View Full Version : Ford Escort RS Turbo
- Help needed asap plz!
- What Rims For My S2 ?
- no oil pressure impossible timing adjust...(BIG problem inside)
- rs turbo missfire when cold
- Torque settings
- the best inlet manifold debate now fact not fiction
- Plug leads keep melting on tubi manifold
- got it running but only when i hold flap down
- Tuned, or not tuned.....whats worth more?
- Indicator lights stuck on....HELP
- Problem with KE-Jetronic after engine rebuild
- can any 1 help me out
- Head bolts....
- Fuel cut off switch
- How do i get my RST Lower
- has anyone?
- My mate D4 rst recieved a call from...........
- Where to connect my turbo gauge vacuum tube>
- Need a couple of bits
- Baileys oil seperator
- 1.8 zvh
- rs turbo heat shield, hows it attached?
- how many d reg s2 are there left ?
- fans switch
- My Series 2
- Boost tailing off...
- didnt really need another RST!
- FAO anyone with a bolt in cage which sits in front of the dash...
- sensor identification
- abit of help needed
- s2 wpnt start after new fuel pump fitted! help
- why is my escort rs turbo engine blowing the oil filler cap off but wont suck ?
- Actautor Question. Which rod length?
- QUICK ANSWER NEEDED> Intercooler hose size?
- People that post clips to YouTube.....
- idleing issues doing my head in
- Pictures of boost gauges and possibly where you got them from?
- overheating
- Can't get a gear :(
- where to get fuel pump relay midlands?
- Does anybody know anything about S2 F843 MPB?
- Fuel pump relay controlled by ECU? which one?
- erst bottom end
- Air Filter confusion?!
- air charge sensor plug
- MFI to EFI sandwich plate any good?
- Xr3i efi looms?
- efi hunting
- Clutch help!!!!
- metering unit
- Show us your...steering wheels
- I'm Stupid
- turbo restrictor
- Buying a S2 Escort RS Turbo
- S2 Turbo Thermostat hell
- S1 bodykit on S2
- Right need a bit of help, pulling my finger out!
- 2 stage boost control
- some 1 help me on message blow
- ARP Rod bolts torque
- tailgate enquiry
- not starting plz help me out lads
- help turbo wont start!!!
- FAO anyone who has done the clutchpedal mod
- inter-coolers
- bottom pulley/ crankshaft pulley
- zetec head difference
- Speedo sender / Fuel sender.....
- my first rs turbo
- will series 1 steering wheel fit series2?
- turbo timer
- newbie
- Info Needed on Series 1 C637 BHV
- ignition barrel
- Lost my spark
- pedal box
- removing brake bar, and servo mounts?
- injectors
- Zetec Turbo Blacktop engine mount?
- Wiper motor plugs
- i no its been up a million times before but gearbox oil
- Whos done the IB5 swap?
- breaking s2!
- What gearbox oil??
- Engine rebuilds
- Does anyone have a boot lock with key?
- Megasquirt Settings?basemap for siemens deka
- S2 smoked rear lights...
- pace front mount intercooler fitting guide needed!
- Helix Sporting clutch! problems?
- had enough( knocking noise )1900 tall block(problem found)
- Any one seen this rs?
- road legal semi slick tyres
- Outlet Valve question
- Rust!..... Repair panel?
- Brake servo take off Boost leak...?
- Bonnet wont open
- V6 mondeo mk1 brakes on s2 turbo
- Boost Adjustment
- locking nuts on sterring rack
- Heat,water loss?
- how much is my 2.5 k mile engine worth want to sell ..
- S2 gearbox mounts?
- S1 and S2 exhaust manifold?
- Aftermarket Management Advice
- What turbo spec
- ppm hydrocarbons
- mk1 focus drive flanges into mk4 escort knuckles
- s1 bodykit screw covers
- Window Motors
- Brackets for 253mm rear disc conversion
- Mondeo caliper spacer kit
- where to get my rods shot peened in essex area?
- Who's running anti-lag?
- Cossie braided loom
- Do fuel accumulators have to mounted upright?
- steering wheel buttons
- Whats the best suspension for a s2?
- whats its worth?? koni SSK1 adjustable springs and shocks
- does your s2 have a boot switch?
- 4 pot calipers 2wd sierra cosworth
- fuel pump which one please?
- Chargecooler or intercooler?
- s1 custom v s1 non custom
- Whats the best poly bushes for a s2?
- S2 RST brake servo spec needed
- Zvh
- loud ticking noise
- heater vent boost gauge??
- Does any one know what this wiring is for?
- 888 sya - h595 mpe
- HELP i need All engine sensor's!!!
- Anyone know the thread sizes for an MFI Fuel Accumulator
- locking problem....
- Whats your RS mean to you.........
- stage 3 big valve head what do you think?
- zetec turbo help, one problem solved, now another-with video
- help plz lads
- Relocating battery to boot
- FRST IAT sensor
- remove the ALB
- anyone run pro race 1.2's on there escort?
- pict of you air filters - EFI peeps
- not runinng propley
- Series 2 lowered 60mm and MOT brake rollers
- How to setup co2 without a gas analyser!
- S1 problem running when i get hot, Help PLz
- Suspension springs.
- rear discs on a S2
- where to buy?
- is anybody actually buying rst's anymore??
- Meter Unit help. PLZ
- Omex features..
- cone filter or standard air box
- pics of xr3i/rs16i inlets
- Anyone know where these loom plugs are for?
- urgent help please!!!
- in line restrictor, where from??
- steering column repair
- Turbo leaking oil
- Rods
- Pics of your oil catch tanks please
- Parts needed for hydraulic clutch pedal?
- Omex management
- carbon roof skin?
- roof skin
- Alloy Products!
- Inner Roof Rotten
- how much paint??????
- FAO people running focus rs brembo's on ERST
- Carbon door handles
- Re-Fitting roof lining
- front splitter
- any one know where this car is
- standard cvh power
- 250hp zetect turbo
- Headlining Needed!!
- s2 front arch fixings??
- electric windows not working..
- S2 gearbox crossmember
- adjustable track rod ends
- cvh head 16v?
- Escort First Start After Rebuild
- Amal Valve Test
- moved to the darkside
- Possible engine damage?? Help..
- Gearbox Mounts
- will not boost
- C637 BHV s1 rst
- Cages and seats
- Anyone got a broken gearbox?
- Which Clutch.
- S2 breathing really heavily
- clutch issues
- Clutch problem.
- Is alternator same on S1 & S2?
- Valuation please.
- Rst vs 328 sport
- help with fuses
- Escort RS Turbo ABS relay.......
- Magnecor 8mm leads
- gearbox
- windscreen washer motor/fuse
- replacement panel
- Show us your Escort RS Turbo track cars
- rear arb pics if you will
- boost gauge
- 4 Pots
- t3 turbo
- 1860 cvh. will she hold out?
- Just when I thought it was fixed!!
- Idea? Escos bonnet vents in S2 bonnet?
- Manual Boost Controllers...
- MK3/MK4 tailgate...
- springs
- Might be of interest...
- Engine bay decal kits Escort RS
- help needed with starting ?
- Abs on S2 RST
- fuel computer ?
- how much POWER with an orignial VALEO ,LUK,..clutch
- Heat wrapping
- zvh conversion
- Megasquirt settings for Greys
- power
- you lot are all...........
- Number Plate Relocation
- gearbox oil
- Venting to atmos now smoking
- speedo cable
- Non Custom Series 2's
- series 2 escort rs turbo arches
- Escort RS Turbo running problem
- rs turbo 202bhp?
- A/R 42 turbo ?? what is it off
- Are mk3 doors same as mk4?
- MFI set up
- wheel spacers
- door catches, fitting central locking
- Stage 3 T3 (0.48/50)
- Fuel pump relay on Series1
- Should my turbo need a gasket ?
- strut brac on efi s2
- HELP AE piston rings???? wtf do i do with these!
- diamond cuts
- Post up your rollcages.
- Ap 6pots on S2??
- Boost all over the place...
- why cant i find a deecnt s1 passenger front arch ?
- Rear Headrest conversion
