Just finished fitting launch control and flat shift!! VIDEO
It's fucking awesome!!!!!!
When launching because you can retard the timing as part of the limiting it makes about 12psi of boost at 3500rpm so you launch making boost and it sounds just like antilag (which works in a similar way) popping and spitting and the same when you flat shift!!
A quick video as I'm parked on my drive and the neighbors wont be too happy!
As do most ecus these days really, my motec does it and that's quite a old ecu now.
Jim is probably thinking of the type people tend to use with sequential boxes, load cell on the shifter etc
We rim it on Gary's,
I also mapped my Aud for it - 4wd and 2 bar of boost - that's a proper launch lol.
http://www.youtube.com/watch?v=ihBmmrbJccU
Rick
Rick
I think if you had the switch at the bottom of the pedal travel you would get slip but I fitted mine to the top for this very reason
Makes for very fast gear changes and it actually feels smoother than changing normally, really pleased!
B1mbo
Nope, not as far as I can tell! Soon as you touch the clutch pedal it pops as the timing is retarded just before it hard limits.
Ah yeah, I used a bonnet switch on a bracket I made using a universal Central locking motor rail (stuff I just had laying around) and then used one of the steering column bolts to secure it in place above the pedal.
I think it activates after around 5mm of travel, which does nothing as far as clutch disengagement goes.
Rick
Rick
This audi makes me smile!
http://www.youtube.com/watch?v=D53yHBT8-LM
What a launch
Rob,
Karl one idea,
If your switch is at the top (which it is) touching the clutch pedal when you have wheel spin might work well as a (really) crude traction control.
I really want someone to write some proper code for basic traction (which i think they may have done) and decent boost control. At the moment the boost control leaves a lot to be desired and i don't see why it couldn't be as good as a stand alone boost controller with some cleaver code.
Rob,
Rob,
Karl one idea,
Rob,
Rob,
MS1 had RPM based traction control, would be better using a pair of wheel speed sensors though and IMO not that hard to program either.
Dont know what you mean Muz?! Cabby's handle really well... lol
Cheers mate!
Your right Rob it would work to some extent, a very light touch of the pedal (restin your foot for example) does activate.
So if the rpm increases faster (the gradient is steeper) than a predetermined curve you have wheel spin, and could retard timing, cut boost, spark cut etc etc
I was talking to Chip about this a while ago and he had some dealings with a traction/launch control which was similar to the above...... if only i could write code lol.
Rob,
Sweeet, i think you could do it quite well with a rate of change graph of rpm,
Rob,
Rob,
Thanks mate!
Rick is your Howdy on megasquirt too? Sounds superb!
What a launch
Rob,
What a launch
Rob,
Rick
