PDA
View Full Version : Ford Escort RS Turbo
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 [93] 94 95 96 97 98 99 100 101 102 103 104 105 106 107
  1. zvh cosy mangement or 5th injector
  2. series 1 Brakes
  3. What is this?
  4. Rattly after oil change!?
  5. "what does an rs turbo weight"
  6. rst lifter tapping???????????????????????????
  7. Hot ERST
  8. exhaust rubber - what one?
  9. took my d/v of, i need louder flutter, how?
  10. Fuel consumption on ERST
  11. mk4 xr3i
  12. what wheels fit my van............
  13. Bubbly roof
  14. help needed
  15. s1 ecu question...
  16. running like a pos
  17. S2 Standard Hoses??
  18. Vibrating Clutch Pedal?
  19. 1.9 engines
  20. im new here, heres some pics of my RST
  21. right question for all u experienced people with S2`s
  22. Pics Of My Rs
  23. S2 into MK4 combi?
  24. Fitting fuel pump carrier....
  25. engine hunting on warm up
  26. Pics of me new S2 Escort RS Turbo
  27. rst holding back on boost pissed of yet another problem
  28. anyone know of this car?? and help on low comp bottom end
  29. brakes ? mk4 xr3i same as s2 ?
  30. ADVISE ON WHAT SHAFTS ARE REQUIRED WHEN FITTING A MTX75 BOX
  31. How heavy...
  32. Fuel pump problem
  33. Sold my rst, well nearly, :-(
  34. i bought another RST *PICS UP*
  35. not another !!!!!!
  36. zvh de-comp bonding stuff?!?!?!
  37. RS Turbo Crank & Conrods
  38. got some new goodies for my car what sort of power
  39. head lights
  40. back fire
  41. ariel on a series 1?
  42. Still over heating!
  43. rear load valves
  44. acceleration and traction peoblem, help
  45. HOW DO U TEST A THROTTLE POSITION SENSER?
  46. LOOKING FOR RS SHELL
  47. replacing a heater matrix
  48. Escort RST Starter
  49. What oil?
  50. ERST fuel tanks..
  51. Help! S2 over heating!
  52. shades of mercury grey
  53. Presure actuator
  54. ANY IDEAS
  55. soon to be a s2 owner cant wait !insurance????
  56. Major help needed !
  57. SERIES 2 LOG ANYONE???
  58. what year did you get your 1st rst
  59. Handy tip for all you with rotten sunroofs!!
  60. My first RS
  61. RST Doors.
  62. Help needed with rst van
  63. form 1.6er to 1.8er cvh turbo
  64. noise after boost??
  65. Help! water is pissing out of the head!
  66. Brakes!
  67. RS won't start?
  68. Fiesta turbo Managment
  69. Ignition leads and spark plugs..
  70. whats the best 5th injector to run on the escort rs turbo
  71. paint
  72. Breather Pics
  73. Stripping the RS....pics
  74. How much is my car worth??
  75. just bought a big valve head uprated cam or standard
  76. new black s2
  77. new S2
  78. cossie 2wd IC in s2
  79. air filter/induction kit
  80. Brake Conversion,help required?
  81. Try to Find an Old Family Car - RS Turbo.
  82. Turbo's
  83. knock sensor
  84. perfect boost weather
  85. moving heater controls .......
  86. amal valve
  87. Help! S2 keeps cutting out
  88. tapping
  89. Engine setup and bhp
  90. Blended in bodykit
  91. 200bhp S2? What do you think?
  92. New filter fitted (loads cool air now)
  93. My series 2 turbo not running right !! help!!
  94. Gearbox going?
  95. Wiring EFI to S2
  96. check this out for a fiver ...
  97. No Compression on number 3 cylinder
  98. polishing grs ic
  99. How Much work is involved?
  100. boost
  101. need new head gasket are burton power any good
  102. Quick question
  103. diesel gearboxes do they fit series 1 ?
  104. Uprated clutch cable??
  105. KE-Jetronic Fuelling Mods
  106. Blocked oil way
  107. low comp plates for zetecs ???
  108. quick piccy of a combi
  109. windows and seals
  110. Dump Valves, cool or not?
  111. 2.o conversion??
  112. WHAT BEST PISTONS FOR 2L ZVH JUST MELTED No4 2day
  113. Anybody fit a pedal box too there RS Turbo
  114. cvh engine capable of 250-300bhp
  115. cvh engine head
  116. water temp sensor playing up
  117. Inlet maniold wiring plugs help needed asap
  118. Fuel in metering unit, but not down injectors*PROGRESS PICS
  119. ACT gauge sensor fitment
  120. am i allowed?
  121. ECU colour codes
  122. Heat up/cool down
  123. electrics
  124. turbo head valves are they the same as xr3i
  125. s2 standard header tank and brake fluid resevoir-from ford?
  126. help someone please
  127. rs turbo cabs
  128. NEW MOT TEST!
  129. 1.9 bottom end
  130. lots of turbo lag when hot
  131. wiring plug colour of idle speed control valve?
  132. Brakes
  133. S2 RUNNING HOT WITH PRO ALOY COOLER FITTED????
  134. whats the problem?
  135. taking off air box
  136. T28 on ERST?
  137. S2 Slow Windows
  138. Carbon fibre door cards
  139. ford escort rs turbo series1 (custom)
  140. DISCS
  141. Number plates
  142. Anyone running a std cam?
  143. What cam do i have? **TS 0530 DC**
  144. Whats the widest tyre i can fit to my RST
  145. ERST on koni's and 17's
  146. S2 Underside Restoration?
  147. Some buying advice for a newbie.
  148. tuners near fife
  149. Roll cages
  150. oil cooler rad
  151. Changing S1 radiator.
  152. Carbon fibre pannelling? Flocked dash? Perspex windows?
  153. Over heating
  154. wots the best oil to use
  155. oil return pipe
  156. classic insurance on my s1
  157. How low should a low comp engine be?
  158. diesel gearbox?
  159. power upgrade
  160. oil leak...
  161. RIGHT WHAT TO DO NEXT !!!!
  162. Turbo Upgrade
  163. what turbo have i got then ?
  164. New (used) T3 stage 2 turbo??
  165. TURBO HELP
  166. HELP! UPDATE: FUEL THERE, STILL NO GO!
  167. Superchip damaged?
  168. General Running Problems
  169. quick rs turbo spring question
  170. Rev gauge!
  171. What turbo will fit my Mk4 Rs turbo
  172. S2 bush sizes!
  173. my brothers first rs
  174. boost drop
  175. suspension setup 4 your series 2?
  176. What wheels do u have on your white rs series 2 turbos?
  177. Powerflex polybushes!
  178. Please help my heap of shite
  179. Intercooler fitted now lost power!
  180. How often do you use your ERST
  181. Tail gate problems
  182. Anybody who come in here regurally,going 2 santapod next sat
  183. cvh block bore
  184. what polyflex bushes do i need then............
  185. Simple really, Series 1 or Series 2?
  186. whats needed to make a s2 stable when coming out of a corner
  187. Best make for lowering springs?
  188. Romoving starter motor
  189. electrical oil gauges
  190. Bonnet vents...how much?
  191. EXPERTS
  192. power expectations
  193. zvh compression question
  194. brembos under escort cossie wheels? mk4?
  195. T28 TURBO
  196. boost ecu
  197. Nomad center vent gauge panal...
  198. Ignition cut out & backfire
  199. bad idle???
  200. floods itself
  201. ABS Pipes
  202. alternator light
  203. S1 problem.
  204. dashloggers
  205. RST Headgasket Step-By-Step Guide
  206. oil leak...but where from?
  207. zetec turbo compession ratio
  208. tracktion
  209. HELP.... MY HEATING IN MY S2 DONT UNDERSTAND COLD
  210. Boost problem
  211. S2 panels
  212. S2 Brake Upgrade
  213. sump gasket, any make good enough ??
  214. changing the mileage...?
  215. 4x4 loom is always live , what wire is..........
  216. Series One Picture Database
  217. is head skimed
  218. Adjustable suspension settings
  219. t28 turbo for a escort
  220. Gotech MFi Std ECU
  221. rs power
  222. winter project
  223. Are ERST Callipers the same as FRST Callipers?
  224. Someone with rs knowledge help !
  225. DATA POST RS TURBO PRINT
  226. i Cant reverse, gearbox problem? pleaseNO!
  227. BREAK IN - PLEASE HELP
  228. RS Breakers
  229. red springs on my car
  230. biggest alt on a mk 4 is?
  231. Cylinder Head Developments
  232. What could this strange noise be??
  233. Calling all the ZVH Gods..
  234. Mk5 escort 1,6 cvh efi engine any good?
  235. is this for real??????????
  236. 2wd brakes on an escort
  237. bare metal respray
  238. Testing compression
  239. where are ur switches and what type are they??
  240. Do S2 rear drums fit S1
  241. how many places can an rs turbo engine leak oil from
  242. calipers
  243. hmmmmm!
  244. Did ford make a mk5 escort with a rev counter and a dizzy???
  245. Samcos
  246. whats up with this S1
  247. S2 rst - Temperature???
  248. Best suspension setup on RST???
  249. Knocking&clicking
  250. Alternator
