Rs turbo clutch allignment tool
11-07-2011, 08:07 PM
The posh are up!!!
where can i get one from? changing the clutch on my s2 in couple weeks time so need one very soon
11-07-2011, 08:36 PM
zetec turbo
dont need the tool just do it bye eye easy enough
11-07-2011, 08:55 PM
Any motor factors mate about ten quid
11-07-2011, 09:06 PM
st170 breaking
dont know why you would need one,
11-07-2011, 09:11 PM
competant bodger
as above just do it by eye its simples!
11-07-2011, 11:35 PM
I did mine at the weekend. Just lined it up by eye, then used a depth gauge against the flywheel in a few places to check it was near enough.
12-07-2011, 11:01 AM
Wye Valley Hardcore
As said, do it by eye. Changed loads of clutches without the need to use one. You'll soon work out if you get it right or worng when the gearbox won't go on
12-07-2011, 01:09 PM
Bodger of Blackburn
12mm deep socket fits through the splines, then just make sure that sits flat against the crank and hey presto, aligned.
12-07-2011, 01:40 PM
Quote:
Originally Posted by
xr2wishy
easy peasy thats the way to do it!
13-07-2011, 07:08 AM
As above on a short extension bar so you can wiggle it with the clutch nipped up to align it then tighten the clutch down and take the socket out... Or by eye, altho im never 100% confident in my own judgement, i always use the socket trick!
SmudgerByName
52
28-07-2016 06:14 PM
neil18
14-03-2016 01:08 PM
Matt Baxter
16-09-2015 08:30 PM
mint_s2
02-09-2015 08:58 AM
druidgetafix
15-08-2015 10:22 AM
