question on fuel filter removal/refit....
Just a quick one really...
Are they pressurised and if they are how do i release the presurre b4 undoing the fuel lines from it?
you can either just undo the banjo connecters and just let the fuel leak away or slacken the cold start injector and this will do the same. easy really,the fuel accumulator will build the pressure back up when you turn the ignition on!!
JK12
33
26-04-2021 12:09 PM
