View Full Version : Ford Escort RS Turbo
- uprated/aftermarket efi fuel pressure regs?
- Efi how to calm the chatter
- IB5 gearbox
- whats peoples tohughts of this
- Gas flowed throttle body
- Central locking help please
- bosch 701 equivelant?
- s2 water temp when driving?
- Turbo block
- Drive shaft oil seals
- gearbox thrust washer broken
- What offset wheels ??
- PArts
- Gearbox limit on a s2?
- Rst cutting out
- engine rebuild tips?
- Has my head gasket gone?
- Adjusting wheel offset
- Block seal
- oil pump help needed
- mk4 bootlid carbon or glassfibre
- softer suspension? what makes?
- ZT exhaust manifold options?
- Burton Oil pumps for RS Turbo
- sunroof??
- Misfiring on full boost
- gearbox on s2 leaking oil
- S2 Wont start???
- fitting a replacement turbo
- S2 internal fuel pump
- Urgently Need A CVH Crank Sprocket.. Anyone Got A Spare Lying Around??
- oil pressure on idle?
- 2007 stereo loom wanted?
- rs turbo wireing
- Coilovers fitted brakes banging
- Dodgy temp sender or fans kick in too early
- Selling The RS..
- this engine make me crazy
- overheating!
- Megasquirt injector dead time guide, pic heavy
- Map sensor signal reading?
- possible driveshaft sticking?
- Rs Turbo Head bolts
- oil feed connector question!!
- running lean on boost.
- using st170 pistons with det marks
- Alternator wiring?
- Escort RS Turbo Injector Line Banjo Bolts
- mfi or efi ??????
- oil pressure problem
- Updated fuel pump s2 zetec turbo
- Are fiesta turbo fuel regs the same as non turbo?
- recon turbo?
- s1 efi boost problems
- heated seat fuse
- handbrake cable clips
- where can i buy this seal/ gasket? pics included IS MY TURBO SCRAP?
- where does this wire go?
- broke my radiator
- forge actuator
- zvh headgasket confusion
- Got the Car booked in for a setup - ** it's Back**
- FRST Idle
- What's needed to fit a cossie T3 onto escort exhaust?
- Remote Central Locking
- handling problems
- replacement ignition keys?
- White escort turbo combi van G205 RWV
- s2 wheels
- s1 rs efi help
- Possible H/gasket failiure?
- running in cam
- anyone know the part number of the arp rod bolts that come with pec rods
- rs turbo 0.25 oversize rings
- Does any have omex 600 wiring diagram?
- Ofab RST wont rev up???
- ST170 Gearbox in a MK4 ZVH
- cts stage 2 box
- cheapest insurance and best cover-help!!
- s2 alloy nuts under wipper's
- Spax damper are noisy
- Who's the cheapest yet good Turbo rebuild service?
- RS Turbo Oil Pump
- uprated clutch quadrant
- 1600i Rocker Cover on RST
- Alternator Fitment
- MSD HyperPower Coil Pack on EFi Conversions - Anyone Used One?
- spings xr3i
- Arp rod bolt torque procedure
- What lower arms
- Ford tappets
- my car is now for sale ppl
- TurboTimers
- what is it
- mk4 escort cossie
- Which SPAX Suspension kit should I Choose for my S1 cabrio replica
- something other than cars.. 9am till 12 now...
- Steering wheels
- Brand new zinc coated fuel lines
- can any1 help me pleeeeeeease,
- Metering units!
- Please Help? connecting the plugs in on the back of the inlet?
- first trophy for the s1 woohoo
- Cosworth management question..
- electronic boost controllers on mfi?
- worn camshaft?
- Starting S1 project, advice please
- tony turbo series 2
- Load Compensators
- rs battery tray
- make my own fuel light?
- Will my ZT still sound like a RST?
- Parts Clearout - polys - powdercoated bits - Ideal underneath resto parts
- Best Standard size RST S2 front brakes
- down pipe help
- S2 RST mastercylinder & servo dome nut adjustment (solved now)
- escort rs turbo died
- what breather do most use on there cvh?
- Turbo seals
- What grade minerat oil for running in?
- rst problem
- Flywheel question
- brakes won't bleed
- rs turbo exhaust
- replacing exhaust gasket
- sounds like another ebay scam?
- Piper fat road cam
- RS Turbo Engine Mounts
- who still uses their s.2s every day????
- new boy here!
- rs turbo offset
- evening all
- RS Turbo exhaust mount
- It begins!!
- Cylinder Head Core Plug
- New Engine Sensors!
- air fuel very lean
- bonnet release cable
- rst wont start
- Bit spluttery on very light throttle...
- red series 1 owned by princess diana
- F999 JTV Any info??
- efi sensors
- CVH Cambelt Cover onto a ZVH
- MTX75 another thread!
- Astra VXR injectors into EFI Fuel Rail
- Brake caliper spring clip
- Rear adjustable 6link setup
- rear coilovers
- plug leads......what to get
- Standard ERST Breather System....
- Nick wapples ported head
- Pace Charge Cooler, Any good?
- how is a ZVH engine different to a CVH engine
- Zetec engine in escort Rs turbo
- S2 Throttle body size ???
- efi engine/gearbox/ ofab ecu+loom
- New engine spec has been decided!
- S2 ecu chip identification?
- What pistons and rods??
- zetec starter motor
- S1 parts pricing help needed please.
- roll cage
- S1 Fuel Relay..
- Cheapest place to buy compomotive alloys?
- Blacktop Engine - waterpump and belt
- Wanter pump from Fiesta Zetec go onto 2.0 Zetec
- Zetec front mounted alternator guide
- Focus RS gearbox question...
- Mark4 turbo alternator onto zetec
- What Coilovers for track/strip?
- Newman Cam users...
- Where to new piston rings from??
- Inlet manifolds
- Brakes!!!!!!!!!!!!!!!!
- Wishbone rubber size
- Crank sensor hole position
- S2 non starter if left too long
- S2 standard ride height
- focus RS blacktop plugs into silvertop
- Mtx box with brand new Quaife atb
- cambelt, bottom pulley
- cvh or zetec???????
- Tracking down parts
- Focus RS Engine & Box Conversion
- S1 & S2 White escort rs turbo's fast fords sessions
- S2 MPG computer wiring? ABS light on too?
- Anyone got a fuel gauge wiring diagram???
- Smoking on track at ford fair why?
- rear disc conversion
- which st170 disks
- loosing boost underload??
- cam
- oil light
- Zetec fitment into Rs
- Mtx75 rs2000 custom mounts series 2 HELP! Please
- ZVH, light rattle from top end
- Efi conversion what's needed
- My rs/ ambers
- metering head advice please
- No oil light, problem is ignition live side?
- Just finished fitting launch control and flat shift!! VIDEO
- Boost problems
- rs turbo radiator
- my escort rs turbo with the 17 wheels
- oil pump help
- Mk4 Owners Handbook and Premium Sound 2000 Manual Taking To FordFair
- Clutch ratchet Upgrade
- Strange actuator/wastegate problem..
- Help with fitting ST170 brakes (Front)
- S1 turbo
- New to forum, few questions about s2 rst
- Rear strut top mounts/rubbers
- what's max std internals can take and be driven daily ?
- Just got a £600 tax rebate, what to spend it on?
- mk4 xr3i cab
- getting seriously bored now
- will these wheels fit my s2?
- rs turbo wont idle wen hot,
- ERST Clutch Quadrant....
- EFI performance question
- turbo talk!!
- cooling issues.
- Front indicator lense removal - help?!
- Help finding camshaft kit
- Core plugs
- Livery...
- STD camshaft kit
- Rs 7s on my series1
- Red/black colour scheme?? people thoughts please
- Has anyone ever changed 5th gear in situ?
- powder coated sump
- Head Gasket And Bolts for ZVH?
- coilovers ??
- escort rs turbo seems slow
- Noggin Nosh and Natter Rs's
- 'Genuine' Ford RST Spotlamps...?
- rs turbo brakes colour?????
- molyslip treatment
- Replacing Rear Chassis Rails?
- cvh on cossie managment??
- Back end lockup :(
- Starting problem.
- where is best to get my car rooling road
- CVH Tappets
- s2 master cylinder
- rear brake shoe fitting kit s2
- Bailey breather when running EFI
- Fitting Gaz coilovers??
