- do dump valve's make a diffrence?
- gaz coilovers on series one?
- S1 escort turbo intermittent flat spot
- S1 S2 tailgate struts
- Loose piston???
- does anybody know where i can get a carpet for my escort rs turbo
- Quick tuning question
- Size of tyres to fit on 17" diamond cut for Escort Rs turbo
- Escort Cossie Wheels
- f ing head prob
- heater and water temp gauge not working
- Brand new windscreen rubber
- ignition timing
- S2 Clock wiring
- 214bhp on MFI but want more!
- what oil do i use??
- indicators working weird, help?
- efi vs mfi ????
- A different question
- Mintex or Ferrodo pads?
- S2 brake problems
- s1 parts needed please help
- How much boost to run?
- how to convert sierra 4x4 cossie interior in S2
- Fuel Relay effects
- Will fail M.O.T on 2 things
- mercury grey touch up paint
- Intercooler / radiator / fan arrangements
- turbo glowing
- would these fit an rs turbo
- oil pressure??
- Gearbox Oil
- T3 turbo problems
- What wire for power windows?
- Rear seat hinges needed
- conrod off piston
- cosworth fuel pump on a rs turbo?
- no ignition lights
- rst rebuild what headgasket?
- gaz coilovers where from???
- Tachometer under reading
- ZVH Flywheel help please
- Stage 2 RST.
- escort rs turbo 1988 mfi
- FAO Karl Norris
- Radiator Fan Question
- Just Wrote My RS Turbo Off
- guide to changing actuator?
- Help Guys S1 wont start
- Cosworth Fuel Pump
- Bigger injectors
- s2 rear poly bushes
- Cold start valve
- 17 inch alloys in RST S2.
- Simon Lardner's RS Turbo
- wanted s2 rs turbo brakes
- series 1 brakes
- Which Front Mount Intercooler to choose from?
- rs turbo fuel computer
- RS Turbo Cutting out when warm
- which coilovers/suspension?
- Which oil to use???
- rs turbo s2 1990 missfire
- Parcel shelf
- Starting problem
- bridge pink relay/fuel pump
- hammerite hammered gray
- Wanted boot lid
- how to check lsd gearbox
- External wastegate
- What puma linkage for s1-s2
- petrol cap broken!!
- intercooler
- can anyone help plz
- Jamie Going's escort in PF
- RS turbo brake disc size?
- Zetec turbo headgasket
- timing gun
- Head work or different Turbo
- Lower arm pinch bolt
- stage 3 t3
- CVH camshaft coatings
- Turbo and exhaust manifold help please
- ST170 head onto silvertop?
- st170 discs and 2wd cosworth calipers, need help
- STOP PRESS - New CVH cam development pics
- Does my Rs turbo need setting up
- kent cams
- Will a diesel box fit my RST?
- Idle control valves
- WTF??? All sorted!!!!
- de locked boot
- well happy thanks jamsport
- who been nurburgring?
- sunroof blind????
- cold start problems
- starter motors
- offset of std s2 wheels
- Vibra Technics Gearbox Mounts???
- indicator problem
- Newman cams- how many have used their new cvh hydraulic lifter cams?
- Looking to get an electronic boost controller
- Top 10 mods for series 2 rs turbo?
- rear disc conversion, help???
- Anyone Breaking A S2 RST
- Pic request - inner wings
- Oil pump
- anyone in manchester
- GEARBOX Q
- Making ERST popouts
- Stadard T3 Spec
- will a series 2 ecu run a s1
- Zetec turbo rover inlet
- Headlights S2
- Yes!, the RedSauce Macine is workin!!
- Is this ecu chipped
- Harvey Gibbs
- rs head
- S1 strips on the S2
- pic request
- alternator
- Anyone got a pic of the oil fill point on the gearbox?
- s1 earth wire
- Hydraulic lifters.
- Breather filter fitted on the rocker cover
- 88spec clocks in a 90spec car????
- heater trouble!
- ebay rover manifold adaptor plates
- Problem with my mate rs turbo van
- good day
- s1/s2 rear wheel cylinders???
- Motorsports Development Chip for RST S2
- Heater Matrix
- Cvh head diffrences
- Is this ecu chipped?
- Zetec turbo rover fuel rail
- Is this a standard rst piston?
- My old 1
- Any1 seen this
- crank pully
- exhaust noise
- 1.8 zvh power output ?
- roof tip spoiler
- Fiesta 2.0 duratec converted in to a s2 turbo what do i need as any one done it
- Coilover spring lengths and poundages
- MK6 pedal conversion?
- trouble with my rs turbo
- fuel filler cap
- Need a head gasket, can you recommend?
- alloy catch tank swirl pot??????????
- forged internals?
- Horrible screech when I back off accelerator
- how do i relocate battery to the boot
- how to remove ecu?
- S2 front mudflaps
- Im confused
- relay
- Oil pressure guage/kit
- Air Intake Duct Pipe Of Xr3 To Rsturbo
- Heat wrap
- Rs turbo water pump
- Redline Tuning Basildon Essex
- changing valve stem oil seals...
- fuel pump???????
- Injectors For Efi Turbo
- s2 Brakes
- Do any wires earth to the passenger side footwel??
- Thermostat Housing Bolt Size
- what spark plugs? actuator?
- Dizzy question
- Ford mud flaps?
- 5th injecter position (90 spec carrier)
- t3 oil parts
- original Ford series 2 car mats
- my escort rs turbo st orange
- are t2 and exhaust flages the same size?
- Where can i get turbo water pipes
- Is it possible?
- Red lighter conversion
- Amal valve disconnected?
- mechanical oil presure gauge
- Rs Turbo non starter (fuel pump)?!
- Head gasket set
- Wont hold Boost above 9psi now!!
- Engine conversions
- efi water pipes???
- rs turbo runiing lumpy on idle etc
- my turbo sounds like running on 3 please help
- Different ecu
- how does timing strobe work?
- best place for dash bulbs ???
- any one familiar with tis type of valve spring compressor?
- escort estate rebuild.
- Alternator Wiring
- Just got back from Torque of The Devil!
- Question on gauges
- Blue Smoke??!!
- Bleeding Brakes!
- just a question
- Secs Monitor
- 4x4 rs turbo
- White Smoke and slight knocking?
- dizzy recon
- escort rst running problems
- 1990-spec rear bumper - difference?
- vacuum hose
- power differance between stage3 t3 and t34
- white smoke and poor idle. PLEASE HELP!
- What Seats To Put In??
- quad headlights ur thoughts ??
- where can i buy these?
- more advice needed
- where abouts is the fuel regulator~?
- S2 Help !
- Cabriolet turbo conversion
- Exhaust "hanging" ???
- F1 Mirrors
- Good Clean 17" Diamond Cut Alloys
- Question! Turbo
- auto specialists actuators
- Pedal Boxes.
- a project on my rs turbo
- escort rs turbo s2 bonnets
- Blown Turbo gasket....
- warming up and cooling down a turbo?
- bumper & fuel pump question
- series 1 tailgate
- No boost... HELP!!!
- HT leads fucked???/
- Fuel Computer
- Possible gearbox rebuild?
- when fitting 4x4 front brakes
- were can i buy a carbon s2 bonnet from any ideas?
- rwd series 2
- Looking For A New Wiring Loom
- Best place for RR/Mapping - Mids Area
- ignition pinking???
- gauges
- RS Gearknob, do they fit?
- Big dilema
- s2 cuts out
- cvh head
- waterproof car cover
- Major Problems!!
- who does rs turbo roll cages??
- bottom end
- s2 wont start
- Pro Alloy Intercooler fitting problem
- weld in front strut brace
- gear problem
