Cold heater
01-02-2012, 09:38 PM
Cold heater
Right, my s2 heater is rubbish and is only blowing a small amount of heat.
It also squeaks when I put them on and when I had a look the drivers footwell had a bit of water?
Matrix? If so what's the instructions for taking it out and changing
01-02-2012, 10:07 PM
03-02-2012, 06:18 PM
My temp goes to half way when ticking over but while driving it goes right down. Will this matter?
03-02-2012, 11:02 PM
Is the thermostat fitted?
03-02-2012, 11:42 PM
Quote:
Originally Posted by
studabear
Yea it is fitted. Just seems like the cold air keeps it really cool
03-02-2012, 11:52 PM
04-02-2012, 12:07 AM
It has a 82 deg thermostat fitted
04-02-2012, 10:57 AM
Sounds like a faulty thermostat causing the heat issue (Stuck open)
Martin
04-02-2012, 06:50 PM
martysmartie
Martin
Will that affect the heating? Like right now the temp is half way but the heaters are a tiny bit hot. If I drive the temp goes down but the heaters will still be as rubbish
04-02-2012, 07:28 PM
Yes the heating system is an extension of the cooling system, so if the engine is not reaching normal running temperature the heater will mirror this.
Martin
04-02-2012, 07:35 PM
But I'm guessing its something else as even with the engine hot the heaters are still cold. Might try changing the matrix I guess
04-02-2012, 07:42 PM
You could try flushing the matrix as that may be blocked, but if it's that causing the leak, then it will need to be replaced anyway.
Martin
04-02-2012, 07:55 PM
05-02-2012, 12:40 PM
rs turbo from Greece...
mark94
Ford Mondeo Including ST
10-10-2023 06:52 PM
A.t.p
23-10-2015 07:54 PM
mk1focus
Ford Fiesta
24-09-2015 06:19 PM
Flatlinedan
18-09-2015 12:41 PM
wheelwizardrefurbs
05-09-2015 10:52 AM
