Fooked me turbo water pipes
Only gone broke the metal water pipes on me turbo its the second time ive done it now
ive seen a few pics cars with braided hose and banjo bolt being used instead does anyone no what sizes you need or any where i can buy some.if not any one got any of metal water pipes????
jon
jon
Audio specialist
hi mate, i went to a hydrolics company and they sold me
2xM12x10mm banjo bolts and copper washers,
also i got 2 14mmx1/2" fittings for hoses,
the only problem i had was the pipes were so close to the turbo they got hot and perished, so when i changed the pipes i put goodridge wrc 1inch heat sheild around them near the turbo, worked a treat!
You will be ok to run the turbo without the pipes while you are soucring new ones, just remember to put a pipe in place to join the pipe ends together
I did this when mine broke one day while giving it some serious shit.
Have you thought of making your own, solder copper pipes onto your banjos.....
Audio specialist
the only problem i had was the pipes were so close to the turbo they got hot and perished, so when i changed the pipes i put goodridge wrc 1inch heat sheild around them near the turbo, worked a treat!![Top](https://passionford.com/forum/images/smilies/smile011.gif)
09-10-2015 07:38 PM
andy130
02-10-2015 08:48 PM
Matt Baxter
16-09-2015 08:30 PM
Ben26
27-08-2015 08:56 PM
