PDA
View Full Version : Ford Escort RS Turbo
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 [106] 107
  1. new cam standard or piper/kent??
  2. What splitter on a 90 spec bumper?
  3. Oil in my hoses! help?
  4. engine warning light is on....
  5. Handbrake light flickering.....
  6. Check out my garage clearout!
  7. close shave
  8. S2 loom
  9. gear box help please only an hour left to buty it off ebay
  10. F.A.O anyone with a b&m quickshift
  11. To ZVH Or Not
  12. difficult to start after left standing
  13. Anyone seen my old RST? C700 DYB
  14. Shells
  15. S1 Brakes
  16. cam for erst
  17. new install in my series 1
  18. Series 2 brake fluid reservoir
  19. thieving scum
  20. badboy bonnet and cut out bumper
  21. clutch ratchet quetion
  22. F28GUD white series 2 rs turbo info needed!!!!!
  23. 48 Exhaust housing hybrid turbo experiences?
  24. Changing Coolant
  25. cages???
  26. Anyone Seen my old RST
  27. Rebuild time!
  28. One of the earliest series 2s up for sale!
  29. Best way to fit oil temp sender to a ZVH
  30. s1 turbo in mark5 shell
  31. BBS split Wheels
  32. My S1...
  33. s2 mongoose full system 3.5" tail £200
  34. ABS removal?
  35. Is it the end of another RS?
  36. Series 2 owners put a pic ere!
  37. s1 in need of tuning
  38. Starting Problems
  39. HELP!! My RS aint startin no more!!
  40. when i take the oil cap off the engine stops?
  41. smoking s1 can anyone help
  42. Chrome
  43. WANTED!. S2 RS Rear disc conversion complete.
  44. Can you help? CVH trouble
  45. my van pics at last
  46. Escort mk4 wishbone?
  47. Rear strut brace pics?
  48. pics of my red S2
  49. series 1 owners help
  50. My 1st RST... cant wait to start moddin... wot u think???
  51. the best .....
  52. 2nd fan
  53. clifford alarms#''#''#''#
  54. my engine misfires!?
  55. My Series 2 RS Turbo
  56. What boost on turbo and chip.
  57. Where to buy an on board fuel computer?
  58. New floorpans-VIN NUMBER?
  59. URGENT fuel pump relay
  60. anyone got a foked mk3 'scort door?
  61. what to do??
  62. S2 Turbo + Manifold
  63. charge cooler on e-bay!
  64. BEST OIL FOR AN ERST
  65. S2 rs turbo question
  66. First pics of my car!
  67. Oh god another person tells me sumit bad!
  68. And there on!...........at last!
  69. Knackered Gearbox ADVICE needed please!
  70. S1 RS Turbo P/X
  71. Coilovers?
  72. zvh oil pump help
  73. Interesting.... ERST tubular manifolds....
  74. Need Series Help Please.......
  75. How much are mk3 inner wings?
  76. 2wd for a S2
  77. Power Engineering System 2 conversion.
  78. Just got my first rs turbo
  79. erst parts
  80. Whats my car worth??
  81. WANTED. erst s2 alternater brackets
  82. result its holding boost at LAST
  83. Just ordered an Evo 4 i/cooler!
  84. heaters packed up
  85. SAPH LEATHER INTERIOR, HOW DO I FIT ONE IN MY ERST?
  86. WHO KNOWS THERE TURBOS?? spot the difff parts PICS
  87. hybrids and how to tell
  88. nicked s2's
  89. Wheel help...
  90. So come on then, tuning.....
  91. Newbie!!!
  92. ** METERING UNIT URGENTLY NEEDED **
  93. Side repeaters
  94. S2 chrome timing/cam belt covers
  95. S1 owners, who are u ?
  96. fu@# oil probs, lend me ur ear!
  97. got loads of questions.
  98. FAO all turbo owners in this forum
  99. Putting on a new turbo...
  100. 20 zetec parts needed(asap )
  101. Stickers for tailgate
  102. problems
  103. Best Exhaust For Series 2??
  104. EVO 4 i/cooler info!
  105. Chassis Leg Rot
  106. What would you pay for a G plate series 2?
  107. Value??
  108. GRS EVO 4 intercooler!
  109. poor running, too rich??
  110. RS Turbo Convertion
  111. gauge pod for coin tray
  112. Reaction?
  113. Ignition maps, anyone?
  114. help!!!!!!!
  115. just had my chip and dash31 done
  116. Wanted! Turbo water Hose and Fan Brackets!
  117. whats a brand new S1 kit worth?
  118. Steering Problems on Rst series 1
  119. oil pump issues
  120. see my nearly finished project
  121. Anyone got. . . (s1 part)
  122. looking for a website
  123. Fuel computer Help!!!
  124. How much for an RST????
  125. STOLEN
  126. cams
  127. engine rebuilds
  128. New legs
  129. Braided hose's
  130. suspect air leak?
  131. What plugs&Leads.
  132. RST S2 Zetec Conversion
  133. werid idling
  134. Exhaust Recommendations
  135. locks
  136. RST S2 Restoration
  137. escort series one
  138. Cutting out at junctions...?
  139. ERST S2 handling advice needed please....
  140. fuel pump, knackered??.....
  141. Single Wiper Conversion?
  142. Anyone need an original ford Series 1 Air Filter Box?
  143. Starter motor heat shield on a zvh?
  144. S2 starting problems please help!
  145. all erst owners help needed
  146. Cutting out on idle.
  147. erst/cossie amal valves
  148. cossie or better brake set up?
  149. Taking off a dump valve!
  150. shell restorations
  151. S1 were and tear
  152. Cossie Wheels on a MK4?????
  153. whots the best intercoller for a S1
  154. Adjusting the boost on RST Series One?
  155. bits needed asap
  156. S2 Clutch Fault
  157. r the alternators the same on s2 and xr3i
  158. New to escort rst's. Queston time!
  159. Top tip
  160. Rocker cover badge
  161. URGENT pics of heat shield req.
  162. 200-220bhp?
  163. lookiin for a pic of the turbo with a certain cooler
  164. bottom end
  165. help
  166. stickers how do i go about doing them
  167. Best way for 200 ft/lb or torque
  168. Damp in passenger and drivers footwell?
  169. im having trouble removing the side skirts
  170. Heaters on a MK4 ERST
  171. mongoose 4 1/2" outwardly rolled back box for s2 for sa
  172. damn exhaust
  173. just bought an rs turbo....
  174. Bloody car!!!!!!!!!!!!!!!!!!!!!!!
  175. Ignition.Click.
  176. Changing the head gasket.
  177. what head gasket is best 4 s1 turbo?
  178. rear lights red/grey smoked
  179. 1 last problem !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  180. rebuild?
  181. whats the max bhp on standard rods??
  182. RST owners.. have a look
  183. 2.0 Zetec Engine for sale
  184. flaming erst
  185. What Oil??
  186. clear ligths for an S2
  187. RS TURBO ORIGINAL INTERIOR FOR SALE
  188. Big valve head on my ERST
  189. Too much fuel?!
  190. cossy brakes on s1
  191. crusher is comin (pics)
  192. Few Probs and need bit of advice
  193. wheres the cold start valve?
  194. car wont start wen hot!
  195. problems when putting foot to the floor!
  196. Plastic Welding my S1 arch ???
  197. Braking problems...
  198. series 1 wanted!
  199. What size Tyres???
  200. car won't start!
  201. Cossie brakes Vs St170
  202. help car cutting out
  203. Timing Problem
  204. 1.9 CVH vs. 1.8 ZVH
  205. chip for S2
  206. hi everyone
  207. 90 spec bumpers
  208. cam
  209. *BREMBO DISCS NEW ERST2* (picture now)
  210. *MORETTE TWIN HEADLIGHTS NEW*
  211. S1 body kit on a S2
  212. over fueling
  213. RST Holding back
  214. Startin up on 3 cylinders!!!
  215. a
  216. insurance
  217. no spark
  218. rolling road result
  219. hybryd engine build [jobs f--ked]
  220. starting
  221. new gearbox
  222. 4 Paddle or 6 Paddle clutch in Escort RS Turbo S2
  223. painting calipers
  224. look in general disscussion
  225. Erst T3 vs. Cos 4x4 T3
  226. RS2k Recaros to a RST?
  227. No boost!!!
  228. f**kin engine probs AGAIN!!!
  229. Cossie brake conversion
  230. Adjustable intermittant wipers
  231. Chipping an ERST
  232. MFI verses EFI on CVH, whats better?
  233. Yellow connector where does it go???
  234. Belt up!
  235. ne 1
  236. No Spark Problem S2
  237. How many miles has your RS done?
  238. Anyone breaking S1 RST?
  239. S2 is it 90' spec interior???
  240. Series 1 Unleaded
  241. Wot size wheels?
  242. ht leads
  243. i need help with my mfi
  244. Newbie here!
  245. witch spark plugs
  246. How difficult is a clutch change on a S2?
  247. look at my engine (it a cracker)
  248. 5th injectors
  249. Rusty Fuel Cap area
  250. Message for B19-TRB
