escort rs turbo oil light stays on
as above , it comes on 15mins after been started and goes away wen u press accelarator but comes right back on,theres plenty of oil ,changed oil pressure switch to no effect, no knocking bangs or smoke the car runs perfect, its been doing this for last two months and its doing my nut in ,the car does have sum electrics probs headlights etc, i need this light gone any suggestions plz thanks
#1 in Spelling Club
I'd say you have low oil pressure!! That's what the light is there for. LOL.
Not good I'm afraid. How old is the engine?
Oil is thicker when it's cold, so oil pressure is naturally higher and when you raise the revs, oil pressure goes up too. However, if the light is on at idle, the engine is tired I reckon. ;(
thanks guys,thats exactly wat my mechanic freind said , can the big ends be done without stripping the engine apart , like jus take
the sump off ?
the sump off ?
orion=mini saff
first change the switch and take the sump off and check the pick up isnt blocked, there the cheaper option, sadly ive had this a few times, fubard bottom end is normally the result
muz
16-08-2015 12:57 PM
sridgett
15
03-08-2015 07:26 PM
