car wont idle
car wont idle
Hi
Have recently fitted an uprated AP Clutch along with mk6 pedal & alloy clutch quadrant to my Escort. At the same time i had the flywheel skimmed, junked the ABS braking system, fitted a new Mongoose exhaust system & replaced a couple of bits n bobs like the sump gasket, rear oil seal etc.
Now the car starts and runs fine, but after a minute or two once the car has warmed up a little and the revs drop below about 1000rpm it just wont idle and stalls. Driving along the car is fine & everything is normal!
Have checked for air leaks in the obvious places btw.
Any help is much apreciated?
Zoggon
10-08-2015 10:39 AM
