my car wont tick ova when cold?????? help!!!!!!!!!!
Old 12-03-2005 | 08:40 PM
lockesRSparts's Avatar
lockesRSparts
Default my car wont tick ova when cold?????? help!!!!!!!!!!
my orion turbo (escort running gear) starts fine in the morning but wont tick ova & is abit jerky on low revs??????? but 2 min down the road when the engine is alitle bit warm its perfect???? any idears??????????
i disconnected then reconnected the cold start valve & it ran ok 1 morning but as soon as it got cold again it was doing it again.
today ive changed the cold start valve for another 1 i had in the shed & still no joy!
could it be any of the other sensors on the engine???????????
any help would be great as my mrs is useing the car & its a pain in the arse keep stalling at every junction in the morning!
cheers
Old 13-03-2005 | 08:34 AM
radiant red's Avatar
radiant red
maybe a faulty temp sensor?? if the ecu doesnt know if the engine is cold it wont open the auxillary air valve. Or maybe it is not rich enough, cold engines need to run rich.
Old 13-03-2005 | 08:36 AM
lockesRSparts
which sensor (colour sensor) is that mate?
Old 13-03-2005 | 03:22 PM
220TC's Avatar
220TC
try disconnecting the cold start multiplug then see how it starts. If theres no difference then take one of the pipes off the aux air valve and blow down it, if you cant then that means the valve is knackered (it should be fully open when cold). If thats ok then check the wiring to the electro magnetic pressure actuator on the side of the metering head, I had a very similair problem to you and it turned out the wires going to this were badly corroded.
Duncan
Old 13-03-2005 | 04:17 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
My rs doesnt start unless u hold metering flap down, it doesnt get used much at all really, thot that was the prob, but took it a good 100mile spin, came bk, next day, wldnt start until fla held down a bit? any idea. cold start valve disconected it was fine once.
Old 13-03-2005 | 06:11 PM
lockesRSparts
Duncan
whats aux air valve?
Old 13-03-2005 | 09:42 PM
220TC's Avatar
220TC
If you look behind the inlet manifold its the largish valve with 2 hard plastic pipes going into it, one comes from near the throttle body and the other goes to the back of the inlet manifold.
Duncan
Old 14-03-2005 | 10:04 PM
JaysS2TURBS's Avatar
JaysS2TURBS
When i start up my car when cold it missfires for about 15 seconds and then clears it seems like its running to rich when cold but once the engine is started the revs drop to low around 400 - 500 rpm so would any one know whats going on.
As for that Air aux air valve one way of testing it is to disconnect the black plastic pipe that runs from the valve and go into the throttle housing, then you should see a little hole take a small screw driver and stick it in to the hole, you should be able to feel like theres something hard inside thats the valve. Put the pipe back on then start the engine ,run it for a few mins and then repeat what ive just said this time when you put the screw driver in the hole it should just go threw and come out the other end of the valve then you know its working .So when the engine is cold the valve is closed and when warm its open
Old 15-03-2005 | 08:17 AM
rs nuts's Avatar
rs nuts
mine did this problem it was something simple like turning the c,o up it was low when cold run whould not tick over
its worth a try if you havent checked it yet
Bailes1992
16-08-2015 07:14 PM
Archiejay
12-08-2015 12:07 PM
Adam-M
22
10-08-2015 10:46 AM
mattman1234
24
01-08-2015 11:46 AM
Quick Reply: my car wont tick ova when cold?????? help!!!!!!!!!!
