guys, is this a crank position sensor on my engine?
just strarted to paint my engine, and noticed this little chappy
Is this a crank position sensor? And does this mean that when i one day convert to EFI my life will be alot easier? Im guessing my engine block started life in a fiesta turbo?
Oh, and also, how do i tell if its fitted with an EFI flywheel?
all help greatfully recieved
cheers
Danny
cheers
Danny
Ah well you can't have all the luck, thats luck enough if you ask me
Ive got an EFI flywheel you can have it for a grand (you know you want to)
Re: guys, is this a crank position sensor on my engine?
i got a fezzy bottom end but dont need it for trigger as use different set up...
bought it for Ł40..... yes Ł40.....
ner ner.... been runnin 220bhp thru it for bout 6 months mayb more and use car everyday!!!
well chuffed!
well chuffed!
Originally Posted by safechav
Lucky c*nt
Just been at the scrapper today measuring up where the hole is on a block
You sure that isn't an EFI flywheel already?
Zoggon
10-08-2015 10:39 AM
