PDA
View Full Version : Ford Escort RS Turbo
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107
  1. Need some help please with rs turbo!
  2. Afr readings
  3. How to test cold start termo-time switch
  4. pics of escort mk4 in frozen white
  5. s2 wont start after new bottom end fitted
  6. big power cvh problems with roller rockers pics
  7. escort rs turbo misin when revs
  8. show me your black s2 erst wheels
  9. 8 to 10 bhp fitting this?????really????
  10. How good are RST aerials ?
  11. Zetec turbo intercooler
  12. Air Injectors
  13. air fuel ratio??
  14. Zetec cold start video
  15. Escort Rs Turbo Air lock/over heating help!
  16. S2 boost problem
  17. Relay issue on S2 ERST.
  18. O.K.C
  19. Megasquirt idle speed control....?
  20. brake pipe length??
  21. help car feels deadly to drive
  22. Wheel lock remover
  23. Turbo Question? (mosty likely again)
  24. Front Goodridge Brake Line
  25. mk3 escort, can you convert early strut tops to late?
  26. Optional Extras
  27. Fitting OMP strut brace??
  28. MK5, MK6 pedal....? Pic inside,
  29. rear brakes
  30. std cvh max boost pressure and std pressure ??
  31. sump nightmare
  32. timing?
  33. Do FRS disks fit straight under standard S2 rst wheels?
  34. 31 actuator what does it do better than standard one?
  35. erst boosting issue :/ actuator??
  36. Genuine mark4 escort wing
  37. What is this connector?
  38. clutch time!!
  39. Fueling Problems
  40. bonnet flew open @70mph (with pics)
  41. Turbo?
  42. power hood motor not working
  43. car wont stay running
  44. Polycarb Windows
  45. CTS stage 1 gearbox
  46. Central Locking Problem
  47. MFI Injectors
  48. cosworth managment??
  49. MS Injectors...
  50. metering head unit
  51. Anyone know of this series 1?
  52. se 500
  53. So how many scorts going USC this year?
  54. best suspension for s1 rst???anyone
  55. opinions on best oil?
  56. air fuel gauge
  57. rear brake cylinder, is this the right part????
  58. g750 tbw
  59. Re-Painting Inlet Manifold Tips?
  60. petrol tank
  61. anywhere in leicester for setup ?
  62. The perfect et "offset" for rsturbo s2 with 16"8" ??
  63. Zetec upgrade
  64. mondeo brake upgrade
  65. cosworth/rst hybrid distributor
  66. Wiring loom clips for a S2
  67. Rs turbo clutch allignment tool
  68. Uprated Alternator
  69. Cosworth 4wd brake conversion, which master cylinder?
  70. New camshaft and followers...
  71. starting problem
  72. engine number pleeeease???
  73. indicator wiring diagram?
  74. Holding Back EFI?
  75. Efi rs turbo greens??
  76. Help needed!
  77. LUK cover plate and helix 4 paddle on a S2?
  78. Flywheel zetec turbo
  79. Help please with escort rs turbo
  80. T3 turbo removal
  81. Blacktop queston
  82. 42/.48 60 trim turbo?
  83. afr gauge
  84. 500bhp rs turbo
  85. Is there 2 different types of release bearing?
  86. mk3 escort bulb holder
  87. fuel sensor (fuel trim computer)
  88. Hydrolic clutch mod on escort rs turbo
  89. Ap 6 paddle clutch kit, pedal mod?
  90. favour needed
  91. Red s2 owners read please
  92. head lights
  93. Escort s2 turbo turbo rebuild spec
  94. What kind of bhp can i get out of this!
  95. little bit of help/ advice please
  96. Which disk's and pads to get?
  97. s2 arb size?
  98. Arch rolling
  99. rs turbo aerial cable
  100. rst boost problem
  101. Running Hot
  102. help.
  103. Escos Alloys on S2
  104. expansion tank not getting warm
  105. Track or fast road?? peoples thoughts please
  106. turbo play
  107. Cossie TB what size hose?
  108. Escort S2 rst / front strut problems
  109. sensors on mfi locations with pics help
  110. Helllllllllllllp
  111. RS Turbo Clutch
  112. BC Gearbox diff bearing shims
  113. escort rs turbo set up in kent?
  114. I/C hose diameter
  115. Fitted the .48/60 T3... Interesting results! LEAKS FOUND!
  116. escort rs turbo
  117. s2 engin number
  118. Mfi idle mixture screw
  119. s2 erst front clear indicators
  120. S1 or S2
  121. lovely
  122. .63 exhaust housing
  123. Blew hole in the mongoose
  124. saab 0.48 exhaust housing on a T3
  125. More RS Turbo's off the road than on?
  126. 4wd rear brake conversion - Denmark
  127. Inlet manifold which is best s1 or s2?
  128. Efi rs turbo wont start !!!
  129. Alternators
  130. RS Turbo Metering head.
  131. full service parts and core plug set
  132. frs brembo
  133. MFI fuel distributors
  134. Do I break or do I sell complete
  135. Coilover Fittment help please..
  136. s2 WTF
  137. S2 Bumper mouldings.
  138. H4 CRA
  139. Changing final drive ratio..
  140. s2 loom and running gear into mk3 escort
  141. 2.0 zetec webers
  142. MFI-EFI
  143. 88 spec recaro seat fabric
  144. fuel pump relay advice please
  145. Advise need on clutch
  146. who loves there old school cars
  147. Mounting mtx75 to cvh
  148. .48/55 vs .48/60 T3 on a RST..
  149. any ideas?
  150. Gearbox Question
  151. Mk6 runners
  152. stolen rs turbo
  153. cossie 2wd 4pots on s2 help
  154. Anyone got a parts diagram for pedal bar set up please
  155. help anybody got 2 spare pistons for sale ???
  156. Is it my actuator?
  157. Gasket suppliers
  158. Airtec single pass on 80 spec.
  159. which engine for rs turbo
  160. Help with restoration!
  161. Zetec Turbo
  162. Efi HT leads
  163. misfire!!!!!!!
  164. Looking for my old escort rs turbo B61AYA
  165. Enthusiast Wanted
  166. Turbo Heat shield
  167. Taking a ford racing gauge apart
  168. Saff RS Cosworth Splitter On S2 Front Bumper
  169. gas flowed throttle body
  170. Identifying Piston Type and engine mods...
  171. need help with rsturbo zetec
  172. best mod for escort rs turbo s1
  173. efi tps conversion
  174. Holding back
  175. window tinting yay or nay ????
  176. Zvh what oil?
  177. Team Dinamics vs Compomotive MO vs RFX?????
  178. Starting Problem, Help Please
  179. swirl pot
  180. Silly Question - Newman Solid lifters
  181. Is the AutoSpecialists Stainless cone filter any good?
  182. Underside restoration
  183. decals
  184. Amal Vave Help
  185. hellp
  186. what are these relays for..?
  187. poly bushes rs turbo rear set 30 quid
  188. fuel lines
  189. Coilover help..
  190. safety devises cage question?
  191. Mapping Question
  192. whistling/Whirling Noise from turbo!!!
  193. metering head xr3 - rs turbo
  194. Happy bunny
  195. handbrake switch..??
  196. Ford racing boost gauge (old style)
  197. forge actuator problem
  198. Rs turbo fuel pump wiring
  199. Best place to fit oil temp sender on rs turbo
  200. what gearbox oil should i use in my turbo's box???
  201. brake pipe picture please
  202. rolling road set up
  203. Rear ARB
  204. Wheel offset
  205. changing escort 1.6 si engine to 1.8 si engine?????
  206. Mounting bucket seats
  207. Bodykit weight
  208. MFI on track?
  209. Reverse Gear
  210. Load Sensing valves
  211. Metering unit
  212. Why cant i use a normal efi inlet iscv for anti-lag?
  213. ap clutches
  214. urgent help needed please please
  215. What boost??
  216. temp gauge problem
  217. Fuel for setup
  218. boost problem
  219. 6 Paddle clutch for my Series 2?
  220. front hub carrier
  221. scrap it or build?
  222. delocking bootlid?
  223. escort turbo boot lid problem
  224. Help needed Escort RS Turbo - Idle problem
  225. Differences between blocks
  226. is it usefull?
  227. is it usefull?
  228. help choosing brake setup
  229. series 2 electrical fault
  230. No brakes....
  231. Hi spec 4 pot 285mm front brake conversion kit worth buying?
  232. Amal valve on Ofab??
  233. Rev gauge wont work
  234. escort rs turbo series 2 really hard to start.
  235. ERST..... turbo relocation manifold
  236. MS vs Cossie Management
  237. escort turbo
  238. Wanted: T3 turbo water cooling pipes ?!?
  239. Help Needed... Water pipe..
  240. Help needed asap please!!!!
  241. S2 Rear load compensators
  242. Gearbox ib5 or mtx75 whats best??
  243. my car wont boost past 0 psi ????
  244. Arp conrod bolts
  245. Helllpppp unsure whats goin on ???
  246. moving fuse box - any pictures
  247. will et16 fit my s2 help just about to buy some wheels
  248. Megasquirt randomly going lean....
  249. what wheels for series1???
  250. efi conversion, is it poss to keep fuel computer?
