oops my bonnet flew open
fitted my nice new radtec intercooler the otehr day and ignored a kid who told me to bash the cooler in a bit where trhe bonnet catch sits, anyway drive up the road, and bang, up the bonnet goes
anyone else found that the cooler fouls the catch and had to bash cooler in?
st170 breaking
i bent the puller on mine, was a bitch to reach when i wanted to open the bonnet but it never flew up, just so that if the 1st catch goes the hook still works, it usually wont with a cooler in the way
Originally Posted by jezRS
Originally Posted by Mr S1
No such problems with my Pace chargecooler !!!!
what sort of ACTs are you's seeing with your chargecoolers?
#1 in Spelling Club
New bonnet catch with new cable, properly set-up won't give you any problems. The catch has adjustment on it, which if incorrectly adjusted won't allow the barb of the catch to full engage. It needs to pass the 'lever' on the slam-panel and pop into place. Also, make sure that the corner rubber supports are correctly adjusted. They should support the bonnet, but not prevent it from closing properly.
fit some bonnet pins mate as an extra measure, that way it cant happen again
as i have heard of this happen a few times now, with different coolers as well
dont risk it (says me i aint even fit any yet! )
this is exactly why I fitted bonnet pins, just in case this ever happens!
not seeing above 40deg on my charge cooler at the mo, could all change in the hotter weather though
07-10-2015 12:56 PM
DavidK
27-09-2015 02:55 PM
