So come on then, tuning.....
Easiest way for 180-190bhp on a good S1 engine....
I'm guessing ;
Zorst, filter (either cone or panel and modded box), -31, 195 chip (shelf jobbie) and about 14-15psi should do it....
Question is - how long will the turbo cope with this, and how stressed is the fuel system gonna be? Over time I mean...
With this spec I would also deffo change the i/c as well, std S1 is shit, and we all know how much more efficient cooling makes to performance (see latest PF for this proof alone)
Now I been told by several peeps on several occasions that std turbo's (in good cond) will top out at 17psi, but should be fine for 14/15psi.... Add a -31 cos the std actuator is shit and you'll be okay - true?
So come on then peeps
I'm guessing ;
Lewis, thats what I was thinking along the lines off...
Would probably go for the 4x4 I/C conversion Scott R has, so thats cool for 16psi, but how long will a std turbo last on that boost? Would probably put in a 2stg boost switch to run say 10+16psi
How much power (est) for 16psi with that spec then?
Ahmed stage 1 chip and matched cam
K&N panel filter in modded box
-31
proper set-up (mine had the metering head mod done)
1.2 bar
4x4 intercooler
standard turbo
decent plugs,leads and Grp A coil
I was seeing approx 195BHP and 210lbft torque
My turbo is now shagged BUT it did last doing track days and road abuse for 30,000 miles
-31
1.2 bar
4x4 intercooler
standard turbo
TBH, as much as I used to fantasise over spec lists and all these trick mods and like 270-290bhp builds, I jsut can't be arsed with that anymore. It's not as if I'll ever use it properly, and I still htink that anything over 240-250bhp in a FWD Escort is wasted power anyway (chassis restrictions and drivetrain) so 180-190 will be fine for now, maybe save for a 230build sometime in the future...
Jsut gotta find a S1 I like now
turbo
Shouldn't be a problem for the turbo mate. Its more down to regular oil changes and obviously allowing for running down time before you switch off that will affect your turbos life expectancy.
standard turbo would b good for 16psi for a good time! & even if it goes pop they aint exactly magor cash r they!
well tjhat was gunna b the spec of my estate & Karl reconed around 190bhp!
LOL
Get one mate you no it makes sence!!!!!
My hopefull spec is:
2.1 ZVH
Big valve ported and polished head
Paddle clutch
Hybrid gearbox
4x4 intercooler
EFI management (Standard FRST to run it in, then off to Paul Hills for a live mapping session)
Co2 or water intercooler spray
ARP bolts etc....
Full Monggoose exhaust
Pipercross cone filter
Should go well
2.1 ZVH
Paddle clutch
Hybrid gearbox
4x4 intercooler
ARP bolts etc....
Should go well
this is my spec
k&n cone
magnex exhaust
uprated actuator
pace intercooler
superchip
the cars running 190 bhp and 200lbs of torque @15 psi of boost
kent cam kit goes in this weekend so hoping for 210 bhp when its rollin roaded next week
cheers kev
k&n cone
magnex exhaust
uprated actuator
pace intercooler
superchip
cheers kev
My spec was
K&n
scorpion exhaust
chip
kent cvh 35 cam&vernier pully
pace intercooler
-31 actuator
never set up
running 185bhp at 15 psi (got bored turned boost up to 20psi then bang)
(didnt last long hope new engine lasts)
K&n
scorpion exhaust
chip
pace intercooler
-31 actuator
never set up
Originally Posted by Rossco
LOL
2.1 ZVH
Paddle clutch
Hybrid gearbox
4x4 intercooler
ARP bolts etc....
Should go well
2.1 ZVH
Paddle clutch
Hybrid gearbox
4x4 intercooler
ARP bolts etc....
Should go well
Save yourself a grand, buy my mates S2, which has a near identical spec to what you listed, for Ł5k, then put a std engine into the S2 and sell it for a couple of grand and you got the engine for yours and only cost you 3k
Seriously, his engine is pretty much spot on what you listed: EFi running Omex ECU (see Christian & Beccy), 2.1 ZVH bottom end, M.A.D Stg3 head (big valve, full port/polish, etc), stg3 Turbo Dynamics turbocharger (S2 spec so already water cooled ) Radtech alloy increased core width rad and matching full front I/C, Arias low comp pistons, ARP bolts, steel crank and rods, serious serious engine, currently still in run-in mode (3,000 rpm limit and beige injectors - mapped for correct fueling) so all it needs is bigger injectors (greens or light blues suit fine), and a mapping session to unleash the power. Calculated power for 22psi (peak at 24psi fully safely) is 270-280bhp, capable of 28psi for 300+
Engine has been supervised and set up/mapped all along by Simon Norris of Norris Designs (he of the 700+ bhp Evo ) but any decent tuner (eg: Gary @ SCA, they mapped and tuned C+B's Omex ECU'd EFi RST and we know how good that car was) can map this car no probs....
Do it man do it!!!!
5k way out of my league too, ive got about 2k to spend, my mate Rob is building the engine for me on the side, he builds engines for a living, ive spoke to him and he thinks i should have an easy 220bhp and relible to with the spec ive listed. I dont want to go down the after market managent its just far to much money!!! A mate of mine says that Amed from grove garage is able run 30 psi on EFI FRST management, so mine running at 18-20 psi should be no probs!!
300 bhp in a FWD car Wheel spin springs to mind!!!!! PMSL
I've seen an Ahmed tuned car running on MFi (K-Jet) system run 24psi for about 280bhp (1900cc low comp, stg 4 turbo/head, steel rods/crank etc) all day long for the last year or so with no det and no probs, so I still belive in MFi Get him or Mark Shead to do the fuel mod to the metering head and your away
I really want H section rods, i think thats gonna be my "weakest link"bit pricey though, iam gonna have the standard Ztec ones shot peaned to make them a bit stronger, just hope they dont say "GOOODBYEEE"
Originally Posted by Thrush
Shouldn't do, depends how high the rev is set and how much boost you pulling out of the engine. H-section avalable form Burtons, but if you get them from the guys next door to Burtons (CTM racing) they are cheaper but the same thing lol....
just like burtons!...ive noticed they are quite expensive!
Yeh think Burtons are geting a bit greedy
Iam aiming for 20psi of boost which should make around 220-230bhp, some people have said the standard rods will cope with 270bhp, but with the pistons costing Ł130 each i dont really want to find the breaking point!! lol
CTM racing you say, iam gonna have a word, cheers Matt
i,ve gone through a few engines in my s1
now im on to a specialized engines 1.9
balanced crank and wheel
s2 fly wheel
low comp
stage two head
piper 285t2
k&n panel
magnex
and 20 psi
on a stg 3 turbo .48
and the key to it all
a custom ahmed map chip
with a fuel enrichener
the chip and set up is the key
ahmeds chip is amazing i had a super chip and theres no comparison
s2 fly wheel
low comp
stage two head
piper 285t2
k&n panel
magnex
and 20 psi
Ross - I think 20psi is a bit high for 220-230bhp. On a fully specced EFi 2100cc ZVH you should only need 14/15psi for that power. We (on my mates S2) are getting *roughly* 170-180bhp whilst only running 8psi (measured by running against cars in this power band, mostly loosing tho due to the rev limit being 3k, but keeping up with em till this point....
The power curve must be more gentle meaning the power is feed in far more smoothly, not really sure why but probally because the cossie managent you can custom map unlike MFI.
Thats another reason iam going for EFI, you have more options with it.
