PDA
View Full Version : Ford Escort RS Turbo
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107
  1. Need advice with my zetec turbo project!
  2. Would this exhaust fit?
  3. Weather strips for a S2
  4. no dash lights :-(
  5. rs turbo s1
  6. Engine worries
  7. Which CAM?
  8. Couple of questions! Frs mtx and hoses?
  9. 1.9cvh power engineering engine, gaskets
  10. price
  11. S1 what exhaust?
  12. who's got leather seats?
  13. rolling road test = not happy :-(
  14. EFI Fuel rail
  15. Oil In Header Tank
  16. Amplifier wiring - Live wire
  17. piss taking insurance
  18. Rear decal
  19. Alternator
  20. Oddkid creations
  21. weird problem
  22. Road springs
  23. Help pls
  24. Fan Wiring And Gearbox Mounts/Seal
  25. RS turbo not revving and rattleing ! HELP
  26. Mobile mechanic
  27. all new brakes?
  28. Turbo Cabrio suspension springs
  29. 2nd Silencer
  30. Oil Cooler
  31. Cambelt change (belt movement) & Tensioner Weeping
  32. few pics
  33. Tie bar bushes
  34. Possibly looking at RST tomorrow, pointers?
  35. Which cams Zetec turbo?
  36. in need of a ofac ecu
  37. Turbo heat shield socks
  38. Starter Motor Upgrades
  39. Efi cabriolet to efi turbo?
  40. Alternative to Hadrian Car Panels/Imperial
  41. Losing interest...
  42. St or rs engine in a mk4 rs turbo? Possible??
  43. Help with rear seat
  44. Series one parcel shelf
  45. S2 wpn't start after standing
  46. s2 front brake query
  47. do escort mk3 or sierra locks fit a mk4
  48. Ambers or clear indicators??
  49. t3 oil return hose
  50. rs turbo tps
  51. MFI air bleed sound when switching the engine off
  52. help needed
  53. Gearbox mount direction?
  54. bit of a long shot
  55. Anybody know anything about my S2 - History/ECt
  56. Fiesta + escort g'box mounts
  57. Weird ignition cut, coil??
  58. unsure about buying an S2 rs turbo
  59. con rod question
  60. Help Plz '88' Escort RST possible overfuelling not sure
  61. Mondeo gearbox and blacktop motor
  62. info on a rs turbo
  63. S2 central locking
  64. H24 RWT
  65. oil feed restrictor size
  66. looking for a decent
  67. Brake Reservoir (NON-ABS) still available
  68. aftermarket handbrake lever gaitor
  69. Dashboard bulbs.
  70. zetec turbo oil feed/return pipes
  71. Camshaft help
  72. will i need a new turbo housing?
  73. Fan belt
  74. Dirt and carbon build up
  75. Rad help
  76. Fuel pump
  77. Quick one on distinct or
  78. Possible air leak
  79. 1.8 zvh torque settings
  80. Escort Rs turbo show plates
  81. Radiator Leaking
  82. Turbo just gone pop
  83. help me.. f401pmo
  84. Hi every.... Erm help please :/
  85. Best way to run a boost controller into the car
  86. Master cylinder question
  87. how do i post pictures?
  88. i need a genuine escort wing mk4 please help me out
  89. Permanent damage?
  90. MK5 Pedal Conversion
  91. Gearbox help!
  92. show me cone filter on S2 EFI
  93. standard boost
  94. s2 brake problems
  95. My RST is getting hot.....
  96. standard fan
  97. Problem Cossie brake upgrade - (pic inside)
  98. Cvh S1 head - what they worth?
  99. Zetec turbo fuel pump
  100. Starter ticking
  101. s2 seat
  102. im new to the forum, bought rst last week
  103. Bottom end gasket kit - white pvc ring? (pic added)
  104. horn problem anyone help??
  105. Radiator location
  106. s2 roof arial, some have them on roof, some dont
  107. A few pics of my s2
  108. Side Mouldings
  109. Turbo question - is mine knackered?
  110. Broke the 13 second barrier!!!
  111. Cylinder head - short side radius exhaust
  112. fan over ride
  113. electrical problem
  114. rs2000 engine in my mk4?
  115. what to do with the S2
  116. Fuel problem
  117. Fuel
  118. Fuel metering unit
  119. few pics of my s2
  120. sounds like crap
  121. Pilar pod
  122. Alcon 6 Paddle
  123. DESPRATE !
  124. Black top water pump hitting inner wing!
  125. S1 MFI to EFI conversion???? NEED HELP!!
  126. 1900cvh
  127. oil pick up pipe cvh
  128. S1 kit on Mk4??
  129. Help please!!!
  130. 3" mongoose ?
  131. Bonnet catch
  132. Heater
  133. Single SPAX Adjustable Shock
  134. Timing belt removed, crankshaft pulley at 16
  135. oil pressure gauge problem
  136. What linkage for rod change mtx??
  137. will any glue do ?
  138. green knock sensor thread size anyone?
  139. 335mm front brakes
  140. Can anyone. . .
  141. Gearbox rst
  142. EBAY rs turbo fuel pump any good?
  143. Door leak
  144. Door leak
  145. Can any help?? I need a pair of mk4 rear quarter window rubbers ASAP!
  146. Rear wishbone
  147. Gearbox Seal, Fan Wiring
  148. forged piston/rods
  149. actuator choice.
  150. Jenvey plenum.... any one fitted one?
  151. Act gauge question
  152. Escort Rs won't fire
  153. Leads to distributor HELP Escort MFI Turbo
  154. Mint 90 spec seats
  155. Mist washer jets
  156. ford racing water temp gauge
  157. New inlet!!
  158. oil in intercooler blue smoke
  159. Help with tyre choice/suspension S1 Rst
  160. Help with tyre choice/suspension S1 Rst
  161. replacing piston rings
  162. How hard is it to get a MINT shell these days?
  163. my s2 project engine bay
  164. Tubular Manifold
  165. MS Users - Rising or Falling Edge?
  166. turbo and missfire help needed, :(
  167. lambda boss
  168. clutch and gearbox
  169. idle problem rst s2
  170. Are they worth it?
  171. Anyone help me find out what i need for this ?
  172. Can anyone tell me what this is?
  173. Igintion barrell removal Series 2
  174. What holds the side skirts on s2?
  175. s1 rst radiator
  176. Pressure in header tank
  177. secs style monitor for ofab?
  178. do 90spec's come with a fuel computer?
  179. what oil for standard engine?
  180. Idle control valve
  181. Metal fuel pipes
  182. anyone have info on h678 erl
  183. temp Gauge problem
  184. no power at heater control
  185. What to do with my engine
  186. Best turbo upgrade??
  187. Rear speakers.
  188. Cvh block/zetec head
  189. mk4 Carbon fibre Door cards
  190. Turbos. Water cooled or not? Which Is best
  191. S1 internal door lock issue
  192. external wastegate problem FIXED
  193. P8 ecu with collins board
  194. Dismantling bonnet latch
  195. s1 escort pedal box
  196. Converted to EFi having a few troubles
  197. S1 2.0 Zvh radiator question
  198. Helix clutch
  199. Fuel pump question buzzing constantly
  200. My Series 2 rebuild
  201. few pics of mine and matts red s2's
  202. Picked up my s1 today ;)
  203. Pictures of Grey S2's please
  204. measurement please
  205. Cosworth management help ... Please ..
  206. exhaust manifold gasket
  207. 1900 cvh bottom ends
  208. Blanking Plugs
  209. Water system problems
  210. any zvh turbo how to guides
  211. Pair of Ford Escort/Fiesta spot lights
  212. IAT sensors question
  213. RS turbo in mexico
  214. Clutch Cable.
  215. red rst e823 osg
  216. S2 pics of relay box please
  217. FINALLY
  218. Spacer size for rear cossie calipers
  219. Will these fit mk3 escort?
  220. group a coil and loom
  221. cvh tuning
  222. Part number help
  223. Standard air box any one have one for sale?
  224. Roof lining re spray
  225. ZVH Headgasket
  226. Fuel Tank
  227. What part/mod have you do to your car...
  228. turbo faq
  229. Brake Pipe Clips Part Numbers
  230. Cosworth inlet on a CVH?? Link provided.
  231. Zetec turbo oil pump help! with pics!
  232. S2 no spark, no signal to injectors
  233. Part number for fuel filter banjo bolts??
  234. rs master question
  235. What suspension do you have fitted to your car?
  236. Newman Solid Lifter lock nut size
  237. Coil pack plug leads
  238. hire of series 1 escort rs turbo
  239. Picked up a 1984 s1
  240. WHERE can i get carbon door handles
  241. rs turbo electrical problems
  242. Water pressure
  243. escort rs turbo s2 help
  244. Zetec turbo compression ratio help needed!
  245. windscreen rubber ??
  246. Oil pumps
  247. no fuel to 1 injector
  248. bumpers
  249. Query on Series 1 rs front headlights
  250. Looking for 3 or 4 spoke steering wheel where have they all gone
