Brakes.....help please
Right I need advise/help on up grading my brakes so please post your opinions on what to use ie st170, cossie, Ap/Brembo ect
I've 17" Wheels
I've 17" Wheels
depending on what wheels you have i would go for some AP 330's.
another option would be brembo calipers[focusRS/evo/fiat etc] and get some bells and brackets made up.
Think I may have just got some ST170 Calipers/hoses/and fitting stuff
All I need are BIG disks ...... Whats recommened??
I've got a set of Wilwood 4 pots with 300mm discs on alloy bells on the front of my S1; i've just got to put them on now !!! Will let you know what they're like.
RegardS
James
RegardS
James
Quick update.... Got my st170 calipers the lad gave me the 300mm disks too for free only prob is ones meant to be warped Still sorted now
That'll be me
I had really bad vibration which is why was going to change the discs (but went fitted brembos instead )
It was the offside disc which was warped and it was pretty bad to be honest...( it might be possible to get it skimmed up??) I really don't know. Worth a try though which is why I thought you may want them
Hmmmm Are you getting any vibration at all? I know about the chunks missing out of the back which is what I thought may have caused the vibration.
I've fitted my new brakes and is cured the vibration I was getting
Originally Posted by Twins
st170 is Easy mate ,just a couple of 10mm spacers
A very cheap effective conversion. I would say that you would be better off getting original discs as some replicas are very prone to warping
Dave
