PDA
View Full Version : Ford Escort RS Turbo
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 [67] 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107
  1. sierra 1800 36-1 triggerwheel mod
  2. RS calipers
  3. car mot'd
  4. beiges not good enough on efi will these do
  5. Relacing the cam seal (S1)
  6. MOT TODAY
  7. Which brackets for S1 spotlights?
  8. Racing of The Line
  9. oil leaking from end of cam....HELP
  10. does s1 suspension fit s2 and vice vercer?
  11. MOT today ... Passed!
  12. Offsets and Widths
  13. zetec turbo internals question
  14. port matching...
  15. Bearings
  16. turbo
  17. air tec intercooler
  18. Rear Suspension Arms
  19. s2 help!! bubbling header tank
  20. Does anybody know the PCD of.......
  21. Wing rubbers
  22. Setting actuator for running in engine
  23. sierra bottom pulley,does this look right???
  24. Brake Proportioning Valve?
  25. fuel wont go in!
  26. Replacing the rad
  27. side repeters
  28. Starting in the morning
  29. oh shit
  30. Standard camshaft
  31. Recaro Retrim?
  32. IS IT POSSIBLE TO FIT ET 20 RIMS
  33. Red S2
  34. Another begging wanker thread - pledge money now !
  35. S2 HELP needed with anoying problem
  36. air leak
  37. Quickshift
  38. Dogbox
  39. sockets ?
  40. S2 Suspension
  41. Zetec rocker covers interchangable ?
  42. £10
  43. efi on a s1 rev counter
  44. s2 overheating help??
  45. How to take off s2 erst rad??
  46. £1
  47. Focus RS discs on S2 RS Turbo.....
  48. fifth injector
  49. efi conversion
  50. Diamond Cutting
  51. manifold with external wastegate help
  52. which colour, year and interior would you want??
  53. intercooler?
  54. Distributor 4 S1 & S2
  55. whats it worth
  56. 300bhp escort on rollers
  57. How much is a series 1 rolling shell worth ?
  58. Steering wheel boss
  59. head back on, problems persist...
  60. Pics of Series 1 with soft 7 spokes
  61. Aeroquip fittings for the fuel system on efi conversion
  62. Tyre Test Site
  63. felpro, is it reuseable
  64. S2 amber front indicators
  65. new alternater
  66. Turbo adaptor
  67. Thank you BMW
  68. S2 Jacking points/axle stand locations
  69. bumper brackets
  70. 240 bhp @ wheels
  71. Aftermarket parts
  72. heatshield on a S2
  73. S2 under 200bhp
  74. Fan over ride switch
  75. help needed
  76. head gasket
  77. S1 cooling fan & reverse lights problem? Any ideas??
  78. RST Nitrous install help?
  79. Ford erst clutch
  80. More help needed with RShitty Turbo :cry:
  81. FRST charge carrier...
  82. Adjustment Kent Cam
  83. info
  84. Fuel Gauge Needle
  85. S2 Wont start when hot
  86. Twin headlights
  87. Shocking....
  88. MFI
  89. A couple of power questions
  90. Lifted my carpet...
  91. dump valve problem
  92. S1 white/ amber indicators
  93. cam belt??????
  94. Zetec cosworth piston
  95. t3 turbo smoking
  96. Car covers.. what you use...
  97. 88 or 90 spec interieur?
  98. 90spec chip in s1 ecu
  99. Insurance
  100. oil pressure switch and speed sensor for an efi conversion
  101. Brake set up
  102. Putting a second rs lump in the back...
  103. Crank position sensor??
  104. RSTs, trackdays, chassis tuning, understeer and such
  105. S2 Slam Panel!
  106. any 1 no g870 gcl
  107. bleed valve
  108. s1 or s2
  109. non lsd box
  110. What injectors fit a rover 220 turbo inlet manifold
  111. alloy fitment
  112. injector
  113. EFI CONVERSION INTO S2
  114. BRAND NEW ESCORT RS TURBO SPOTS ON EBAY
  115. cossie powered s1
  116. Turbo on Diesel
  117. What is the good turbo on the 1,8 ZVH?
  118. gearbox
  119. fao tony at mef
  120. Buying Paint
  121. Escort rear bushes
  122. What floor mats do people have???
  123. management
  124. mocal petrol filler cap
  125. does anyone how to set roof clock?
  126. S2 Non runner!
  127. hp question
  128. fuel sender finis code?
  129. Colour of s2 please?
  130. s1 spotlights ford/carrello
  131. car back on the road after my diesel incident!!!!
  132. 205 mi16
  133. efi on a s2
  134. S1 petrol
  135. Knock Knock
  136. Mk3 Escort A Pillar 2 Gauge Pods Holders....
  137. Engine hunting
  138. distributor
  139. finally SORTED
  140. What gearbox oil???
  141. nomad 3 gauge holder
  142. s1 fuel pump/relay
  143. Bit of help valuing an RST please
  144. head gasket
  145. air fuel mixture on efi xr3i
  146. passenger side driveshaft
  147. MOT Question
  148. Head Gasket...
  149. how do i know if i have a lsd gearbox
  150. 5th injection...
  151. ebay just gets better
  152. caliper
  153. Has anyone seen these ?
  154. I HATE CARS
  155. 071C Spark Plug Gap????
  156. steering wheel boss
  157. Strut Brace Fitment.
  158. QUICK QUESTION how much oil?
  159. plugs
  160. s1 gear linkage
  161. How much zetec standard con rods can take power?
  162. rs turbo ecu
  163. dump valve woes
  164. Battery Wires
  165. seals
  166. help ,no rev counter!!
  167. Urgent - Where to get some bits from
  168. Your choice of turbo for a zetec ?
  169. Turbo Re-Build kits ?
  170. Fuel Pump Relay Issue
  171. brakes
  172. my £250 rs turbo (bargin)
  173. s1, s2 ecu
  174. camshafts
  175. New ford suggestions, 16v and fuel computer...
  176. Oil pressure switch?
  177. Standard piston/deck height
  178. Tapping noise from engine.
  179. what screw adjusts the idle on a s2
  180. s1 turbo paint shop newcastle area
  181. Starter motor
  182. pics of diamond
  183. S2 RST wiring - help diagrams?
  184. finis code request
  185. Best Polishing Kit
  186. setting timing
  187. Rs1600i turbo
  188. Escort fuel computer
  189. found sum engine block paint (pics)
  190. a noise when i accelerate
  191. can you still get the disch.fuel line from the fuel pump ?
  192. EFi inlet manifold studs
  193. re built bottom end, stiff to crank
  194. FOA safechav
  195. 3 pod gauge holder, maybe a stupid question but...
  196. will my car be ok...?
  197. "O" rings
  198. 15w 40w semi sinthetic oil
  199. servicing
  200. Ebay bargin
  201. clutch size
  202. stickers for dash buttons?
  203. rs turbo problem
  204. Brake master cylinder EAK!
  205. erst on sharktooths (4x4cos rims)
  206. s2 badges
  207. what temp does your erst run on the guage?
  208. Boost hose kits (Roose Motorsport)
  209. s1 turbo fuel pump priming problem?
  210. distributor to coil pack question
  211. EFI trigger wheel conversion, which alternator belt?
  212. valve guides
  213. Correct or Not?
  214. fitted boost gauge today....
  215. Overhead light and Clock
  216. amal valve
  217. s2 gearbox
  218. clutch rachet
  219. Backbox
  220. s2 head
  221. Lowering Spring Sizes
  222. still no life
  223. Turbo upgrade...
  224. anti roll bar bushes,, what size
  225. s1 turbo stereo/indicators
  226. MFI uprated injectors?
  227. has any one built an rs turbo van
  228. Low compression valves
  229. will not start when warm
  230. t34 turbo conversion erst
  231. engine specialists in the west mids (wolverhampton)
  232. Help, loosing coolant again, PIC
  233. Fuel pipe
  234. What connects here? MFI picture identification,this right?
  235. urgent question about chipped ecu's. only got 3 hours left..
  236. Spark Plug
  237. low compression headgaskets?
  238. compression
  239. help s2 wont start
  240. S1 Fuel Relay
  241. Mk3 Cabriolet Front Speaker Size..
  242. Gaugepod replacing center vents...
  243. roof skin
  244. Can Someone Help!!!
  245. Load Apportioning Valves
  246. piston rings need done?
  247. Head gasket help please ?
  248. Piston identification
  249. Piston identification
  250. drive shafts?
