what would happen if ....
You're ABS would no longer work on that circuit and your brakes would feel shit. Have the ABS removed as it's utter shit anyway and both braking and pedal feel are improved by getting rid
S1 Database Editor
Plus your ABS light would be permanently on as the microswitch activated by the belts would show there was a problem, thus failing any mot also.
If you're gonna remove one because of a noise then you may as well replace it and save yourself the hassle or either working around the system showing there is a problem or removing the whole lot saving yourself some cash in the process.
I upgraded my brakes to cossies bcalipers and discs and high performance pads with goodridge hoses but kept the abs working as i found that when doing high speed braking the abs combinded with this setup was brilliant! no need to worry about brakes locking up!
but it is personal taste.
nipper.1
Ford KUGA
12
30-05-2022 07:39 PM
