Rs Turbo 1600 elp :(
Ok This is How it Goes Y Does my Escort rs 1600 turbo sound like a diseal van wen i booot it ???? 1st gear sounds like a transit van then 2nd 3rd an 4th alll run sweeet as a but soooon as thay get to 4000 reves its sounds like a transit van boooting it any elp please
standard leads an plugs bin on car 4 a while now its bin bugging me 4 couple weeks its just sounds so horrible in first gear its imbrassing but every gear pulls like animal till it gets to 4000 revs like i said then sounds like some driving a diseal van
pinking is detonation, on a turbo car caused by wrong AFR, normal cars normally timing out, yours could be a combination of both.
now to me pinking dont sound like a diesel it sounds more like a mettalic sound, thats why didnt suggest it
![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
Don't mention ze Vor
I wish 1.6 CVHs would run as smooth as a modern Transit Diesel...
Either it's pinking/detonating or there's something wrong in the cylinder head. (Rocker arm broken/loose?, hydraulic tappets leaking? camshaft worn?)
i am having the same problem m8 but my oil light is also flickering on and off on idle i was thinkin down the lines off changin the oil pump and a new set of lifters ...... will any1 no if this will solve my problem because my timing is spot on
Don't drive it like that or it'll be f'cked in no time...
What you probably hear is the cylinder head running without lubrication and wrong valve clearance since the tappets don't get enough oil.
Has it been off the road for quite some time before it started losing oil pressure? So far I've had two RST's with bad oil pressure due to a blocked up oil cooler (the thing thats between engine block and oil filter).
JK12
33
26-04-2021 12:09 PM
