size on engine
multiply half the bore diameter by[in mm] its self ,divide that by 3.142 ,multiply that by the stroke ,multiply that by 4 and then divide that by 100 and that is your answer, if not email me the bore and stroke and i will give you the answer
Location: fee,fife,foe,fumb,i smell the blood of an englishman ,in scotland!
does it matter with a rebore???thought if you changed the bore dramatically(overbored liners) ,,thats when the petrol gets gulped propa.
If you have had your engine overbored you may notice a slight differance in fuel economy! The best thing to do would be to get it set up by a reputable tuner in your nearby area and they should be able to cure any fueling problems for you. About the maximum over bore you can go on a 1600cc CVH block is About 1905cc, but you start running into reliability troubles!
Matt
Matt
lee2cossies
26-08-2015 10:04 PM
