PDA
View Full Version : Ford Escort RS Turbo
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 [62] 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107
  1. s2 fan problem
  2. boost
  3. Ignition problems
  4. Alternator belt pullry!
  5. Rims Q
  6. where can i get low lowering springs?
  7. RST owners S1 prefered, need a favour....
  8. Knock sensor wiring
  9. Window seals?
  10. lag
  11. 2.1 zvh pistons...please help..
  12. Drive shafts
  13. Anyone know where do get mint standard rs turbo rims from?
  14. S1 ECU, Can i Run Blue-Red-Black ECU
  15. CAMS's
  16. Fuel Pump Bracket
  17. Best Cylinder Head ?
  18. sorted rs turbo
  19. Standard Intercooler. What they Good for?
  20. will a fiesta turbo bottom end fit a escort turbo cvh head?
  21. What dampers?
  22. Felpro Head Gasket
  23. non custom s2
  24. ANOTHER S2 PROBLEM (F**KING CAR)
  25. Running temperature
  26. 2.1 zvh. what pistons/rings ?
  27. What timing Belt fits ZVH
  28. RS Turbo ZVH series one engine problems
  29. Rear bulb holders
  30. Any one fitted a st 170 or focus RS engine in a mk3-4?
  31. Gated and baffled CVH sump
  32. TOP SPEED OUT OF RST.. THRUSH
  33. Micro Dynamics Fuel Enrichment (5th Injector Controller)
  34. Superchip
  35. selector rod and B&M
  36. Help! Car wont start!!
  37. No oil, batt or parking light on instrument panel? efi conv
  38. what oil ??
  39. chipped ecu question
  40. zetec escort turbo
  41. Which clutch
  42. fuel pressure regulator
  43. s1 grill
  44. blown 2 fuel relays????????????
  45. New T3 please!
  46. ACT gauge
  47. Cam Lifters Genuine Ford Vs Pattern Part
  48. steerin wheel
  49. 180 bhp
  50. gearbox!!!!!!!!!!!
  51. piston rings
  52. brake problem / washers & bolts
  53. coil pack bracket
  54. glowing manifold & turbo!!!
  55. boost problem
  56. polybushes
  57. Tips and tricks with building up engine
  58. New management, which way to go??????
  59. Co Pot and backfiring
  60. Arrghh Sump Gasket
  61. Brakes
  62. engine set-up
  63. Smoky ERST
  64. I bought a new projekt in sweden
  65. vernier pulleys, timing belt
  66. Plastic Windows
  67. caliper brackets
  68. Coilovers........
  69. Stunning standard, genuine low mile S2
  70. Fuel Pump / Filter Options ??
  71. evolution chip
  72. what injectors
  73. zvh
  74. cooling problems
  75. Missing piece of repairmetal for the welder from a S2
  76. mef front tension strutts
  77. S1 and S2 header tanks. are they the same?
  78. rs turbo alternator
  79. t3
  80. Step by step needed
  81. What tyres did the S2 have
  82. efi conversion
  83. wont start
  84. best brakes under standard wheels??
  85. s2 cutting out
  86. help
  87. to much boost
  88. rs1700t
  89. Airbox Rubber Seal
  90. esngine question
  91. everybody help
  92. Will S1 doorcards fit a S2?
  93. did ford ever sell new s1 dash's
  94. actuator question
  95. beige injectors with differnt code? 0280150749
  96. s2 full width intercooler problem
  97. ACT Gauges
  98. wont start
  99. S2 rst, mounts for cross over pipe to rocker cover?
  100. gearbox
  101. c353 pvl
  102. wanted petrol pomp bracket RS turbo S2
  103. More Power
  104. cam belt snapped urgent help needed
  105. rev counter
  106. Worlds Fastest Fwd Escort RS Turbo, 1/4ml in under 10sec!!!!
  107. Steering Rack
  108. SLOPPY GEAR SELECTION HELP!!!
  109. Head Gasket
  110. tubular manifold
  111. think i have a problem
  112. Whats the Best Engine/Gearbox Mounts To Have
  113. s2 not boosting
  114. what power
  115. metering head
  116. What are these wheels off?
  117. Fuel pump pumping air
  118. fuel tanks
  119. New engine opinions wanted
  120. 1.4 bonus mk4 escort. any1 need any clips or bits or wotever
  121. Exhaust manifold
  122. C245 SAP
  123. REAR BRAKE CONVERSION
  124. Headlights Not Working
  125. WHAT TURBO SHOULD I USE ON MY NEW ENGINE????
  126. BnM short shifter
  127. Airtec Intercoolers??
  128. Zetec Turbo Conversion/Engine Mounts
  129. Lightening and balanceing - pros and cons?
  130. Sloppy Gears
  131. removeing abs
  132. Witch is the best exhaust to the S2?
  133. zvh boost
  134. speakers..
  135. possible 4wd conversion is it worth it?
  136. s1 turbo engine rebuild prices?
  137. standard airbox
  138. wont boost over 3 psi?
  139. tubular manifold
  140. MFI air filter - where in London should I buy?
  141. which loom for efi......xr3i or fiesta turbo(hav both)
  142. WHAT CHIP
  143. increasing boost pressure with actuator
  144. Will Cosworth 4 pots fit under standard S1 wheels?
  145. ECU chip identification
  146. how to get vin number on chassis re stamped
  147. wheel stud conversion
  148. Leaking gearbox?
  149. Rev Counter.
  150. S1 parcel shelves?
  151. Where do you make max bhp?
  152. pressure??
  153. wont start when its warm
  154. s2 headlights
  155. Been On the Rolling Road today.....
  156. cheapest place for s2 boost hoses
  157. mk3 ecort cab se how many made
  158. Turbo conversion
  159. rs turbo block gone pourous
  160. zetec exhaust flange?
  161. Lets see your engine bay/ rocker cover.
  162. Do most people use there S2s as an every day car
  163. flat spot
  164. rs turbo tappets...
  165. rs turbo firing order
  166. ANYONE?????
  167. My New S2
  168. virgin rst owner haha help
  169. AMAL valve
  170. managment for zetec turbo
  171. turbo woes
  172. Workshop manual about transmission
  173. 1800 cvh
  174. S2 full front mount
  175. 1.9 head gasket.
  176. s2 engine conversion
  177. putting focus st170 front brakes on a rs turbo s2
  178. no boost, please help : (
  179. WHICH CONRODS SHOULD I USE?????
  180. set up
  181. strange power?!
  182. how much for a s2 shell
  183. efi conversion
  184. Pic request
  185. revs picking up slow
  186. s1 panels where can i get from
  187. BMW Forums
  188. Non sunroof headlinings...
  189. Anyone got a S1 loom
  190. My 31K Series 1 Turbo
  191. sluggish
  192. Powder Coated Wheels???
  193. help please
  194. inner wing
  195. jamsport tubular manifold
  196. Buy New Pillar Trims for Escort Rs turbo s2
  197. Paint DOESN'T add hp!!!!!
  198. Reverse charge carrier
  199. What Calipers Are These?
  200. STEERING RACK MOUNT BUSH FITTED PHOTO
  201. Will a S2 loom go on in a S1 with S1 engine etc
  202. Any info on this ERST??
  203. Steering column question.
  204. COSWORTH INTO S2 RS
  205. change in fuel pump prime noise??
  206. Help...
  207. REPLACE STANDARD ACTUATOR TO -31 GARRETT ACTUATOR
  208. S1 wheel on a S2?
  209. no power and getting hot
  210. Escort Series 2 Radiator
  211. will a st170 gearbox fit a zetec engine
  212. camber adjustment
  213. Non starting S2.
  214. ZVH Conversion advice needed
  215. paint code?
  216. Does this mean the car is stolen?
  217. power
  218. Changing a valve,
  219. help!!!!!!!
  220. Req'd urgently
  221. Holed a piston - need advice
  222. what contains this cam kit
  223. HELP NEEDED BONNET STRUTS
  224. EXHAUST MOUNTS/RUBBERS
  225. strange power
  226. Old MOTs for C491 ANE
  227. cosworth monte wheels on a s2
  228. Bad news for my RS - Any advise????
  229. grs intercooler...what boost!
  230. 90 spec difference
  231. where can i get my rev limit removed?
  232. where can i get my rev limit removed?
  233. rst help
  234. ERST problem HELP!
  235. Steel wheels what sizes?
  236. series 2 rs turbo running problems
  237. HELP, S1 WONT RUN,
  238. whats the best oil to use (rs turbo)
  239. D REG S2'
  240. what causing this...
  241. White Escort At Torque's
  242. 2.1 ZVH OR ZETEC TURBO OR 1.9 TALLBLOCK
  243. HOW TO CHOOSE CORRECT MONGOOSE EXHAUST
  244. FORD Oil Return Hose
  245. splutter on boost
  246. car specs
  247. opinions on a s1 please
  248. cosworth discs and calipers
  249. power enginering cam
  250. HKS Dumpvalve
