PDA
View Full Version : Ford Escort RS Turbo
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 [43] 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107
  1. uprated head
  2. 6 point roll cages
  3. Battery lights stays on but altenator is fine
  4. my rs
  5. 40mm tyres for 15s ?????
  6. Best oil to use in 2.1zvh
  7. Boost Problems?
  8. compression struts for mark 4
  9. favor needed
  10. straight cut gearbox?
  11. mint xr3i. good for rs turbo conversion
  12. help needed with oil pressure and rev counter wires
  13. master cylinder etc...
  14. question about AP RACING CLUTCHES?????
  15. Fuel Tank
  16. series 2 sunroof
  17. MK5 Escort clutch quadrant replacement/Alloy quadrant
  18. does the mk4 fiesta master cylinder fit into...
  19. Lowering Springs.
  20. Facebook?
  21. s2 over heated today,please help
  22. s2 cutting out!
  23. TÜV for LEDA coilovers
  24. Head gasket advice please
  25. Anyone recognise this Immobiliser??
  26. 1.6 cvh rs turbo bottom end rebuild
  27. fuel presser
  28. rs leather 3 spoke steering wheel any one no what boss fits
  29. T3 Turbo Return Pipe
  30. rad help please
  31. s2 rattles when i take foot off throttle
  32. s2 smoking and no boost
  33. overheating, cant find a solution :(
  34. Injectors?
  35. Show me your inlet manifold setups please
  36. injector ?
  37. help s2 running troubles
  38. piper or kent
  39. would they be ok to use?
  40. Escort Rs
  41. s1 no spark
  42. fan fitting pics
  43. Cosworth brakes
  44. where can i get a polished oil cap from?
  45. dump valve dropping idle...
  46. does anybody now this car?
  47. st stripes on s2
  48. little help please
  49. I might be wrong but surely this is too much for this ?
  50. S2 speedo cable?
  51. Fan Relay?
  52. rs turbo in mk 5 van.. engine mount
  53. misfire!!!!!!!!
  54. 88 spec to 90 spec clocks
  55. 300bhp+ turbo's....
  56. Stage 3 Head
  57. fitting a bailey oil seperator
  58. gearbox mounts?
  59. What lights are these?
  60. a-post pillar seal?
  61. Powerchips EECIV Module identification
  62. ofab map sensor wiring diagram
  63. good fuel regulator/guage for the frst rail
  64. erst running problems
  65. timing cover
  66. timing piper
  67. Fan sender.
  68. standard cam with vernier pulley
  69. arrrr non starter
  70. Series One wiring problems??
  71. Cylinder head 'is this true?????'
  72. fiesta turbo shockers fit rs cab?
  73. Fan isnt working?
  74. is the timing different on a kent cam than std
  75. cams
  76. Fueling????
  77. what oil do u use
  78. Twin Fans
  79. XR3i EFi Wiring loom
  80. EFI Accelerator Pedal
  81. top end tapping?
  82. twin fan fitting between rad an i/c?
  83. engine problems with s2
  84. 3 bar map sensor
  85. brand new s2 turbo bonnets
  86. what would happen if ....
  87. BR rev limiter?
  88. Pic request
  89. Any pics of outer wishbone area?
  90. Much difference in the 1988 rst and 1990?
  91. Air charge sensor
  92. t34 turbo on 1.6cvh?
  93. TCA balljoint.
  94. Youngest RS Turbo owner?
  95. please help rs turbo steering column. arrrrr
  96. way to check for cracked head?
  97. fuel pump
  98. show us your rs turbo engine bays?
  99. mite sell the rs
  100. rear wheel alignment?
  101. Show us your rust
  102. Standard Fan
  103. wineing noise
  104. Master cylinder problems
  105. Plug and go?
  106. F*** PTM rebuild
  107. Safe boost pressure on S1 turbo
  108. Who does dash flocking
  109. series 1 suspension
  110. will a bottom end fit with the gearbox..
  111. HELP, car wont start when cold
  112. best gasket for zvh
  113. rs turbo van fuel tank?
  114. lot of regulars selling up
  115. fiesta cradle fit series 2 escort??
  116. someone got bad news (rot)
  117. Turn side lights on, they are my headlights... help
  118. anyone seen this on ebay
  119. Easy Mods?
  120. Alternative Dash Displays/Instruments
  121. gear box problem
  122. which alternator bracket for zvh???
  123. Linking a clifford alarm to central locking
  124. What voltage at battery?
  125. releasing Tie rod ball joint?
  126. Where do these go and why?
  127. Carbon Fibre Roof
  128. vxr injectors
  129. new or reuse
  130. Bolts
  131. Simple question: Escort MK6 RS2000 handbrake cable # number
  132. carbon bonnet
  133. Would a 300bhp S1 rs turbo see off a 550bhp ecsort cossie?
  134. anti lag
  135. standard ford radio/cassette
  136. quick question about rods
  137. Bought this today
  138. New Metering head value?
  139. welder req (Slough area)
  140. How do you disconnect a immobiliser
  141. ap organic clutch
  142. EFi and lambda
  143. Oil coming from exhaust manifold gasket?
  144. how heavy is yours rs
  145. New Rims for 09
  146. valves
  147. Fuse box repair panel
  148. EFI Head
  149. found a new turbo
  150. a good sump gasket
  151. a lot of smoke!!!
  152. S2 v Civic Type R
  153. What Engine?
  154. mondeo mk3 brakes
  155. rst cossie?
  156. Wiring Loom
  157. S2 always running hot?
  158. turbo oil feed
  159. whos bought a grey rs turbo thats sat in a bodyshop in chester ?
  160. GOT ONE ALL SORTED NOW! Can anyone help out with this please?
  161. boot lock
  162. Zvh vs zetec turbs
  163. Any one got a spare engine?
  164. CVH oil and water pumps
  165. zvh question
  166. Boost gauge needle sits below 0...
  167. oil pipe
  168. escort cosworth fuel pump into xr3i tank
  169. Does anybody know the spec?
  170. EFI Questions
  171. YB and CVH vernier pulleys?
  172. EFI
  173. s2 water cooled turbo vs s1 oil cooled turbo
  174. timing on a cvh with a piper cam and pulley
  175. where can i get a vin tag made??
  176. twin fan position?
  177. diy tuning
  178. vernier pully/standard cam ?
  179. Help, Escort rst s2 starting then dying
  180. Couple of quick EFI conversion questions please!
  181. 215/40/17 tyres
  182. FRST EFI OFAB Q's (NO spark)
  183. rs2000 cv joint fit rs turbo?
  184. F**k it! I'm going EFI and Megasquirt!!
  185. car wont start
  186. Gearbox / Quaife ATB Fitment
  187. FAO Karlos
  188. 200 BHP @ fly
  189. Big Boost
  190. Difference between Let and Xe Pistons
  191. Metering Head?
  192. suspension koni+apex? what you think?
  193. 1.8 zvh question
  194. fuel ecu colour s2 ?
  195. frst engine loom into escort efi rx3i ** help needed **
  196. Can i cut out my spare wheel well
  197. s2 escort rs....many problems!!
  198. Handling Mods???
  199. compression issues.
  200. base map for level 8 ?
  201. are fsi boost valves worth it?
  202. Brake setup
  203. Where to get braided fuel lines
  204. Why we do it.
  205. Back fire??
  206. What can cause massive ignition retard?
  207. boost gauge hose
  208. Rear disc coversion problem!?
  209. s1 rs turbo not starting?
  210. mk2 fiesta cradle fit a s2 rs turbo?
  211. Can anyone help me sort my sunroof?
  212. Anyone got a Mutlimeter who's MFI and a spare 5 mins?
  213. S2 Cutting Out
  214. show us your efi engines
  215. Can you still get new trailing arms?
  216. which new wheels
  217. What inlet
  218. stg 3 hybrid turbo question
  219. xr3i turbo not starting
  220. head bolts tourque setting and oil
  221. s2 howling on boost
  222. s1 gearbox casing
  223. Update! BACK FROM APT! Do I fucking need it??!!!
  224. time for forged??
  225. full outer body re-sparay cost's?
  226. new driveshafts/recon??
  227. Leaving the rs turbo world
  228. how to install air vent gauge mount
  229. car wont idle
  230. my rear disc converstion
  231. Head differance????????
  232. Front Arch Skirt removal
  233. rs2000 dri-shafts fit my rs turbo??
  234. crack in arb bracket
  235. best place for bit?
  236. Inner tyre wear - all 4!?!
  237. Radiators!
  238. Series One Know-it-Alls. Need some advise. PICTURES ADDED
  239. vibration on over run
  240. Front speaker pods
  241. escort rs turbo oil light stays on
  242. Rs Turbo Clutch Help.
  243. Fan switch
  244. best stage 1 chip?
  245. s1 fuel problem
  246. Cvh sump Gasket
  247. ahmed bayjoo chip/adjust
  248. Question About my new exhaust manifold
  249. Petrol lock, keys and cap
  250. escort rst powerflex anti-roll bar bushes
