Rs Turbo Head bolts
Rs Turbo Head bolts
Hello mates.
I have a Mk4 Rs Turbo with 81mm pistons and I've been using Felpro head gaskets and they keep blowing up!! Anybody had problems with them? Another thing, I have rigid head bolts but I dont remember the tightning torque for them. Can anybody help me with that?
Thanks,
Jorge Fernandes
Thanks,
Jorge Fernandes
Felpro gaskets are no good for 1600s. The fire rings are much smaller than the STD ford turbo gasket that you should be using. The torque figures posted above are wrong too. It's something like 19lbs 40lbs 90 degrees and 90 degrees again.
Rick
Rick
Balls Deep!
As Rick says the Felpro gasket is the wrong size for a 1600cc CVH, the fire rings are in fact bigger (diameter) than the normal Ford/Payen gasket, I also do not recommend using non stretch bolts either as these have a record of causing gasket failure on RST's.
A Ford/Payen head gasket and a set of motor factors stretch head bolts are proven good for 350bhp+ and is what I recommend you use mate.
I had a felpro headgasket on my old series 2 about 5 years back and it blew very quickly when I was only running 170bhp!!!
Do it right the firset time and go genuine ford head gasket and stretch bolts
The genuine Ford gasket is very high quality - The central core of the gasket is steel.
The Felpro one is poo.
ARP studs can certainly be used - if used properly.
The Ford stretch ones are idiot proof
I have non strech bolts bought from PTS - Performance Turbo Systems. I'm not aware of their make! Would you recomend cometic multi layer head gasket??
Thanks,
Jorge Fernandes
Thanks,
Jorge Fernandes
A very fine surface finish is required. Many machine shops have older head and block deck grinding machines which cannot produce the fine surface finish required with the Cometic gaskets. - Probably why we hear of so many Cometic gasket failures.
Here in North America if one is unsure of the surface finish many shops spray the Cometic gasket with Copper Coat spray and seem to have very good results.
Norris Motorsport
Genuine Ford RS Turbo head gasket and stretch bolts are good up to 300bhp. Beyond 300 bhp you will experience some head gasket lifting with certain failure at some point beyond 350bhp. (i.e. 350bhp is the absolute maximum power the std gasket and headbolts can be used with any sort of life span.)
Cometic gaskets work great if both surfaces (head and block) are a near mirror finish.
Ive just had an engine rebuild and i used a payen head gasket, ive driven 1.1k miles and the head gasket has gone already, Ive now got cloudy oil and it misfires everynow and then! im going to try a genuine ford one.
Thanks, Joe
Thanks, Joe
I put a felpro gaskit on mine with arp stud and nut kit and it did'nt last 2 mins. fitted a ford gaskit and bolts and had no problems at all
lee
lee
Nothing wrong with the ARP stud kit if installation is done correctly.
Nothing wrong with the Ford stretch bolts either - just much more forgiving.
Have you not got an underlying issue with that car then? Payen are very good gaskets and if that has blown, a genuine Ford one won't last much longer unless there was a manufacturing defect in the Payen gasket.
Matt Baxter
16-09-2015 08:30 PM
