LSD?
Im sure if u spin the pot where driveshaft sits in gearbox then the other side should spin opposite way?
Im not 100% on this n not sure if u can just jack front up and turn engine over both wheelssides will spin opposite
Im not 100% on this n not sure if u can just jack front up and turn engine over both wheels will spin opposite ways
Look through the drive shaft hole if you see a bar going across its an open diff if you can see what looks like a washer in there its a lsd box
Jack the car up with BOTH wheels off the ground, make sure it is in neutral then spin the one wheel. If the other wheels spins the same direction then it has a LSD.... not to be confused with LSD tabs
TPM961
Jan 15, 2018 10:50 AM
155lee
Oct 24, 2015 11:11 AM
