gotech engine management for RS TURBO
Any thoughts on it and the quality of the system itself?
whats kind of injectors can u run?
for escort rs turbo?
would it be better than cossie management or better to use gotech as its newer?
any opinions and thoughts greatly received
cheeRS
cheeRS
my mates had it fitted at jamsport think he is running light blues t34 running 280 + bhp and its on a 1900 bottom end jamsport head,cams etc its a great bit of kit. its a leathal weapon
Ive got it on my escort mk3 with st170 engine, its good because u can run any thing with it, n/a or turbo etc. Its just mapping that costs u a bit...
got it on my rs turbo just havin a few probs with cold start at mo,maxed my injectors out at half throttle so swappin them for cossy greens next week then a re-map
management is only as good as the mapper, I would suggest finding who you wish to map your car and then take advise of them regarding what they are experienced with and would use.
I run cossie management with a brand new loom (Ryan Loom), a new coilpack, new injectors, and new sensors.. ohh and a second hand ecu,
I choose to do so as i felt the fact that the ecu was enough to power a high powered cossie it would be good enough for my CVH, and the fact that the fastest Escorts in the UK run cossie management suggests it is still up to the job
I like the fact that many people across the country can map it, if your 200 miles away from the specialist who maps your system, getting to him on a trailer can add to the costs should anything co wrong.
Another thing which effected my choice was that I wanted to run coil pack for a stronger spark rather than a worn old distributor, I also wanted to run water injection and air injectors. When you attempt to find another ECU with all these features for the price of a second hand cossie ecu you are hard pushed imho (well you were when I got mine)
But like I said, find your preferred mapper and then use what he is most experienced with
powered by K26
ive got gotech ready for my rst powerd van, although its still in the box at the mo, ill get round to fitting it when ive got time!
simon@sitech runs his escort on gotech proX and believe my it works very very well!!!!!!
Stu @ M Developments
41
21-08-2015 06:47 AM
