fuel pump always priming
not sure if my car is meant to do this but as soon as you turn key fuel pump primes like its meant to but keeps on doing it, on my other rs after 3/4 seconds it stops
Hiya mate,
If it helps standard OFAB/OFAC just primes the pump then cuts out after 2-3 seconds. It sound's like you have a stuck relay or some bad wiring. Earthing the fuel pump wire from the ecu will turn the fuel pump relay on. I take it that it doesn't do this with the ignition off? PM me if you need a hand / wiring diagrams. From memory the main relay feeds 12v to the fuel pump relay, its common for people to bridge the fuel pump relay if they get problems (so its on all the time).
Rob,
Rob,
Hiya mate,
Rob,
Rob,
Hiya mate,
Rob,
Rob,
Is it an escort with fiesta rst engine fitted, if so it may be wired similar to mine via two yellow relays. It may just be slightly wired wrong?
ive had 12 rs turbos an this is the only one to ever do it thats why i knew it wasnt right. yes it is an escort with 2.1 zetec lump using megasquirt
Just PM'd you mate, but if its doing it with the old ecu and the new one its a wiring fault.
Its not a big deal tbh unless you sit with the ignition on, the problem is that with no inlet manifold vacuum the fuel pressure reg raises the fuel line pressure to around 4bar, in the past i have had a leak caused due to the higher than normal pressure, but with decent lines and fittings this shouldn't be a problem. The fuel pump will also have a shorter life as its on constantly regardelss of whether its needed or not.
Its also not as safe, if you have a crash and the ignition stays on but the engine stops currently the fuel pump will remain on, if all the fuel lines were ripped off the car during the accident you could potentially pump fuel all over the road etc, which is obviously not safe!
But your car will still work,
Its sounds like the ignition relay has been used to power the fuel pump? rather than using the fuel pump relay.
Rob,
Is it a problem if the fuel pump relay is constantly priming? Mine is
![](http://images.ibsrv.net/ibsrv/res/src:passionford.com/get/forum/images/smilies/bigcry.gif)
Rob,
i have braided fuel lines don't know if that would be able to handle the pressure. its been fine when I've driven my escort in the past but the fuel pump did cut out on me once when I was stuck in traffic on the motorway. I had to bridge a wire on the fuel pump to get it working. Where is the ignition relay and how can I sort it?
It's not particularly a big issue, any excess fuel will just go via the return line, the fuel pump runs constantly when the engine is running anyway, it's better to just prime though really.
It makes no difference what so ever in an accident if the pump runs on ignition or not, the power will still be cut, unless someone has bypassed the inertia switch!
Martin
yam yammer
Encase you missed this, someone has grounded the relay, opposed to wiring it to the ECU.
Martin
Martin
Ignition relay is irrelevant.
If yours runs constantly you have the same issue as the OP, i.e. it has a permanent ground, if yours is standard and so MFI, the "Speed sensing" module is what keeps the relay closed when the engine is running, this does not apply to OP as he will have aftermarket management.
Martin
ok got some pics - this is just purely to show how I got my fuel pump to work when I was stuck in traffic and my escort cut out - It cut out because my fuel pump wasn't priming when turning the ignition.
*Edit* It was just a quick fix until I got back as I was 100+ miles away from home. I dont know what my mate did to sort it but he fixed it the same day I got home
It still runs constant now![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
![Name: SDC17032.jpg
Size: 103.9 KB](https://passionford.com/forum/attachments/ford-escort-rs-turbo/139439d1501884623-fuel-pump-always-priming-sdc17032.jpg)
Can you see the wire bridging the 2 across
![Name: SDC17030.jpg
Size: 130.4 KB](https://passionford.com/forum/attachments/ford-escort-rs-turbo/139440d1501884623-fuel-pump-always-priming-sdc17030.jpg)
![Name: SDC17029.jpg
Size: 95.6 KB](https://passionford.com/forum/attachments/ford-escort-rs-turbo/139441d1501884623-fuel-pump-always-priming-sdc17029.jpg)
I'm running mfi and I replaced the fuel pump with a brand new one from speedshack it cost me £40 - I remember because I was shocked at how much it was for a bloody relay!
Like I say due to expense, that is why some people don't bother and bodge them!
I suspect what he has done is fit a cheap SPST relay and permanently ground it, which is the totally wrong thing to do, simply replacing with the correct relay would have sorted the problem.
Martin
Martin
my relay has just packed up. bridged the relevant wires to confirm it was said relay. seems a common fault on a 20 year old rs turbo. just ordered one, £46!!! still, at least its right. am i right in thinking the relays job is purely to supply the fuel pump with a signal telling it when to pump juice? ie at start up and as and when it need during idle? just because on start up it would prime, then the pump would run constantly until ignition is killed. was never a problem when the relay was working.
When the engine is running the "Speed Sensing module" keeps the relay closed with ignition pulses and thus the pump runs constantly.
Martin
JK12
33
26-04-2021 12:09 PM
DixieTheKid
11
06-06-2020 11:20 AM
wheelwizardrefurbs
23-09-2015 09:21 PM
wheelwizardrefurbs
18-09-2015 08:59 PM
