rst holding back on boost pissed of yet another problem
hi i have yet another problem with my rs runs lovely apart from when i come on boost it will start to lift of then just go flat make alot of noise and not realy go no where.could spark plug gap caues this or faulty spark plugs them selves it does not back fire just goes flat starting to get pissed of now as every day it seems to have a new problem i have spent out on group a coil group a 10mm leads cossie plugs(which i havent fitted as icant get the car to run propaly on them)has anyone got any ideas would be very greatfull
sounds like need a new cam as mine does this got get round to fitting new one as one of the lobes on cam is worn very bad it broke a tappet ive replaced it and it works for now.
jon
jon
thanks for that jon i did suspect that but trying ta kid my self as thats another Ł200 ive got to find but if thats what it is ill have to do it any way thanks for your help
just spoke to a friend has got a piper cam i can have with about 2000 miles on it will fit and see if it is any better as i have a sx428t cam in at the mo and want another one of those cams as i have been told the piper cams can make the car lagey dont know how true this is but im sure ill find out
![Banana](https://passionford.com/forum/images/smilies/banana_dance.gif)
Originally Posted by Combi_Chris
speaking of cams , what rev range is the cvh35 best at ?
Mine does this and ive just fitted a new std cam
Im thinking my turbo to metering head hose is collapsing under load??
as its ok if i dont give it full throttle worth thinking about.?
i seem to have the same problem with mine, dont think its the cam! mine is new, got samco's, Could it be the actuator or the amal valve maybe?
i have the same problem some times it seems as the turbo doesent want to spin up.im hoping that new hoses will sort it as it is going in ea for a set up saturday
I had a problem with the standard boost hose collapsing, normally at high revs (5K+).
Sussed it out on the rolling road with one of the guys holding it while they ran the car up
Silicone has solved it
Cheers,
Marc.
Incidentally i replaced my cam last year with a Kent CVH35 and i think i prefer my old 90 thousand mile standard jobbie...
Seem to have to ring its neck a lot more nowadays for the same effect, standard cam has much more midrange (Useful)...
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
![Smokin](https://passionford.com/forum/images/smilies/icon_smokin.gif)
Cheers,
Marc.
i have another small pob it might be linked, when u switch of engine it will shut down then about 3 seconds later will pop out of the exhaust i have been told that it could be leaking injecters if so could they not be faulty and spraying incorrect patern.ithink ill have to spend weekend swapping and changing bits around and see if i can solve it that way trial and error and thats long
Escort Rs Turbo
ive got "EXACTLY" the same problem mate
i was thinking it might be a ECU problem
if i bring the power on slowly it seems to go better than when i just floor it duz your's do this to???? let us know how you get on with it
yeh mate thats the same as mine starting to realy piss me off ![Wall](https://passionford.com/forum/images/smilies/wall.gif)
ive got a spare chipped and non chipped ecu ill try that first as its prittey easy but i plan to change injecters metering head ecu and cam 1 by 1 at the weekend as ive got all that spare and its got to be one of them ill let u know how i get on cus im desperate to get it back to the flyin machine she is
Escort Rs Turbo
i dont think it would be the cam as i had a new one not that long ago
i think it's a fuel side problem
let us know how you get on mate as it would be nice to get this fooking problem sorted as it's REALY PISSIN me off to
cannot beleve it !changed the spark plugs and the car is ten times better still not 100 % but a great impovement have got a set of new injecters coming as spoke to a guy he told me that i should realy put a set of injecters in it as they arnt that good after about 60,000 miles and i dont now how old the ones in my car are ,i have tried pushing the plunger on the metering head and it seems to have a bit of pressure when pushed down so ill change the injecters any way as thats another new part and eliminates them got them from euro car parts Ł80 trade witch ant to bad thanks for your help
My mates van had the exact same problem till today when another mate of mine who works for ford fixed it... the timing on the distributor was out. If you havent cheked that already it would be the first thing i would do
ive solved my problem today, i seemed to have the same problem with the boost and it boggin down
, ive just replaced the actuator and adjusted it up, now i cant keep the car in a straight line!
Originally Posted by sam wyatt
My mates van had the exact same problem till today when another mate of mine who works for ford fixed it... the timing on the distributor was out. If you havent cheked that already it would be the first thing i would do ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
Escort Rs Turbo
Escort Rs Turbo
Originally Posted by parky1984
will mine be the same then it happens more when it gets warm
well mines not boosting atall, unless im not in gear and just revving it(well the dumpvalve works then.)
ive been told its the actuator, my question is, what actuator does a standard rs turbo have?
CabrioTurbo
01-08-2015 11:04 AM
