Help needed Escort RS Turbo - Idle problem
Hi everyone
I've got a problem with my turbo, it's in the garage at the moment but the mechanic can't work out the problem.
Originally my car wouldn't idle, the mechanic thought it was something to do with the fuel system so I have replaced the fuel metering unit. Now it will idle for around 5 mins before cutting out but then won't restart unless you press down on the plunger on the metering unit or wait until the engine gets cold again.
Has anyone got any ideas? I haven't had this problem before, I only use my car in summer, it was fine last year, over the winter I have fitted a Kent Cam and a KN panel filter but I can't see that being the problem......
if it was cold start valve i would say it would be a bugger to run, if your having to push the flap down i would say its to do with fuel pressure dropping off, did u change the pressure regulator when you changed the metering unit?
Zoggon
10-08-2015 10:39 AM
