series 2 fuel problem
Old 18-01-2012, 07:45 PM
Ronaldinio
Ronaldinio's Avatar
Default series 2 fuel problem
Hi,new to passion ford so hello to everyone.no fuel to injectors unless
meter flap is pressed down,checked fuel pressure ok can anyone shed
any light on this problem.Cheers
Old 19-01-2012, 01:37 PM
Karlos G
Balls Deep!
Karlos G's Avatar
Air leak most likely (breathers, breather filter, oil cap, dipstick, rocker cover gasket, etc.) or the idle mixture screw needs adjusting in.
Old 19-01-2012, 06:40 PM
Ronaldinio
Ronaldinio's Avatar
Cheers mate will try what you said,also been told to unplug fuel ecu and pressure actuator
will post results.
muffster
13
03-09-2015 09:40 PM
Sheepdisease
30-08-2015 09:11 PM
mickparky81
Ford Focus ST
30-08-2015 06:58 PM
Stu @ M Developments
41
21-08-2015 06:47 AM
dlwarrior
05-08-2015 10:19 AM
Quick Reply: series 2 fuel problem
