cam belt snapped urgent help needed
Old 11-10-2007 | 11:41 AM
7554roy's Avatar
7554roy
Default cam belt snapped urgent help needed
hi i was driveveing my s2 erst last night and my cam belt snapped i dumped the clutch straight away ive been told to check the valves for damage is this a big job ? and how do i do it please help!!!!!!!!!!!!!
Old 11-10-2007 | 12:52 PM
dave green's Avatar
dave green
Takeing the head off a S2 is simple.
Takes about 20 mineuts
Dave
Old 11-10-2007 | 12:58 PM
antony215's Avatar
antony215
Escort Rs Turbo
Guaranteed that you have bent valves as the cvh is prone for it if the belt snaps How fast were you going when it went??
Old 11-10-2007 | 01:29 PM
addiction's Avatar
addiction
99 out of a 100 times it will bend the valves and the belt usually snaps when you are at low speed and sometimes when your staionary!
you can put a new belt on and then do a compression test or just by starting it up you will know cos it will miss like a bitch!!
easy enough to do once you've got the head off though!
Old 11-10-2007 | 03:29 PM
7554roy's Avatar
7554roy
so you suggest putting a belt on it and see if it will run if not check the valves i was doing about 40mph going from 2nd to 3rd
Old 11-10-2007 | 04:31 PM
antony215's Avatar
antony215
Escort Rs Turbo
If you put a belt on id turn it over by hand first to make shore you dont do anymore damage.
RUBY123
22-10-2023 12:04 PM
cos elle
01-09-2015 06:48 PM
JoeyBoyden
14
15-08-2015 09:51 PM
taylora1409
12-08-2015 12:06 PM
col93saphcos
07-08-2015 03:21 PM
Quick Reply: cam belt snapped urgent help needed
