- which head gasket????
- need rs turbo diagnostics
- any one got morette lights on their s2?
- series1 clutch bearing
- hissing from metering unit
- Air Injectors?
- HELP! Rattle noise,What is it?
- set up at jamsport
- cheap brake upgrade, i know its been asked before!!!
- rs bonnet needed asap
- **updated**no juice 2 injectors
- Alternator help please
- whinin noise
- ?? Cigarette Lighter wiring ??
- series 1 rs turbo brakes
- Do i still need these when going EFI
- shocked
- any one know where to get cheap bearing sets..?
- Tappets on S2 Rs Turbo
- manual fan switch
- Megasquit base map for RST
- big end bearings goosed!!
- just joined
- wont start
- Woodruff Key needed
- Rs Turbo Conversion
- Brake pipe diameter
- suspension
- fog lights
- my fuel pump prime sounds weak/non runnin rs
- torque setting for the front hub nut..
- What injector?
- ajustable suspension
- High pitch buzz on boost!??
- Lads and lasses
- fiesta rst rad fit a escort s2
- Speakers
- MFI XR3I Mk4 to MFI RS Turbo Engine
- S1 Parcel shelf colour
- Anti roll bar
- Morette headlights new indicators required
- cosworth manangment
- Where to get s1 tie bars???
- ZVH finaly started
- 3 way bleed walve
- Are cossie brakes on a s2 really much better?
- fiesta ecu on mfi? will it work?
- RS Turbo headlights not working !!!
- high volume oil pump
- Advice please
- Whats involved, s2mfi to fez efi conv
- stainless manifold
- missing !!!!!!!
- efi or mfi??
- fans not workin?
- interior
- zvh in escort
- concours s1
- fuel pump
- Tony Turbo's fan club
- rs not firing
- mahle forged pistons..
- air leak?
- rs turbo series 1 engine problem
- Brake pipe clips!!
- what cam
- New Engine what can a safely expect to push BHP wise?
- What are the best rims on a black S2?
- tyre sizes again !!
- Factory RS Turbo Fuel Computer
- replacement flywheel
- adjustable TCAs
- rs turbo colour change
- heated windscreen
- Front link kit?
- Poorly running RST...
- easiest way for efi
- What size tyres do people with 16s have?
- what a nightmare
- rear disc bias valve
- diagnostics ecu 3 pins ??
- siemens vs bosch....
- i really need help quick
- full s1 kit inc bumpers+ lower skirt on mk4?
- putting rst clocks into a basemodel...
- Please help, summers coming!!
- Big up to Reyland!
- Vacuum hoses
- Starter motor problem
- front mount fitting
- S2 underbody cleanup
- alloy rad
- what sends the signal to the metering unit?
- S2 Escort- Can you use a MK5/6 master cylinder?
- b&m quickshift
- puma gear linkage?
- best rims for grey rs turbo
- NEW ROOF
- recaro fabric
- silicone hoses
- advice please.
- exhaust manifold
- show me you gauges
- Polyurethane help needed!
- escort se cabs
- Does an MFi Series2 really need a D/V?
- is there any hot girls with rst's....show your selfs
- wanted s1 rs turbo
- gotech engine management for RS TURBO
- adjustable track arms
- 5th injector
- smokin
- Imported Series 1
- Pistons?
- Series 1 Windscreen
- series 1 and series 2 windscreens
- rallytech?
- Heater hoses
- standard inlet
- bottom end And BigEnd's
- What power how much boost
- B692 Ffm Series 1 Rs Turbo Any Info On This Shell Thanks
- front whell bearin knocking noise?
- brake problem
- manifold gasket and stud kit?
- **pic request** acumilator
- gotech help needed
- S1 Front Suspension.
- Series 1 MOT failure
- Reshell or Not?
- just a couple of questions
- escort rs turbo s1 wanted
- Boost Guage Help Please
- drive shaft
- Slim line fan
- F**king Police!!!!!
- Rs Turbo Revival
- Wat psi should they be running?
- newman cam
- naff brakes
- are all 1.8 and 2.0 zetec cranks the same..?
- turbo oil feed
- puma gear linkage
- finnis code for rst clutch release bearingcan some1 confirm?
- swopping gearbox casings
- help
- Escort rst s2 piping? help required asap
- Rs Turbo On Anthracite Rims
- is a rs turbo fuel pump same as xr3i?
- where can i find a full rs turbo loom
- MK3 Fiesta wilwoods on s2 Escort RST HELP!
- (Screamer pipe) F.A.O Christian
- check these
- Rs Turbo 1600 elp :(
- Car will not start!!
- stickin rev counter
- metering unit gaskets
- metering uit gaskets
- grindin/ rattle noise? series 2
- Replace orig. ECU with Gotech unit
- turbo shell
- all steel cvh bottom end ?
- airtec frontmounted intercooler
- alternator wiring diagram or info/
- cossie fuel pump on series 2?
- bouncing revs
- closed loop
- how hard to do rear archs.
- oil pressure problem
- Fith injector fitting
- Inlet Hissing?
- S2 Bottom End.
- rolling road results
- RS Turbo B&M Shifters......Eeeeeek.
- anybody got any knackered s2 mirrors about ?
- s2 wheel off set
- Opinions Please
- Raced A Subaru!! Guess Wat Happend
- Intercooler and Rad wanted Plus other prts
- trip comp ?
- my car is smoking?
- White Dials
- 270bhp jackass
- hydraulic tappets
- Fan wires
- rst cts box wanted
- What colour?????
- finis code please?
- oil light switch
- mercurygreyrsturbo any one now this member ?
- Brake problem
- anyone got a fiesta turbo head they want to sell
- turbo over heating please help
- Help abs for my mot
- hids or angel lights
- getting my bushes done on my erst
- gear box leaking
- will a series 2 gearbox fit a series 1
- series1 cts stage2+ gearbox
- dump valve or external waste gate
- best exaust system
- Track Car using my Rs turbo.
- S2 fuel pump (pink?) relay
- Exhaust probs?
- sparktable
- set of bonnet raiser?
- cossy 4x4 intercooler in a series 1
- Which is better ?????
- Intercooler for my setup
- Just booked the car in............
- st24 brakes
- plug gap
- help please.
- st 170 gearbox
- What was this from??
- springs
- help me
- ticking noice please help
- please help!
- Fiesta RS Turbo Springs and shocks
- Wont start when hot
- con rod bolt tightness on a zetec bttom end ??
- Series 1 carbon???
- Show us your aftermarket rims !
- Yellow Relay Under Dash
- mahle pistons?
- ERST won't start. Have fuel and spark
- remove ABL
- my new engine build what u think
- New Spoiler
- Idle Problem
- leak help...pics
- Rs turbo series 2
- wich is best calliper
- rollcage
- help please battery
- boosting up problems.....
- Tyres
- k.m.s management
- ecu chip
- s1 to cossie or not to cossie
- ECU HELP
- what to do engine wise
- heatwrap and manifolds...
- S2 spotlights
- Escort MK 4 1990 Spec RS Turbo rear lights.
- Boost Controller
- Wheel size/offset for S1?
- 17's on a mk4 with a 60mm drop
- stereo
