URGENT REPLY NEEDED ADVISE PLEASE PLEASE
right guys umm im in need of a new engine mount and some polybushes where can i get these from its for a escort s2 turbo.
also i need a new suspension set up it runs to low i have koni adjustable dampers with eibach springs lowered by 45mm way way to much what springs could i use ive seen some P.I 35mm would they do.
thanks preciate your help in advance
is that £95 for 4 springs or just 2 ??
umm well i was advised to do all the engine mounts coz but the main movement is from the one right down near the clutch i think
cheers buddy
cheers buddy
ok so £95 for springs ill have a think on those i got some P.I ones give a 25mm drop might see what there like only cost £30 unless there complete crap and ill have some off you i dont know if 25mm is gonna be not enough drop ?? 30mm would be better what do you suggest i have 17" rs7's at the mo but looking to go to 16's what would you suggest??
borboyous
22-08-2015 11:17 AM
kosienutter
31
22-08-2015 09:55 AM
