HOW DO I FIT A GRS INTERCOOLER?
HI ALL. I`V GOT A GRS INTERCOOLER AND I CAN`T GET IT TO FIT WITH THE FANS BETWEEN THE COOLER AND THE RAD, I`V GOT 2 10" KENLOWE FANS AND I`V MOVED THE RAD AS FAR BACK AS I CAN BUT THE COOLER STICKS OUT TO FAR SO THE BONNET WONT SHUT! I HAVE HAD THE COOLER ON BEFORE WITH THE FANS IN FRONT BUT I DONT LIKE THE LOOK! HELP PLZ!
had the same problem on mine mate, in the end, i thought fuck it, and took the bonnet catch off, this is what normally hits the top of the intercooler,
Ive installed lockable bonnet pins now, safer with these on anyway, i wouldnt trust just a bonnet catch as they normally pop open while at high speeds with very messy effects.
I had this problem with mine when i fitted my second fan too,it moved it so far forward that it caught the underside of the bonnet
Drastic times called for drastic measures.I took an angle grinder and skimmed a few mm off the underside I did a tidy job though If you do this just remember to cover any bare metal afterwards
I dont really see the problem guys fitted mine with 1 fan and had no probs only think i did was chop bonnet catch back as it dented top of cooler hope u get it sorted m8 fans in front of cooler looks shit IMO
Mine was fine with one fan,it cleared no problem.The extra width makes one of the fans sit on either the left or right hand side of the cooler instead of on the cores so thats why it pushes it out a bit more
mine caught 2 when i tried 2 fans only have 1 on at the min but temps rise to high so i think ill be putting the other back on soon.
i am thinking of cutting the bottom cross member out to drop down the cooler a bit more
so the bonnet will close proper
same here mate, binned catch, got my drill out and fitted some pins.
I personally think they look good
the reason for moving my cooler is because the bonnet has already come open at 50mph, just rebuilding the car now , the cooler is the last thing i need to do!
vdun01
Ford Fiesta
05-10-2017 08:14 AM
