- Boost hoses
- FRST fuel rail
- injector question
- Best OEM brakes under standard rims?
- S1 left hand drive
- name that wire dash wiring help!
- Monroe sensatrac
- What tank is this?
- efi mfi tps sensors and omex question
- fitting coilovers
- Tracking down a s2 escort
- exhaust rattle?!
- What turbo ?
- s1 and s2 hoses
- Compression test results - Not good :o(
- Cosworth inlet on cvh head??
- poor running
- Zetec turbo gearbox and clutch
- Starter motor thread again..
- Good Reasonable bodyshop!
- any one know this car
- cambelt cover onto ZVH?
- sump
- Can any 1 identify this turbo for me?
- bonnet won't open!!
- jamsport downpipe
- The comedy car now with rs2000 engine +nos
- what other door handles fit the escort rs??
- Breaking
- Cold start problem, lumpy
- cutting out sometimes when slowing down
- Lots of photos and questions - Please help
- probs been asked loads of times lol arp torque settings
- anyone scrapping a sunroof model mk 3-4 escort ???
- Is this the right head gasket
- headbolts
- im stuck,quick help needed
- wossner CR need help
- s2 heater box
- does your rst hve wastegate chatter ?
- Dumpvalve blanking plug?
- Cossie rear caliper rebuild
- Burton power alloy rocker cover
- oil filter
- CDF Discount!
- Discount Anyone?
- s1 and s2 turbo/manifold differences?
- Sounds mint.
- what a collection !!!
- water swirl pot
- What plug gaps?
- 1800ZVH build threads?
- ZVH injectors
- K&N and heat shield
- Turbo compresor strange set up!
- Classic insurance
- Standard swirlpot to headertank hose?
- ANYONE no if this head gasket set any good???
- Track control arms.
- back on the road white S2
- Mk3 five door fuel tank
- zvh oil and filter
- Scuttle panel - Do you have to take the wings off?
- zetec breather setup
- Leakdown test, where?
- Idlevalve check efi
- oil pressure????
- S2 rear brakes
- Best oil for 1800 ZVH?
- Hmm can this work?
- Had a great idea....
- turbo oil return hose
- rs turbo/bonus steering problem.
- Running on 3 cylinders.. diagnose/advice?
- can someone please advise me on what suspension is best for my series1 rs turbo
- Headgasket
- Few n00b ZVH questions
- Water temp sensor
- Anyone know anything about this company?
- Brand new header tanks?
- how many black s1 where made ??
- my new toy
- Where to mount a oil cooler?
- Mk3 five door
- S2 mtx selector cables
- no battery light
- are 2.0 black top con rods same as the 1.8 rods
- Brake Compensators / ABS Removal
- Got some new wheels for the s2 ;)
- low compression
- Overheating ?
- Euro optional extras
- aftermarket gauges probs
- Rear disc kit
- B+M shifter strong vibrations, clutch judder!!
- fuel pump
- Zetec cams
- How much for
- bad starting when hot
- s1 rs turbo wanted
- best way to sell an rs turbo :(
- More Power?
- Engine temp Sensor on ebay
- OFAM ecu Any comments?
- Pressure plates
- S2 speakers
- Which turbo for efi turbo xr3i
- what clutch?
- S1 metering unit vaccum pipe outlet to amil valve?
- strut brace
- back wheels clunking
- s2 boot struts
- Can a 1.8 zetec be bored to 2ltr?
- Ford Escort RS 2 Full Resto - My first attempt
- Bonnet alignment
- GPA coil rewire loom
- fuel rail quip fitting
- do you know this car
- ZVH starter motor
- efi throttle pedal and cable
- Quick EBC brake pad question
- Interior Light (bulb type?)
- Series 1, L6 with w/s Rev counter help required.
- megasquirt loom protection
- no speedo????
- S2 f200 tel
- Ford PCD?
- roof question
- s2 metering unit
- Stage 3 t3
- Ha my car damaged
- 3dr cossie rims on rst...
- S2 bumper/ rs500 splitter
- Speedo sensor removal
- no fluid at rear drums??
- blacktop alternator setup?
- s*#t heaters??
- Aftermarket Tacho In standard location
- cold start sensor
- escort temp sensor
- fuel pump always priming
- indicators
- RST relay questions
- MFI Fuel Pipes
- Replacement wheel bolts.. With link...
- Cold heater
- Front Wiper Arm Nut Covers
- unplugging ecu ofac
- dodgy starter?
- Cooling Sysem Upgrade.
- Uprated GPA coil
- chargecoolers...
- Boost Pressure PROBLEM!!! HELP!
- What drop?
- Fitting Brembo's?
- Picking my s2 up saturday :)
- ebay help
- Rs onion getting hot.
- Gear Change pops!?
- MK3 Escort in Restoration project rs turbo conversion
- Looking at buying an s2
- Forged Pistons
- Just brought myself a nice 90 spec :) (now with pics)
- Spraying the underside after wax-oil?
- mates escort rs turbo keeps cutting out?
- what is the best head gasket to use 4 a escort rs turbo s2 engine 200 bhp plus
- What is this
- where to get a new standard cam?
- s2 fuel gauge problem
- Fitting S1 arches and skirts to my S2
- 3i to turbo
- people who have converted to efi
- Shropshire rs owners
- sitech headbolts zvh
- EFI block
- people with carbon roof/welded sunroof help please
- Cossie 4 pot calipers
- Mk3 ghia 5dr brake upgrades
- Xr3i masters
- ZT Thermostat Housing
- Best spark plugs??
- Modifying Bailey Breather ?
- 1.8 bottom end for goin zvh
- S2 RST Springs in an Estate?
- Cutting out problem
- Bosch thermo-time switch.
- S1 Drivers door won't close!
- buying a black s2 rep xr3i mfi cabby very soon!! what to do with it
- Best place for exhaust wrap?
- New metering unit
- set up?
- sunroof tray
- LSD?
- Piston identification,
- finnis number?
- Deposit put down on Series 2
- What bushes?
- anybody know what spec turbo is?
- monroe suspension
- Rebuild panels
- best way to take the engine out
- want polybushs, where from
- Ford racing temp gauge
- miss fire
- battery tray welding in essex?
- ib5 gearbox
- Rear Cossie brakes on s2
- Rear disc conversion
- clutch
- Not having a good day
- Fitting cossie plugs to a zetec head
- Cleaning samco
- What colour for underneath of grey S2 RST
- my brand new alternators charged at 16-19v! swapped it for another one n stil same???
- xr3i brake servo reservior bigger than the rs turbos?
- non abs reservoir
- MFI to aftermarket enginemanagement conversion
- master cylinder
- powerband
- oil pressure and temp
- Best tuner / set up in Northwest??
- Parts
- Sump sealant
- Engine swop
- series 2 fuel problem
- st170 calipers
- ka pulley on rst
- Rover inlet manifold
- What clutch?
- Cold start valve..
- Need help
- Anybody Got An RS Turbo LSD Gearbox For Sale ?
- xr2i efi crank
- Newman cam question
- HIDS
- bosch mfi metering unit help?
- front outer door weatherstrips
- twatting spax top nut??
- Is this the clutch? Pressure plate? Or release?
- just bought a white series 2 any ideas?? now with pics!!!!!!!!
- Rebuilding metering unit
- St170 conversion?
- braided brake lines
- fans?
- smoking rs turbo
- is it legal?
- coolant temp sensor
- Brakes
- rebuilt it and now running rich
- New engine pics, and some different questions :)
