PDA
View Full Version : Ford Escort RS Turbo
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 [99] 100 101 102 103 104 105 106 107
  1. RS OWNER AT LONG LAST!!! ;)
  2. engine wiring
  3. question on fuel filter removal/refit....
  4. S1 Front washer fluid bottle Q
  5. polybushing rear wishbone
  6. Collapsed jacking point
  7. Gear linkage?
  8. S1 Interior Pics Sorted At Last!!!
  9. Help me find some wheels for my rs turbo
  10. Pics of my S2...Just about done!!..
  11. Gearbox Oil?
  12. What Yous Think?
  13. Restoring My S2
  14. click for cheap coloured dials
  15. MFI to EFI conversion - Fuel tank question
  16. will a cossie t3 turbo fit on my s2?
  17. Someone pls give me a pick of fuse box
  18. Series 2 RS
  19. New Alloys = Odd Noises
  20. How hard is it....
  21. how much for a turbo rebuild?
  22. i think my turbo's on its last legs help
  23. swirl pot
  24. RST CVH goodies compatibility?
  25. how to adjust koni adjustables???
  26. s1 0r s2
  27. Series1
  28. what size tailpipe on my s1 3"OR 3.5" ?
  29. how fast does a s2 go at rev limiter in 5th gear
  30. What offset wheels do i need with 2wd cossie brake set up?
  31. any info on series 1 B144 EHK
  32. MFI idle co adjust guide?
  33. Weird starting question............
  34. Must be the lowest mileage s2 in existent
  35. need a new turbo, what do you think of this..........
  36. how do i get......
  37. can anyone help?
  38. Thanks to Christian and Gary @ APT
  39. Jacking up a S1 Question
  40. Post piccys of your S2 RS Turbos
  41. Heated Front Screens
  42. series 1 wheels what 17s look good
  43. Maximum BHP on S2 ERST
  44. who's been in a s2 zetec turbo then ?
  45. does anyone??
  46. still no luck
  47. New engine build over the summer, which one ????
  48. Any such thing as a none welded rs turbo?
  49. S2 Running problem!!
  50. Anyone know where i can get my s2 rocker cover powdercoated
  51. fuel pump prob???
  52. rev limiter
  53. ERST S2 HEAD GASKET??? FORD ONE BEST..
  54. Smoking?
  55. how rare is an 88 erst with 2 previous owners
  56. Find Dan an S1
  57. work to fit 17`s???
  58. rst turbo wanted
  59. Sparking on No.4 only - cosworth management
  60. what will a std s2 cost me?
  61. does anyone know if the gearknobs from the new focus......
  62. any 1 got a black bonnet for sale?
  63. my s1
  64. Amal Valve connect ERST.
  65. will escort cos front calipers/disks fit on a s2?
  66. moving
  67. Turboing a zetec?
  68. ecu `s????
  69. A piller gauge mount
  70. My S1 *pics inside*
  71. Benefits of an uprated breather system?
  72. White ERST?
  73. Whats the difference between the Turbo's on a S1 and a S2?
  74. Wanted - Original Series 1 Stereo - Analogue or ECU1/Digital
  75. escort rs turbo wanted
  76. diamond cut alloys?
  77. turbo wanted
  78. s1 chipped ecu problem
  79. CAN I RUN A S2 ECU ON MY S1
  80. erst Inlet manifold connections - please confirm?
  81. clean as a whistle
  82. Spoiler Caps still available?
  83. RS 7 Spoke alloys
  84. s2 sump gasket
  85. S2s with chrome cages...
  86. What wheels are they .............
  87. TT STAGE 2 HYBRID ANY GOOD FOR MY CAR?
  88. S1 RUNNIG PROBLEM HELP??????????
  89. Best Engine Mounts for a S2???
  90. Heater Matrix?
  91. s1 fuel relay bridging
  92. water temp ???
  93. Would you buy a Series 1 without any history?
  94. Ok. Series 1, stars - runs for 3 secs dies.....
  95. Anyone got a Zoo front link kit fitted??
  96. 2 Questions!!!!
  97. S1 Heat issues original airbox/K&N cone
  98. air leak under inlet manifold any ideas
  99. Wheels
  100. Ive actually took some chrome off my ERST!!!
  101. anyone running saab turbos on their s2 ?
  102. Radiator
  103. Ultimate tyres for RST?...
  104. WHAT IS THE MOST BHP YOU CAN GET ON STD ERST INJECTORS??
  105. How many Series 1's were made?
  106. best gearbox to go for?
  107. how can i make the fuel pump stay on ? +oil light not workin
  108. thinking of selling me car
  109. rst runs ok but dont like starting when hot ?
  110. what oil pump for a 1.9 erst??
  111. S1 and S2 fuel pump relays...
  112. Zetec!!!! Whats your spec?
  113. Best suspension for mk4 Escort Cabby?
  114. Found this site if anyones interested on what.....
  115. Anyone got any series 1 spot light fixing brackets
  116. RST opinions........
  117. what to look for when buying a rst
  118. Just wondering...
  119. car judder.
  120. exhaust rubber mounts for s2.. whats best???
  121. S1 Towing Eye Cover
  122. Myth or what?
  123. Uprated Fuel Pump for a S2
  124. SPEEDO DRIVE GONE!!!!!!
  125. rs turbo engine rebuild
  126. why use dark greens on a cossie loom conversion????
  127. Losing water
  128. Starter Motor Heat Shield
  129. Quick yes no answer needed!
  130. S2 Starting problems
  131. PRICE IT
  132. my car wont tick ova when cold?????? help!!!!!!!!!!
  133. Fuel Computer?
  134. Gauge Pod
  135. URGENT PIC REQUEST?? WHAT WHEELS??
  136. what cam for my ERST? piper 285T2 any good?
  137. abs (orange) light
  138. cutting out
  139. What Thrmostat
  140. S1 Centrecaps
  141. s1 wont start!!! (WELL IT DOES NOW YWHAAAAAWHOOOOOOOOOOOOOO)
  142. S1 C126 LEG
  143. S2 90 spec Fiberglass rear spoiler??????
  144. mongoose zorst system?
  145. Bigger throttle
  146. 2wd cossie discs onto erst
  147. MY OLD RST
  148. Wanted - Rear bumper overriders for Series 1
  149. Std ride height?
  150. T3 stage
  151. new mk4 headlight protectors..£25
  152. S2 'Box
  153. Turbo n cams
  154. 4" mongoose or 4" scorpion ?
  155. Best Oil For RST
  156. Got one of those G-Tech Pro meter things!
  157. Full set Samco boost hoses anyone?
  158. engine removal
  159. Bleed valve - How much to turn?
  160. brake warning light staying on!
  161. My cars in the rs turbo collectors special!!!
  162. Bleed valve or Amal valve????
  163. Original RS Series 1 Stereo....
  164. TURBO HEAT WRAP
  165. uprated breathers, vent to atmosphere ????
  166. fuel computer
  167. How to check for updated ECU/Superchip
  168. Series 1 front spots
  169. When do I need a 5th injector setup
  170. gearboxes
  171. UPRATED BREATHER ??
  172. WHERE CAN I ?
  173. RST Exhaust pop???
  174. read this!!!im in total shock!!!
  175. managment system
  176. wanted series1 rs turbo
  177. rs turbo badge
  178. Chipping advice
  179. RST BIBLE pf
  180. ME 1 GOT NE VIDS OF ALEX ZVH CABRIO?
  181. 90 Spec Bumpers and Spoiler?
  182. New Clocks
  183. Does this sound right?
  184. Spotlight stickers
  185. bailey venturi
  186. What would happen?
  187. Adjustable track control arms
  188. HOW DO I FIT A GRS INTERCOOLER?
  189. S2 ROLLCAGE
  190. Pictures?
  191. How much should i pay.....
  192. s2 radio wiring diagrame
  193. Question about Performance Ford RS Turbo collectors special
  194. Series 1 stickers
  195. rear 90 spec spoiler
  196. What do you lot think of these tail lights on a s2
  197. my s2.....
  198. Grey S2 In Haxby, York
  199. Dying S2 :(
  200. TO EFI OR NOT TO EFI???????
  201. Anybody know B389 XUW ?
  202. what a pooo day
  203. Page 70 this months Fast Ford
  204. s1 power
  205. 'heated seats' fuel fuse ?
  206. WHAT CHIP?
  207. What power to expect?
  208. filler cap,if taken off it cuts out?is this good or bad?????
  209. Wanted - Nice to Mint Series 1 RS Turbo - cash waiting....
  210. Mobile mechanicc needed
  211. BLEED VALVE HELP
  212. New S2 Clocks?
  213. S1 RUNNING A BIT DODGY
  214. Starting Problems
  215. Wheres best place to mount an aftermarket oil cooler on a S2
  216. Head gasket gone
  217. Mint series 1 Please...........
  218. the age of the S1/S2 driver???????
  219. Anyone know anything about an amal valve?
  220. SHE CAME BACK TO LIFE TODAY!!!!!!!!
  221. MY S2 ERST PICS
  222. cvh 37 kent cam
  223. rs exhausts, std v's perf
  224. REAR ARCHES
  225. Brakes.....help please
  226. Whats the purpose of the air temperature sensor on the...
  227. brake light
  228. Another silly series 1 question
  229. 90 spec recaros
  230. digital water temp gauge, correct wire for temp sensor ?????
  231. Series 1 side wing indicaters whats the score??
  232. alarm
  233. caliper/wheel clearance
  234. Wanted - Series 2 pedal box
  235. Ht leads
  236. 1800 CVH
  237. Opinions please
  238. 4 pots on s2
  239. whats this?
  240. come on then whats yer dream/intended specs
  241. Lumpy/Cutting out S2
  242. hi spec big brake conversion
  243. chatter, s2
  244. s1 dash
  245. HOW MUCH FOR THESE PARTS TO BE PAINTED !!!
  246. going over to cossie managemnet
  247. Updated pics of my RST 24/02/2005
  248. S2 Intercooler on S1
  249. EFI or MFI????
  250. s2 breather system.......help!!!
