compression ratio Help
  117. S1 C245 SAP
  118. help identifying a camshaft
  119. Kent cams???
  120. unknown noise?
  121. new engine
  122. Rebuild time, Pistons, Rods
  123. side to side movement on the turbo shaft
  124. Turbo engine has high expenses
  125. New boost guage. Cossie inspired...
  126. advice on rst big ends and mains
  127. rear drums
  128. cloud of smoke
  129. SPACER INBETWEEN GEARBOX AND ENGINE
  130. eatin starter motors
  131. S2 RS Turbo
  132. Zorst Q
  133. any 1 seen my old escort rs turbo???g900 gex blue
  134. CAN ANYONE HELP?
  135. who wanted a cheap rst stainless??
  136. more bhp!
  137. HELP WITH RESTRO
  138. BHP Question as below ???
  139. inner arch liners
  140. what tyres?
  141. BHP Question ??
  142. Advice?
  143. sji 2993
  144. running problem a mystery with my s2
  145. Cibies??? Your Opinions Lads...
  146. Misfire on S2!!!
  147. Any ideas why I got no Comp on Bore 1.
  148. Change MFI to EFI??
  149. turbo oil feed pipe
  150. Black S2 WITH POWER STEERING (LOTS OF PICS) updated 14/9/04
  151. does anyone know... ?
  152. Brake pads
  153. help!!!with grs i/c.
  154. fucked drive shaft
  155. will it fit ?
  156. 5th injector set up
  157. Head Gaskets???
  158. Various questions and concerns....
  159. NEED ASAP
  160. turbo water pipe
  161. HOW FRAGILE ARE ESCORT RST'S
  162. what to expect. BHP?
  163. I wanna s2 RST
  164. Manual "Override" Fan Switch
  165. How did the meeting go???
  166. n00by question
  167. recaros
  168. flamer kit
  169. S2 people with S1 rear glass!Please help.
  170. how low can u go?
  171. from mfi to efi
  172. Help With Sensor Lights On Dash S1
  173. S2 mercury grey '90spec(NOW BREAKING)
  174. RS meet in the midlands anyone...?
  175. actuator rod length
  176. Has anyone got one of these??? Oh and these!!!
  177. Series 1 pictures
  178. 7.00 MACCYS J30 OF M1 TOMOZ NIGHT.
  179. help?
  180. cossie managment on efi manifold - pic request
  181. Will S2 Exhaust system fit S1?
  182. rst box
  183. Is it still available???
  184. M1 J30 Yorkshire meeting???
  185. starter getting too hot
  186. rear disk conversion
  187. Oil pump.
  188. s2 erst
  189. Ahhhh, juddering is back!
  190. ALTERNATOR?
  191. frst q (i know but i figure more ppl look here)
  192. Help wanted: timing a kent cam with vernier pulley?
  193. Gear Selection Question
  194. S2 Too Low
  195. amal valve wire??
  196. boost query
  197. handling question??????
  198. selling up!
  199. handling problem, please help!
  200. help with removing turbo on S2
  201. coolant fan
  202. power steering
  203. People seriously underestimate these cars..... Ha Ha
  204. how much...
  205. TOP SPEED OUT OF RST..
  206. S1 RS Turbo pods.
  207. wot boost ?????
  208. Headgasket gone ????
  209. Soft Brakes
  210. what is...
  211. shot in the dark?
  212. sump gasket
  213. 2.0 zvh compression info.
  214. little help with wiring anyone??
  215. Std RST Torque?
  216. Warped discs
  217. wot turbo
  218. SATURDAY 11 SEPTEMBER RST MEETING
  219. s2 rst
  220. specs of RST T3 unit needed
  221. Whats Needed to Turbo My XR??
  222. efi management on rs turbo
  223. Escort RS Turbo's & tuning?
  224. Sizes on pistons
  225. cone filter heat shield ?
  226. My 2.1 Bottom End On Ebay
  227. got my car back today!
  228. centre air vent dials
  229. Changing turbos round?
  230. Noise
  231. poly bushes
  232. is my turbo fooked
  233. some good stuff here
  234. ERST External Wastegate
  235. Replacing gearbox.
  236. RS 17" 7 spoke wheels
  237. B&M quickshift
  238. jack eye covers
  239. anone got a spare piston??
  240. couple of pics of my 1st rs
  241. FAO: RST suspension, setup and handling gurus
  242. Gear lever jumped?
  243. HOW MUCH?
  244. a few queries...
  245. How much are these things worth?????
  246. Rs Turbo S2 Running Problems Again
  247. FAO: National Day Parade Lap peeps
  248. Advice needed - turbo running gear!
  249. S1 - replacing center air vents with guages....
  250. Plastic arch liners....
