Bodykit adhesive
Bodykit adhesive
Have got to remove the bodykit to do some welding what is the best stuff to bond/stick the kit back on a series 2 ERST?
cheers Si
cheers Si
I used some strong adhesive on my old one, stuck well, but there are better ways, probably as above, failing that check tony turbo's thread in the "restorations" section there are pics of what he used
i just used sum bodykit adhesive from halfords, it was only £3 a tube n its kept my s2 kit on my cab fine! Its in a white tube wiv a green label. I cudnt find no tiger seal newhere!
Yep id use Tiger seal, its way cheeper than Sikaflex and really is just as good.
Windsceen fitters dont use the stuff, they use a glue which goes off alot faster, not sure what its called, but i know its fooooookin expensive!!!!
fuzzy
21
15-02-2016 10:26 PM
Vacuman
22-09-2015 12:09 PM
muz
16-08-2015 12:57 PM
