PDA
View Full Version : Ford Escort RS Turbo
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 [63] 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107
  1. What does this contact do?
  2. STEERING RACK MOUNT BUSH KIT RS TURBO
  3. petrol tank!
  4. what steering wheel?
  5. Water cooled Turbos and Newman Cams questions
  6. Actuator Fitting
  7. compression
  8. oil cooler help
  9. koni adjustable help
  10. Escort RS Turbo standard cam
  11. thermostat
  12. zetec boost
  13. t3 turbo question
  14. what could i mount kenlowe fans to cooler with?
  15. Exhaust to Turbo elbow Stud-where from?
  16. what would a 2 litre zetec turbo cost?
  17. S1 Turbo on S2
  18. Gear stick assembly question
  19. starter heat shield
  20. EFi Conversion v Cossie Conversion.
  21. turbo buildz
  22. T3 turbo, hows it cooled?
  23. what i need to build an 1.9 cvh?
  24. Big Brake Question.......
  25. Header Tank
  26. Temp Guage Is it wrong??
  27. My Car Help F570 ppv
  28. cosworth s2
  29. where to get my 1900 builts?
  30. whats needed for zvh conversion?
  31. smoking????????
  32. cossie management again
  33. valve stem seels
  34. rs turbo efi engine bay pics
  35. mk4 efi loom
  36. Rev counter
  37. ofac vs ofab which is better
  38. help me :)
  39. Who do you reccomend for powder coating?
  40. s2 roof
  41. 1.9 CVH Turbo
  42. clutch slip on boost
  43. Turbo heat shield
  44. mfi to efi help im stuck plz
  45. What different starters will fit the s2?
  46. sunstar xr3 model
  47. My RS TURBO Rear Brakes not Working !!!!
  48. temp guage going really low??!!
  49. where can buy a new front antiroll bar
  50. 15w 40 oil
  51. mk3 cab MFI to EFI conversion on a 2.0ZVH
  52. Help!!!
  53. will this fit??????
  54. Safe Boost?
  55. quick answer needed-S1 TURBO ENGINE.
  56. kent cvh 34 & 35
  57. saff cozzie seats in a mk6
  58. Just blew up an anti pump up camshaft follower
  59. Q about actuator
  60. Anybody know where my old RS is?
  61. Does escort diesel van gearbox fit in s2 rst????
  62. oil cooler question...
  63. water help
  64. Headlights gone wrong!
  65. Gone to the dark side
  66. Series 2 Underside Rebuild
  67. ERST Brakes
  68. MINI MEGASQUIRT FOR ZETEC OR RS TURBO
  69. Stage 3 Turbo
  70. cam followers
  71. low comping how much needs to be machined off?
  72. bit of help please zetec turbo
  73. dropping onto 3 under load?Suggestions?
  74. whats the weight of a cvh engine
  75. Starter motor problem
  76. Wheel bearing fitting
  77. Hands up if you have fitted Go-tech?
  78. big ish power rst's
  79. boost pressure in two places...
  80. Hub Carrier
  81. help zetec turbo water hoses
  82. bailey breather
  83. silly question i know but
  84. This cant be right surely?
  85. megasquirt
  86. Zetec / zvh crank positon sensor info
  87. Desperate for help.......someone?
  88. Brake problem..please help..
  89. Dash flocking
  90. gearbox rebuild
  91. cosworth/ rs turbo hybrid dizzy
  92. Does anyone know where to get a genuine Sereis 1 clutch kit?
  93. Oil pressure and water temp gauges
  94. Earth wire for Fuel pump?
  95. efi throttle position sensor (tps)
  96. knocks and rattles!!!!
  97. SFS SILICONE HOSES
  98. efi blocks, mfi engine blocks whats the difference???
  99. low comp on standard pistons
  100. steel rods
  101. does co pot need adjusted after turbo conversion
  102. Getting a fan to run with ignition off
  103. What alternator set-up on zetec??
  104. feedback port on external wg
  105. cabriolet rs turbo conversion
  106. RST ABS
  107. group A alloys ?
  108. Series 1 torsion bars, struts, springs.What colour were they
  109. zetec manifold question
  110. help! engine is out of car
  111. boost on a s2
  112. zetec turbo water hoses
  113. fuel consumption
  114. plugs
  115. oil pressure
  116. boostproblems
  117. Alloy Rads????
  118. NEW ON HERE, C612 WPA, DOES ANYONE KNOW IT?
  119. 165 ofac (efi) chip....ok with standard injectors?
  120. series 1 petrol tank
  121. Back Panel for a S2 ** FAO Mercury Grey Minter**
  122. Central Locking...
  123. idle control valve
  124. Cossie Management?
  125. new radiator
  126. Security question!
  127. Tapping noise from top end
  128. Can you ..........
  129. Setting EFi CO Pot
  130. 5 speed GHIA gear linkage-will it fit?
  131. Fuel gauges-is this right?
  132. off set
  133. S1 Clutch cable
  134. what turbo on low comp cvh 1600.
  135. Bearings.
  136. erst turbo whats this worth please??
  137. erst turbo whats this worth please??
  138. 16i head on rst
  139. efi conversion still playing up
  140. who has cossie 8j's on ther rs and what tyre size do u use??
  141. S1 with MO's
  142. Green relay under dash-whats it for?
  143. Cossied s2's
  144. oil leak
  145. Manifold
  146. S1 Rear 1/4 Windows
  147. blown gearbox
  148. question about S2 radiator
  149. Series 1 Turbo Unit Rattling Question with Picture PLS HELP!
  150. is this ecu chipped?
  151. cossie brakes upgrade
  152. rs shell
  153. smoking !!!!!
  154. Clutch slip
  155. 350 bhp
  156. How much BHP with...
  157. hks turbo timer
  158. Master Cylinder Where to get one??
  159. polybushes??
  160. Starter motor heat shield, where from?
  161. is it legal for me too...
  162. Magnex exhausts...
  163. idle control valve????
  164. 2.1 zvh
  165. Engine Management
  166. f****d again
  167. Diesel starter motor on a series2
  168. Rs turbo wont start, HELP!!!!
  169. knackerd stage 2 turbo
  170. Flywheel bolt holes??
  171. anybody know lee billing?
  172. efi rev counter
  173. Water hoses
  174. s1 arches
  175. s2 brake problem !!
  176. help car has no power
  177. temperature gauge goes straight to hot
  178. S2 rst wanted
  179. C574DNC SERIES 1
  180. cossie brakes problem...
  181. head gasket failure
  182. Pic Req- correct position of overiders s1 turbo/rs1600i
  183. std zetec rods
  184. Apexi boost controller , any good ?
  185. HELPNEEDED DO YOU NO THIS CAR C20 LRS
  186. Noise from F/O/S wheel
  187. COUPLE OF PROBS WITH MY S2 RST
  188. tappets s2
  189. B317 LAL - anybody???
  190. (( READY 2 GO BANG !!!!) need sum quick answers!!
  191. Pattern part RST pistons?????????????
  192. F.A.O S1 OWNERS
  193. gearbox
  194. overheating probs
  195. Bonnert Release
  196. s1 & s2 fuel ecu's
  197. MOT'd today
  198. Turbo Unit Exchange. Who do you reccommend?
  199. escort cozzie wheels on rs turbo s1
  200. efi conversion Q
  201. low comping
  202. Should boost change when fitting a intercooler?
  203. Who uses bleed valves?
  204. xr3i and rst rods and crank
  205. dog box
  206. cam probs
  207. LOW COMP S1 REBUILD
  208. Smoke
  209. cossie thermostat
  210. Mk4 to Mk3 Conversion
  211. finishing off the engine chroming,inlet Q ??
  212. T3 WATER PIPES
  213. series 1 electric windows
  214. S1 parts ??????
  215. Engine mounts?
  216. GRS intercooler! any modding?
  217. Escort fuel pump photo
  218. What engine mount for zetec block?
  219. temp gauge? fuel gauge
  220. What colour name & code are genuine Series 1 wheels?
  221. Original fuel cap with key!
  222. urgent*** metering unit S1
  223. zvh needs more fuel!!!!! 5th injector????
  224. s2 rear break adjusters!!
  225. Zvh or 1.6........
  226. ANYONE USED ONE OF THESE ????
  227. fibreglass quadlamps
  228. Escort RS Turbo ZVH conversion
  229. Going for a uprated (sierra cosworth) pump
  230. Any one got a mk3-4 running n/a zetec?? help needed!!!
  231. fixing morrettes
  232. s2 wiring diagram
  233. Which oil
  234. piper 285t2 or cvh35
  235. zvh running problem quick reply needed (pls)
  236. delayed turbo+anti lag S1?
  237. Zetec inlet manifolds
  238. which turbo?
  239. 2 problems...
  240. RS TURBO coil packs
  241. Adjustable track control arms
  242. Anti roll bar RS1600i on RST S2
  243. S2 Dash Lights
  244. MK4 rear lights
  245. New Gearlinkage for S2
  246. Best ignition leads (Efi)
  247. Front Brake Discs
  248. please help
  249. Rear Screen seal
  250. removing diveshafts
