how is a ZVH engine different to a CVH engine
thats what i assumed it was, i have just bought a new 1.6 zetec engine of ebay, apart from putting my cvh head on to the zetec, what else will i have to do
Quite a bit.
It does seam silly tho to put the same size bottom end in with loads of wortk insted of the simple bolt on cvh.
Usuall people go 1.8 or 2.0 for the extra gain.
yam yammer
It's not as simple as that, plus there won't really be an advantage using the 1.6 zetec bottom end. For it to run correctly, the compression ratio will need to be reduced using either new pistons or having them skimmed. That's just the tip of the iceberg too.
All the ones I've seen have been based on the 1.8 or 2.0 block. IMO a well built cvh is just as good as a ZVH or if you're going for silly power, a full 2.0 zetec turbo would be the best option.
If you're on a budget, I've seen steel cvh bottom ends (steel pistons and rods) sell for around Ł500 with 0 miles on them and will take 300bhp with supporting mods.
im currently building one, and theres a fair bit more than just putting a cvh head on it. youve gotta get a specific head gasket, cam belt tensioner, waterpump adaptor, modify the o/s engine mount, welding the head, (depending on how u go about the conversion sometimes u dont need to)
This isnt a bad place to start and gives u an idea of parts req's and how to go about most of the conversion
http://www.zvh-build.co.uk/index.htm
cheers, neil
cheers, neil
my cvh in my rs turbo is smoking very heavy, so my options are:
rebuild this engine, buy another used CVH engine, saw this brand new 1.6 zetec was on sale for only Ł200 i thought this would be the better option but i see it possibly isnt
yam yammer
Depends on what you want from the car really. There are some real bargain engines to be had when people break projects. Just make sure it's exactly what the seller has described.
Thanks for all the replies, I want to take my rsturbo to a lot of shows and maybe a couple of track days around the country so I want a slightly modified engine which is totaly reliable.
steve
steve
Not being rude mate , but if u have to ask questions like that then i would not do anything myself , let a good RST garage do the work for ya and let them advise you
thats ok ben, i wasnt planning on doing anything myself as im not a mechanic, i was going to find a mechanic who was familar with rs turbos locally ( can u recommend anyone as i see ur from torquay), the reason i asked that question was because i saw this brand new zetec engine on ebay thinking that this would be ideal , bought it and its being collected on monday morning, but have spent this afternoon reading various posts and come to the conclusion that maybe this zetec wasnt the right thing so asked the question before i cancelled the ebay sale
steve
steve
bloody hell, its being collected 2 mozz , u mite of left it to late mate , was it brand brand new from factory still in a crate ?
if u dont mind me askin what sort of wonga did u pay ? Ł200, i really should pay more attention when reading posts !!!
yes brand new still in a crate, the guy had 4 of them to shift. at the time i thought it would be ideal to give a mechanic the new zetec and my rsturbo, get him to repair asap as i want to take my car upto the national rsoc day.
is there anyone in devon who could work on my rsturbo
could buy this:
https://passionford.com/forum/ford-r...ad-1000-a.html
or
https://passionford.com/forum/ford-r...block-etc.html
if you still want a cvh
or
hopefully i'll have all the welding finished this week, will get it mot'd. then take it to a decent garage. have found a garage in totnes who deals with RS's so may take it to them.
