OFAM ecu Any comments?
Old 09-02-2012 | 08:00 PM
jan247uk's Avatar
jan247uk
SE500 All Blue
Default OFAM ecu Any comments?
whilst looking at efi conversion posts i came across the boost monkey site link they have developed an OFAM ecu
http://www.boostmonkeys.co.uk/products.html
any comment on if this will be any good?? or has anyone got one fitted allready
Old 09-02-2012 | 08:24 PM
mk1turboestate's Avatar
mk1turboestate
iv just got mine mate, looks good, will have it fitted in the next month hopefully, send them an email and you will be sorted out, or pm rob_dohc on here about it
mine came next day delivery really well packaged,
Old 09-02-2012 | 08:27 PM
studabear's Avatar
studabear
rogeyboy has 1 on his turbo onion
Old 09-02-2012 | 08:38 PM
CasperR's Avatar
CasperR
Got it, read the manual, checked all the settings etc, and it fired up witout much hastle.
Very nice product and easy to map, if you read & understand the megasquirt manual
Definitely recommended
Old 09-02-2012 | 10:28 PM
jan247uk's Avatar
jan247uk
SE500 All Blue
is it a direct plugin to the efi loom to replace existing ecu or do you have to make up a loom
Old 10-02-2012 | 07:06 AM
Rogeyboy's Avatar
Rogeyboy
Its a direct plugin to the existing EFi loom... If your MFi you will have to source a loom or get boostmonkeys to make you 1 up!
I think its wicked as casper said, opened the box, plugged it in, checked 1 or 2 setting and turned the key and it started up lovely. Easy to Map and play around with.
My car has been off the road longer than i intended but in the next month or so i intend to go balls deep into the mapping and really explore the ecu and its functions!
Old 10-02-2012 | 04:24 PM
martinmilne's Avatar
martinmilne
Will be getting one in next few weeks been speaking to rob very helpful bloke and seems a great product
Old 10-02-2012 | 06:15 PM
jan247uk's Avatar
jan247uk
SE500 All Blue
sounds good will be on my things to buy list then
Old 10-02-2012 | 06:30 PM
danielson04's Avatar
danielson04
Actually thinking about efi'ing my van now and getting one of then after reading about it. Quality bit of kit by the sounds of it!
Old 25-02-2012 | 10:31 AM
Maxwell's Avatar
Maxwell
Irregular Poster
any more info or opinions on this?? im considering buying one, but want as much input from others first
Old 25-02-2012 | 05:10 PM
studabear's Avatar
studabear
I've just got mine running on megasquirt, loom took a while to construct, so If you've got the option of plugging a ofam into your existing loom its gotta be a winner, I would have a good check over of your loom though.
Old 25-02-2012 | 11:30 PM
jan247uk's Avatar
jan247uk
SE500 All Blue
looks like the ofam ecu is based on the megasquirt 2 ecu so seems a winner all round
Old 05-06-2012 | 03:46 PM
Ben26's Avatar
Ben26
I'm looking into this ecu now. I'm guessing it comes with everything to map it ? Can it do live mappingso all I need is a laptop yea ?
Old 05-06-2012 | 05:04 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Laptop, WBO2 and Det Cans...
Old 05-06-2012 | 05:18 PM
Ben26's Avatar
Ben26
what have u done for det cans ? home made jobbies ?
Old 05-06-2012 | 06:51 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yes mate.
Old 05-06-2012 | 08:21 PM
wedge07's Avatar
wedge07
How u make them, got my ecu ready to go on my revuild
Old 06-06-2012 | 08:33 AM
s2erst's Avatar
s2erst
Ive got it on my 2.1 zetec an love it just plugged straight in an mine fired right up no problem at all an as said above rob is very helpful if you have any Q's he will talk you through it
Old 07-06-2012 | 01:47 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Old 09-06-2012 | 05:40 PM
martinmilne
just got mine fired up today started 1st time rob has been very helpful (thanks Rob) just shame im slow and thick trying to work out how it all works now and how to tune it as i have no idea at moment
Old 11-06-2012 | 12:24 PM
chrisxr2it3's Avatar
chrisxr2it3
What injectors,map sensor ect do u use with the ofam ecu I'm currently using ofab with custom msd chip,bieghs,t3 would I see a big difference in the way the car drives an performs?
What sort of power/boost does it let u run
Thanks Chris
Old 11-06-2012 | 02:24 PM
studabear's Avatar
studabear
It will have a internal map sensor in the ecu, you can use any high impedance injectors you want really, its a plug and play megasquirt ecu
Old 14-06-2012 | 04:21 PM
gingeRS's Avatar
gingeRS
whats the advantage of it?
Old 14-06-2012 | 05:02 PM
CasperR's Avatar
CasperR
Plug and play megasquirt setup basically.
It gives you a mappable ecu at home. Ideally if you always wanted to try it yourself, or like me, havent got anyone in the country who can map ofac.. Plus you are saving money everytime you put something new on the car, and will be able to change the map to suit.
Old 15-06-2012 | 10:16 PM
AstoN_B's Avatar
AstoN_B
An eye for detail...
What a good idea. Would have been perfect for my efi xr3i.
Hoping they put efi looms up on website soon cause its on the cards when I buy an RST.
Old 19-06-2012 | 07:14 AM
Rogeyboy's Avatar
Rogeyboy
I wish i'd have put one on my Orion before it was turbo'd to squeeze the most from the NA EFi 1.6cvh i had in there!
Old 19-06-2012 | 07:21 PM
Gadget's Avatar
Gadget
Spanner monkey
Anti lag option??
Old 19-06-2012 | 08:09 PM
AstoN_B's Avatar
AstoN_B
I'm guessing you'd need a few extra pins putting in the factory loom for it but I'm sure mega squirt is capable of it?
Old 19-06-2012 | 10:25 PM
s2erst's Avatar
s2erst
when i spoke to rob about anti lag he said he was working on it
mark94
Ford Mondeo Including ST
10-10-2023 06:52 PM
griffo69
04-10-2015 11:58 AM
IainRS1700T
25-09-2015 06:44 AM
DixieTheKid
14-09-2015 09:04 PM
bigryrs
07-09-2015 06:45 PM
Quick Reply: OFAM ecu Any comments?
