boost
Old Oct 28, 2007 | 05:09 PM
ginner s2's Avatar
ginner s2
Default boost
my boost gauge flickers on idle.cud i hav an air leak sumhere.and has any of u guys fitted an external wastegate to standard t3 ,wot wud i benefit .or cant it be done unless u r running 300 bhp
Old Oct 28, 2007 | 05:45 PM
Dragsteer's Avatar
Dragsteer
Check air hoses for leak. Maybe hose from metering head to turbo. Or vacum on inlet mainfold plenum (you will have higher idle if remove vac pipe).
Old Oct 28, 2007 | 07:57 PM
Fiecos Dan's Avatar
Fiecos Dan
Some gauges do flicker on idle.
But you can pressure test the boost system.
No point fitting a external wastegate on below 260 bhp @ least.
Old Oct 28, 2007 | 09:54 PM
Dragsteer's Avatar
Dragsteer
yes I forgot, my old mechanic gauge oscilating a little. And present gauge sometimes oscilating but if engine revs dont oscilating I think it will be ok.
Old Oct 29, 2007 | 12:28 PM
ginner s2's Avatar
ginner s2
cheers lads
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
