PDA
View Full Version : Ford Escort RS Turbo
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 [105] 106 107
  1. ECU'S
  2. ECU'S
  3. help
  4. rs turbo engine advise
  5. rst thermostat
  6. strange 'ticking' noises ?
  7. I want an Escort RS Turbo. Advice please!!!
  8. clutch prob :-(
  9. series II problem
  10. rs turbo fiesta and escort cyl heads
  11. twin 2wd vs grs 4
  12. want compomotive wheels
  13. My New brakes setup!
  14. s2 ecu box colours???
  15. Help! S2 rs turbo knocking..(pinkin)
  16. GRS intercooler cost? phone number?
  17. Good bit of sport
  18. 1.8cvh bottom pulley
  19. Series 1 pics
  20. pics of your front bumpers needed, (meshed up)
  21. Boost Gauge (information) please
  22. please i need help with a s2 rst, having big problems!
  23. please i need help with a s2 rst, having big problems!
  24. please i need help with a s2 rst, having big problems!
  25. s1 problem
  26. boost
  27. dumped my 17s for standard rims
  28. Running Rough!
  29. Carbon Bonnets
  30. s2 rst running problem /was pump,done for now!pics!
  31. fao a red s2 with chrome bumper strips
  32. Headlight Covers
  33. mk3 to mk4 rear head lamps
  34. relocating bleed valve hose to crossover pipe....
  35. temp prob??????????????
  36. any 1 got 18s on thr s2
  37. starter motor??
  38. 90Spec Front Bumper Wanted
  39. s2 engine help!!!!
  40. RS TURBO FOR SALE
  41. bleed valve
  42. Can some1 put some pics up 4 me!!
  43. HELP !! MY RST
  44. RED S2 on the A1198 to royston 2day 3:15???
  45. S2 CUTS OUT THEN BACKFIRES
  46. drop+wheels size
  47. Bodykit adhesive
  48. Turbo Conversion
  49. RAD OR INTERCOOLER
  50. hi im newm (pics?)
  51. seatbelt help
  52. Backfiring and cutting out...(Again!)
  53. starter motor
  54. does any1 know
  55. cossie 4 pot brakes in series one
  56. fan not working
  57. bloody car wont leave me
  58. Cossie or st170 brake conversion
  59. S2 Gauge Pod Surrounds
  60. My S1 in now on the road
  61. fuel pump??????
  62. Oil?
  63. fan override switch
  64. Anyone Sellin...?
  65. 205 tyres on Escort RS Turbo Rims
  66. idleing
  67. s1 custom project (bare shell)
  68. rst driveshaft oil seals
  69. having a turbo rebuild
  70. RS Turbo S2 Wiring
  71. wiring in a fan over-ride
  72. what gearbox??
  73. Cold Start
  74. TRACK (NATIONAL DAY) HELP !
  75. Got my 2.1 up and running
  76. help needed suspected headgasket gone
  77. boost pressure fluctauting
  78. 3dr front brake on a S2
  79. Fans, overide switch etc...
  80. rolling roads
  81. boost gauge not working
  82. ABS light ?
  83. test
  84. cams
  85. What gearbox oil?
  86. will a stg 3 s2 hybrid fit a s1 rst?
  87. using efi throttle body
  88. John Noble Motorsport??? any good??? Derbys'
  89. piper or kent or unknown contender
  90. Hoses . . .
  91. Coil overs or shocks??
  92. Plug gap's....
  93. Fuelling control ?
  94. spoiler screw caps.
  95. PLEASE HELP !!! s2 fuel problem...
  96. Few Probs. Help Needed.
  97. Best radiator for an RST
  98. Car Failed MOT!!! :(
  99. 4 pots on rst
  100. does a head allways need skimming
  101. just reregistered
  102. 1.9 fitting info
  103. WHAT OIL?
  104. Series 1 (Not boosting) ????
  105. rear discs
  106. Stereo wiring help needed pls
  107. S1 ARB BLOCKS
  108. Backfiring?
  109. Need new turbo. Who makes a good'n ?
  110. s1 & s2 promblems
  111. whats next!
  112. need a new clutch, where from etc...
  113. plugs?
  114. RS turbo running probs!
  115. ADVICE NEEDED PLEASE RUFF RUNNING S2 ERST
  116. series 2 - which head gasget? (NOW WITH PICS )
  117. rs turbo abs leave or ditch ?
  118. wiring fault
  119. Thread size for brake line ends. ABS
  120. S2 Escort RST blue smoke exhaust problem
  121. GRS Intercooler?
  122. help needed big time please
  123. S1 respray
  124. 90 spec gear knob ?????
  125. Stereo wiring....HELP !!!
  126. few bits selling off me ERST!
  127. me RS is eating radiator fan switches
  128. head gasket?
  129. Bubbles
  130. another one bites the dust!!!!!!!!!!!!!!!!!!!!!
  131. Start Problems When warm/Ripping ABS out
  132. s2 cuts out when warm
  133. help
  134. another problem with erst....
  135. ERST FEEL LIKE GIVING UP
  136. s2 leaking gear box oil
  137. SETTING UP THE AIRFLOW METER AND CO LEVEL??????? pls help
  138. Where does your temp gauge sit?
  139. How much is my series 2 worth?
  140. How much is my series 2 worth?
  141. Abs light/brakes ?
  142. How much boost?
  143. s2 erratic fuel gauge
  144. s1 cutting out problem
  145. some pics of my m8s s2
  146. should i keep my ERST
  147. Alloy parts
  148. can/will i get 200bhp now?
  149. Engine refit question...
  150. Me VS E46 M3 Convertible
  151. Anyone got a flammer on there escort rs?
  152. Relays & part numbers
  153. rst clutch
  154. URGENT help needed!!!!!!!!!!!!!!!!!
  155. Quick shift advice
  156. cossie management conversion
  157. bought the s2
  158. Boost drop off......
  159. Rotor arm
  160. how much would you for a 90 spec bumper (mint)
  161. cheap s1
  162. swapping ecu to chipped ecu?
  163. Problem with ERST....
  164. What boost with new actuator?
  165. Who do you insure your S2 with?
  166. Sparco Strut Brace.... Good or bad?
  167. S1 window seals
  168. Series 2 for sale
  169. is a s2 rad the same as a xr3i
  170. Fitted my bumper strips, what do you think!?
  171. Wot clutch?
  172. s2 rst buy ir not?Advice please!!
  173. Cam belt covers
  174. just bought my first s2
  175. ANOBODY NO ABOUT ACTUATERS.
  176. Starting rst
  177. got a prob with my s2
  178. s1 wont stay runing
  179. wet filters?
  180. s2 cuts out whken you brake
  181. Throttle Linkage, any ideas.
  182. s1 turbo overiders for bumpers ,were can i get them???????
  183. Big Problem!
  184. prob bin asked before but here gos
  185. prob asked loads of time but here gos
  186. Delayed starting !!
  187. k&n airfilter
  188. DOH! CAR DIED RACING AN IMPREZA WRX LAST NITE
  189. s2 dead or not?
  190. Car not starting>>>>>>>>>>>
  191. lightened & balanced ?
  192. indicators not working !
  193. strange noise on low tickover....
  194. Electrical problem
  195. 205/50/15 tyres for sale
  196. FAO TILLIO
  197. need WANT a s2 rst
  198. RS TURBO BOOSTPRESSURE
  199. Boostpressure RS Turbo
  200. Thinking Of breaking My S2
  201. Who owns a 'D reg' series 1.............
  202. she's back
  203. wheels sizes
  204. HELP!!!!! RE: AIRFLOW METER FIXINGS
  205. Battery keep going flat
  206. S2 stainless steel speedo surounds
  207. WHAT SHOULD I BE LOOKING FOR WHEN PURCHASING AN RS?
  208. cambelt removal and replacing
  209. S1 Window Rubbers
  210. Oil/water heat exchanger on a ZVH...
  211. Brakes
  212. carbs on a s2
  213. piston broken
  214. Help Needed!!!!!!!!!!
  215. S1 front tie bars
  216. INFO ON PISTONS REQUIRED!!!!
  217. My fu#*ed engine!!!!!!!!!!!!!!!!!!!!!!!
  218. Been offered £1500 for my S1...
  219. Where can I get.....
  220. headgasket failure?
  221. Do I need rear seats for MOT?
  222. Need Advice.......
  223. How can you tell the difference....
  224. The thorn in my side
  225. CAR WONT BOOST PROPERLY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  226. Stage 3 hybrid turbo..........help!
  227. S1 front glass *help*
  228. anyone in northants or beds have a......
  229. Always an F'ing problem
  230. Looking into buying a rs1600i with a 1.9 turbo lump and
  231. erst missing at 5000
  232. Car Wont Start...
  233. Best Intercooler
  234. My 200 bhp RS
  235. Headlight problem?!?!
  236. My New ERST
  237. super chip erst plug in or soilder any 1 help plz
  238. 1.9 CVH HELP !!!!!
  239. Zetec Coil on Plug Kit
  240. s2 efi conversion. whats needed etc?
  241. Im really confused
  242. What oil for series 1 RS Turbo
  243. question re K&N/Airbox
  244. AP 4 paddle clutch.....
  245. bonnet raisers?
  246. fans etc...
  247. Fitting After Market Oil Cooler
  248. Plugs & Leads.............
  249. series 1 rs turbo???????
  250. whos got the nicest
