PDA
View Full Version : Ford Escort RS Turbo
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 [83] 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107
  1. who is it
  2. any one know
  3. Series 1 Graphics
  4. Cossie fuel pump?
  5. coil-overs on s2
  6. Radtec intercooler
  7. F.A.O Shane
  8. NEED SOME ESCORT COSSIE WHEELS 16"
  9. UREGERNT i need a new down pipe to day 12-05-06
  10. Do dumpvalves work????
  11. Lower Splitters for 88 spec Bumpers
  12. jeezus not another
  13. pace double brackets
  14. Probably been asked before but......
  15. OIL TO USE AND MOBILE ONE
  16. Was on the rolling road today
  17. s1 dials
  18. Where can i get???
  19. Seat Ibiza Front Splitter
  20. Series 1 front gearbox mount
  21. 1.6 turbo heads
  22. rst van
  23. 5th injector
  24. Underfuelling problem.....
  25. erst paddle clutch help ????
  26. will it fit!!!!?
  27. Oil Cooler
  28. 90 spec spoiler
  29. Oil Pump Removal
  30. Radiators
  31. guys, is this a crank position sensor on my engine?
  32. RST outin the sunshine
  33. Is the gearbox end plate still available new from ford?
  34. plastis windows
  35. back box question
  36. any decent ford tuners in cumbria?
  37. MK4 Speaker Pods
  38. Help, reference Koni's please...
  39. how do these bolts come off lower suspension joint? *pics*
  40. Oil Pressure Light
  41. Bought a series1
  42. zetec turbo build question regarding c20let pistons ?
  43. what is the xr3i box code stamped on it?
  44. More guage questions
  45. Help me with history .. if possible
  46. abs belts/modulator question with pic
  47. clear or amber, mind made up with pic
  48. advice on intercooler and radiator
  49. RS 3 or 4 spoke
  50. DUMP VALVE
  51. Series 1 Radiator
  52. Problem... Help!
  53. if ur stickin a zvh or zetec in a erst
  54. bosch fuel pump
  55. EFi fuel lines
  56. Help Please!!!
  57. which is the largest grs intercooler
  58. any zetec turbo MK3's out there???????
  59. anyone know the size of the little end of conrod?
  60. SFS hoses bad fit?
  61. anyone know wot this is?
  62. brake pipe fittings quick question
  63. CLUTCH OR ENGINE MOUNTSS?????
  64. some advice please
  65. taking apart the driveshaft
  66. Smokey Joe
  67. S2 boost problem
  68. What would you do ?
  69. my s2 ans xr2i
  70. Steering column guage pod!
  71. Lowering springs
  72. pic of series 1 rear quarter rubber...PLEASE!
  73. FAO MEF
  74. rst s1 does any 1 no if still about B44WHX
  75. MK3 spot light brackets
  76. How much power can a standard T3 take before it fails???
  77. Another Brake question
  78. ST170 brakes on S1....what is needed for the conversion
  79. Your recaro's
  80. electric sunroof on S2
  81. Not quite sure if this is a good thing ...
  82. Recaro seats......
  83. focus rs box in mk3 escort
  84. engine set up
  85. Infinity MJD and his power roof and general chit chat etc
  86. Removing a dump valve
  87. Wheel hub flange
  88. Brakes upgrade
  89. Cold starting help needed????
  90. Price of RST lump ?
  91. just had my erst MOT'd
  92. Latest thing my S2 done, JUST HAPPENS TOO BE THE LAST!! LOL
  93. Problem with Idling... I think it could be Dump Valve?
  94. AMERICAN TALL BLOCK ENGINE
  95. american tall block
  96. Radtech intercooler or not?
  97. Starter Motor Bolts
  98. cossie management on and set up on s1
  99. Pipe work on 5th inj system with correct ends.
  100. Come on then - ERST roof repair.....
  101. REDLINE RUMBLE
  102. Rs sunroof
  103. my fans............
  104. RS Turbo Vids
  105. candy s1/xr update
  106. Am i losing power with a whining turbo.
  107. oh dear - test time
  108. Turbo help
  109. Which pipes do I change for boost pipes!!!!
  110. anybody using spax top adjustables???
  111. Removing ABS
  112. rs turbo mainshaft
  113. Theiving B******
  114. st170 gearbox
  115. FAO the "300Bhp+ CVH crew"
  116. ANOTHER OFFSET QUESTION!!!!!!!!!!!!!!!!!!!!!!
  117. any pic of rs500 cooler
  118. will air filter fit?
  119. rear anti roll bar removal on S1
  120. Anyone know who own's this car?
  121. HELP NEEDED ON MY CAR ITS NOT STARTING ??????
  122. rear discs
  123. Cutting my bumper up!!
  124. looking for car, if it still alive?
  125. COBRA 30MM'S FROM APT
  126. Exhaust manifold blowing, easy to do?
  127. Fooked me turbo water pipes
  128. Brakes? where from?
  129. FORD ESCORT XR3i COSWORTH
  130. found an ap clutch on my car
  131. rims rubbing on the mk4
  132. Stregthening welding
  133. hiding your on-line status is
  134. Where Can I Get A New One From?
  135. had some fun in the s1 today
  136. newman cam
  137. Power coating
  138. boot floor ?
  139. Z.T. Question....
  140. Parcel Shelf
  141. spring help......lowering question
  142. Chassis Dimensions
  143. EFI Convertion on my Series 2
  144. repair or new scuttle
  145. Compression Test???
  146. recaro seat badge
  147. S2 Cylinder Block
  148. When going onto EFI...coilpack!
  149. how do i check if my S2 ECU is chipped!
  150. mahle piston?
  151. vin plate
  152. More Ebay madness
  153. Wiring Question
  154. Value
  155. temp guage in wrong place. and fat inlet gaskets??
  156. electric water pumps
  157. Need some advice about an RS Turbo i want to look at
  158. are these clips available?
  159. Can u get water temp digi display?
  160. FINALLY
  161. Boost Question
  162. idle jumps to 2k when you pump brakes?
  163. noise from the turbo
  164. EFI conversion's slowly getting there
  165. BORBERT C's cool or not?????
  166. NEED NEW HUB
  167. deflex bushes on s1
  168. around about now.
  169. Erst metering head pipes red??????
  170. Sunroof - Anyone ever removed one permently?
  171. Arg ! What now ?! - !Update! Part Number needed
  172. Big BHP figure
  173. headcloth!!!!!!
  174. s1 samco swap
  175. dash iclocks
  176. what do you think????????
  177. roll cage
  178. wheel offset.....
  179. rs 2000 into mk 3 estate
  180. Sunroof advice
  181. Headgasket for 2.0 ZVH Turbo
  182. Going tp PE today for RR SETUP
  183. hunting........
  184. ENGINE MOUNTS
  185. AE Pistons
  186. warmer weather
  187. T34 Turbo's
  188. joined the elite s1 club
  189. Esc cos seats
  190. CVH ARP Head Bolts...
  191. Escort Prices
  192. Electrical Problem
  193. LAGUNA SPLITTER/HOW TO ?
  194. Fitting Subs...How did you do yours?
  195. whats my problem...
  196. 17" RS7'S
  197. WHAT SPRINGS ???
  198. fuel pump relay
  199. tinted front glass
  200. S1 radiator... where from???
  201. momo gtr's
  202. HEAD GASKET ???????
  203. Oil and water mixing???
  204. What Brakes You Using?
  205. Std ERST tailgate pic
  206. URGENT REPLY NEEDED ADVISE PLEASE PLEASE
  207. s1 rst
  208. just need some advice on my brakes please
  209. standard pistons
  210. How many miles do you get from a tank of fuel in your ERST?
  211. solid lifters
  212. tank
  213. good garage round preston area
  214. Torque settings
  215. Pattern panels
  216. Pro Alloy Front Mount Intercooler
  217. another rst gone
  218. nms cossie intercooler fans ?
  219. ERST chipped ECUs
  220. wot wheels to suit my s1 cab 17"
  221. new to this any comments on my s1 cab
  222. Brake light problem
  223. Noise from front suspension... Please help!
  224. What Aux belt for a ZVH?
  225. Think i have a boost problem?
  226. S1 Home-made gauge pod
  227. FAO People Using EFI Turbo Engines
  228. Idling/Running problem
  229. What tyres you using
  230. oops my bonnet flew open
  231. fuel filter
  232. Tony's M.A.D is open for business....
  233. oil filter
  234. Hearts and diamonds ECU (90 spec)
  235. Strange metal sound.
  236. s2 radio
  237. Quickie-where are CTS based?
  238. t3 actuator ?
  239. oddkid number
  240. Series 2 Temp problem (Advice/ideas pls)
  241. Power
  242. Rad gone
  243. does a strut brace make any difference
  244. Groaning noise
  245. Orange Side Repeaters and Indicators WHERE FROM!>
  246. stage 1 box
  247. SLIGHT PROB
  248. How much boost shall i give her!!
  249. what clutch?
  250. rs turbo rear spoiler 87 vs 90
