overheating!
Old Sep 3, 2011 | 07:30 PM
escortzetecturbo's Avatar
escortzetecturbo
Default overheating!
my escort rs turbo is overheating and cant get the temps down have tried removing the stat no difference all pipes get hot and all off the rad the temps keep rising even at steady 70mph keeps going up into the red, car has chip,pro alloy front mount intercooler, stage 2 turbo and piper 285t2 cam any ideas?
Old Sep 3, 2011 | 07:35 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
is the water getting round? as in is the water pump working? run the car up to temp and brim the hedder tank see if any bubbles start coming out ect could be the head gasket going
also are you sure its getting hot and not the gauge playing up?
Old Sep 3, 2011 | 07:51 PM
milesy23rst's Avatar
milesy23rst
PUG 306 GTI-6
if its not the above then try an msd 82 degree thermostat and an uprated fan switch mate
Old Sep 3, 2011 | 08:25 PM
escortzetecturbo
yeah water pump is working all pipes getting hot and return to the header tank, i have tried manual switch on the fans and still slowly rises, got another temp gauge on it and its going to around 105-110 on the gauge then have to pull over and let it cool down
Old Sep 3, 2011 | 09:07 PM
zippyobrien's Avatar
zippyobrien
Get your ignition timing checked. Could b retarded to much.
Old Sep 4, 2011 | 10:31 AM
Karlos G's Avatar
Karlos G
Balls Deep!
As your pump etc. seems to be working and water is flowing round i'd have the fuelling and timing checked in case you are lean or as above retarded.
If thats all good then maybe a new rad is needed, an 82 degree stat and MSD fan switch is not going to help as you have already tried without and at 70mph the fans do almost nothing.
Old Sep 4, 2011 | 12:05 PM
jonny s2's Avatar
jonny s2
timing or worst case the gasket, as at 70mph it shouldnt really be that hot
Old Sep 4, 2011 | 01:07 PM
nigel b's Avatar
nigel b
does the rad get hot top to bottom?
Old Sep 9, 2011 | 05:35 PM
bigkev's Avatar
bigkev
u tried taking thermostat out then running it,
Old Sep 9, 2011 | 05:49 PM
cosevo's Avatar
cosevo
sounds a similar issue to mine, but mine is fine if driving off boost, and also when on idle, but as soon as you come on boost hard, it takes no more than 20-30 seconds and im in the red, done all the same checks as you, have uprated alloy rad front mount, also tried to heat wrapped turbo and downpipe, still no joy, also mine was only mapped a few weeks ago, so im guessing it sounds like head gasket???
Old Sep 9, 2011 | 06:20 PM
DAZZER's Avatar
DAZZER
I had the same problem with a frt mount intercooler so fitted half size one and alloy rad also tubo cooler now temp is spot on.
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
Ade
Feb 8, 2007 05:11 PM
kurdt5
Jul 17, 2006 03:01 PM
fiestaturbo1984
Feb 19, 2006 03:51 PM
woodz77
13
Nov 6, 2005 03:02 PM
